Question about Whirlpool Stove Temperature Sensor Replacement Range Oven Sensor Repla
Whirlpool micro shelf hood fan turns on by itself.
2 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: I have a WHirlpool Hood/Micro combo MH7140XFB-0.
Did your cooktop lights fail recently? If so, then the circuit board may have been damaged by a surge. We can probably repair that for you.
Otherwise, I would suspect a shorted high voltage diode or bad magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number (as MH7140XFB0) here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
Posted on May 28, 2010
Fan comes on by itself and won't turn off.
Is it a micro hood? If so, and you're cooking on the stove below, it may be that the microwave is getting too warm. Some of them have an automatic fan the comes on when you're cooking below them - especially when boiling potatoes or something else steamy.
Feb 01, 2015 | Goldstar Mv1502b Microwave Oven mv1502b
Please,tell me how do I turn off my self timer on my JVC micro component UX-lp5
Press CLOCK/TIMER repeatedly to select "DAILY 1", "DAILY 2", or "DAILY 3", then press CANCEL. See page 2 of this manual.
Mar 27, 2013 | Audio Players & Recorders
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
Have a Whirlpool MW Model MH6600XV with a vent hood; last night the vent went on by itself and I was unable to turn it off except by the circuit breaker; turned the breaker back on this morning and the...
If you got it hot enough from your soup there is a fan switch to turn the blower on to cool the unit. Maybe next time cook that on a different burner on the stove to try to not heat up that area under the microwave.
Sep 17, 2017 | Microwave Ovens
Does the maytag mmv1164ww1 micro/hood combo require outdoor venting?
No .. it can also be recirculated . you will need charcoal filters if you do so. There is a specific charcoal filter for each microwave hood. Any appliance part dealer would carry it ( you will need to give them the micro hood model number ) or you can order them online through Whirlpool parts website ( whirlpool owns maytag)
Mar 14, 2011 | Microwave Ovens
I have a WHirlpool Hood/Micro combo MH7140XFB-0. The micro portion has quit working -- lights, exhaust fan and clock still work. Turntable in micro turns but it doesn't heat and makes a funny noise.
May 26, 2010 | Whirlpool Microwave Ovens
VENT CAME ON BY ITSELF. WHIRLPOOL MH6130XEB-2
The hood / vent fan is controlled by the keypad, but it will also come on when the temperature of the hood area / stove top gets too high.
If it does not go back off by itself after a few minutes, then you probably have a shorted hood fan thermostat.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 24, 2008 | Whirlpool Microwave Ovens
F61 error
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
Dec 05, 2007 | Panasonic SC-AK78 CD Shelf System
CD player is locked
Hell Yes!!!  Thanks my friend - I haven't been able to use this thing for about 6 months.... You da man!
Feb 07, 2007 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
Whirlpool Stove Temperature Sensor Replacement Range Oven Sensor Repla Logo
99 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
