Question about Hotpoint Washing Machines
Aquarius wmf470 has F-05 SHOWING cannot finish washing
DOES NOT SPIN AND SHOW F-05
5 Suggested Answers
  • 86 Answers
SOURCE: Machine not finishing cycle and final spin
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Need a bit more information! but when the machine does not complete the spin it normally indicates either the water is not empting or you have an out of balance load in the drum. If you only put a few items in the wash they may not be able to distribute evenly around the inside of the tub thereby causing it to become out of balance when it spins. Solution: put more cloths in. Or if you are trying to spin a large object such as a sheet, then take it out unravel it and put it back in.(It may have got knotted up). If there is still water in the drum you have a pump out problem which could be the pump, a blocked filter/sump, blocked outlet pipe or if your outlet is connected to an under sink waste, that may be blocked.
Posted on Aug 31, 2009
active209
  • 14 Answers
SOURCE: hotpoint aquarius wf340g will wash put wont spin
check solaniod valve on water pump
Posted on Nov 06, 2009
pappapumpdaf
  • 635 Answers
SOURCE: My Hotpoint Aquarius WF430 1300 doesn't complete its cycle
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Posted on Mar 05, 2010
  • 662 Answers
SOURCE: wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
My Hotpoint Aquarius WML540washing machine will not switch over to spin after the wash cycle, can anyone help
Most all the time the problem is in the timer/control.
You will probably need a new one, or a different one to fix this.
Jul 21, 2016 | Miscellaneous
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
MY PROBLEM IS THE FABRIC CONDITIONER IS NOT BEING WASHED AWAY THE WATER GOES INTO THE COMPARTMENT BUT WHEN THE CYCLE IS FINISHED THE CONDITIONER AND WATER IS STILL IN THE TRAY?
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jul 30, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint wmm39 aquarius extra washes but does not spin
you are in an unfortunate delemer. It is either your spin winding thats gone or the control board or timer thats faulty. Normally a technician has spares to test against to prove by process of elimination.Aquick test, pull the pressure switch pipe off the drum assy. and retry spin cycle. Alao take note if all water is drained out of the tub. Let me know
Sep 25, 2009 | Hotpoint WMM39 Front Load Washer
It wont do final spin..makes a clicking noise as it turns the drum during spin
I moved my washining machine in order to check pipes....thought id do a final test spin hoping that it would work changed the temperature setting to higher degress (60) put in on a empty wash for about 5 mins then turned it to fast spin an it slowly started spinning until it finished a complete spin!!!!...dont forget to turn the temperature down again!!!
Aug 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
AQUARIUS HOTPOINT WD440
How many times does it flash.
it still sounds like you have an obstruction in something.
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
