Question about JVC TH-G30 Theater System
No sound from all speakers except front left and front right
When I do a test all of the speakers are heard from, but one I try to watch anything, it only works from the front 2 speakers.
Hi, I hve JVC TH G30 and i have connected my DishTV receiver (not HD) to the Aux port of the device. I can get sounds only on the front left and right speakers.. Is there an option to get surround for this kind of inputs.. for the rest surround is working perfect..
Posted on Jun 07, 2011
  • JVC Master
  • 5,309 Answers
Check the cables from the DVD to the Amp and make certain your in Dolby Digital mode on player.
Posted on Jan 26, 2009
    Genius:
  • 1,175 Answers
Yeah,
Grubhead has the right idea.
Make sure you have the receiver set to Surround mode or 5.1
Posted on Feb 08, 2009
2007 cierra ,my radio cones on but not putting power to speakers except to 1 front speaker and it has almost no sound ,up full and very screechy . do I need a new radio ?
Sounds like a wire is shorting out, probably in behind the stereo, but more likely in the back where the speakers connect. Check for something shorting out or a wire grounding out near the speaker.
You can trace back from there.
Other than that probably is the stereo.
Dec 01, 2014 | 2007 GMC Sierra 1500
How to set up surround sound
Not sure what you are looking for
But if 5 speaker setup have your front left and right speakers on the appropriate side of the television, your center speaker in the middle of the tv, Either mounted on the wall or underneath or on the shelf, try to have the center speaker set back from the front speakers. Subwoofer usually I mount behind the entertainment center. Your rear right and left speakers optimum position is behind you on the left and right.
If its a 7 speaker setup everything is the same except side right and left speakers go in the middle somewhere between the right and left front and rear speakers
I will make a example the the cursors [] Speaker *TV
LF[] CT and TV*[] RF[] []Subwoofer behind tv
SL[] []SR
LR[] RR[]
Hopefully that helps
Aug 15, 2013 | Audio Players & Recorders
I have Harmon Kardon AVR 25 ii receivers and I have attached it to Bose 701 front speakers and three other Bose surround speakers and an subwoofer. All the speakers work except for right speaker, I need...
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Jun 16, 2009 | Audio Players & Recorders
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
One speaker not working and Scratchy Audio
just check is there any loose contact frm that speaker connection plug out the cable connect it again and have a check it may work...
or may be any time the speaker may be falled on ground so may be there is problem
Nov 23, 2007 | Gateway GMAX 5100 Computer Speakers
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
Mar 15, 2007 | Sony STR-DE545 Receiver
JVC TH-G30 Theater System Logo
286 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
