Question about Harman Kardon PA 4000 8-Channel Amplifier
Harman Kardon PA5800 amplifier short problem
I have a Harman Kardon PA5800 amplifier. While the system was on I was taking speakers wires off one speaker lead and puttin gthem on anotehr when my system went dead. When I powered the amp back on it now displays a short circuit indication. I will not green. I opened the unit and checked all the fuses, which are good.
Doyou have any suggestions? I'm hoping to get this fixewd by the Superbowl.
Thanks Norm
  • 14 Answers
SOURCE: one speaker not working.
Suggest you swap the right speaker into the left output if it works the the amplifer in the control unit is faulty. IF still on sound then the rigth speaker is faulty.
Posted on May 08, 2007
  • 63 Answers
SOURCE: Amp problems
From the above symptom, it show that the output stage of the amplifier have some problem.The protection cct come in to cut off the amp. when the output shorted or have Dc voltage.( this is to prevent further damage to the amp. & speaker ).If you know how to repair , just check on the pwr transistor (with heat sink )or else send it to the repair center.hope it help.
Posted on Aug 21, 2007
  • 44 Answers
SOURCE: Harman Kardon avr 1500 service manual
try here - http://www.harmankardon.com/product_support/support_detail.aspx?prod=AVR500
Posted on Dec 16, 2007
Open SKy
  • 620 Answers
SOURCE: harman kardon
Orastie
Wow, general problem here, but the most near your problem could be, power failure, or the Power adapter is bad, or a energy failure at home, time to buy a new adapter.
Carl
Posted on Dec 30, 2007
SOURCE: Harman Kardon DPR 1005 problems
Sounds like the power supply or associated module. Definitely fixable, but probably needs a technician.
Posted on May 13, 2009
Speakers harman kardon buzz
you have interference from something too close to your receiver. or too close to a speaker. don't stack all your devices together.
Apr 20, 2014 | Harman Kardon Audio Players & Recorders
My harman kardon avr 55 keeps shutting off on its own
HI,
Fist of all you have to disconnect all the speakers From AVR. Then switch ON the AVR . If its working normally then any of the speaker or any of the wire to the speaker is faulty. If so connect the speaker back one by one and check on which speaker connection does the AVR shuts off. That speaker or the wire to the speaker is faulty. Also try the same with the HDMI cables if they are use. Improper connction of HDMI cables can lead to these type of problem
If the AVR is not functioning properly even after removing the speakers(shuts off) thne there is internal fault with the amplifiers stage. Normally Dry soldering on the amplifier circuit board can cause this problem. Its need proffessional support.
Ajin
Apr 27, 2012 | Harman Kardon AVR 55 Receiver
I have a Harman Kardon AVI 200 ii, when i turn it on it turns on like 3secs and then it automatically it turns off, why is that?
It is going into protect mode. You may have shorted speaker wires, you may have an internal short in a capacitor either in the filter section, or those on the output.
Mar 24, 2012 | Harman Kardon Audio Players & Recorders
My harman kardon avr 100 keeps cutting out every 3 secs. i can hear the music but constently keeps cutting off. its very annoying... any ways to fix this probem?
Check the impedance of the speaker wires going into the amplifier. It sounds like at least one set of speakers is overloading the amp (shorted, or almost shorted)
Jul 24, 2011 | Harman Kardon AVR 100
It runs so hot why?
Possibly lack of ventilation or excessive volume through difficult speaker loads.
http://media.onecall.com/Image_Products/Harman%20Kardon/harman-kardon-hk990.pdf
See page 6.
IMPORTANT: When connecting two pairs of speakers, determine the impedance of each pair
by looking on the back of the speakers, in your owner's manual, or by contacting your dealer or manufacturer.
You can listen to two pairs of speakers at the same time ONLY if the impedance of EACH speaker is NOT LESS THAN 8 Ohms.
WARNING: Do not play sets of speakers simultaneously except as recommended above.
Amplifier may overheat.
Jul 09, 2011 | Harman Kardon Harman HK 990 Amplifier
I have **protect** in my kardon harman avr85?please give me solution
It could be a short in your speaker wire or the crossover in your speakers.
1) Turn off your unit and disconnect your speaker wires at the amp, if the protect is no longer displayed when the unit is turned back on, check the connections on the speakers. If you do not visually see a short on the speaker wire connection, turn off the unit and disconnect the wires at the speaker and isolate them so they do not touch then connect the speaker wires at the amp. Turn on the amp and see if the protect is on. If it is on, the wire has a short somewhere in the line. If the protect is off then suspect the speaker has a short in the voice coil or crossover.
2) If the protect is still on after you disconnect the speaker wires at the amp, it could be the power IC in the amp is shorted and needs to be replaced.
Jan 10, 2011 | Harman Kardon Audio Players & Recorders
I own my harman kardon 620 amplifier for about 8 years. Now the sound from the speakers comes on and off intermittently. I have connected and disconnected all the cables to the speakers but it still has...
The problem is in the audio circuitry, there are bad solder joints on the board that need to be addressed, from your description it is a intermittent issue with the sound. Since this a high end unit I recommend a top audio technician to work on your amplifier, and I suggest not using the system until it is repaired because the risk to the audio output parts getting damaged is high and they are pricey.
Jan 07, 2011 | Harman Kardon Harman HK 990 Amplifier
Older Harman Kardon computer speakers have loud hum
The hum (50 or 60 Hz) is caused by the AC power getting into the entry point of the amplifier. Either the filtering capacitors from the powersource of the speakers have dried up - replace them - or there is a short in the cables.
There is another possibility: if you have kicked the subwoofer  box its transformer might have slipped from its fixings and now is touching the subwoofer speaker frame.
The only way to find which is to open the cases.
Nov 28, 2009 | Harman Kardon HK695 Computer Speakers
Harman Kardon PA 4000 8-Channel Amplifier Logo
114 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
