Question about Sirius HONSC1 Interface for Honda/Acura
Low volume from my Sirius radio
I had a SCC1 (Sirius connect vehicle turner) and a HonSC1 professional installed into my XM ready 2007 Honda Odyssey. The volume is very low-it can not be heard turned up to full volume with the heater fan running. I already put in the code 162534 and it increased the volume very slightly. I tried to the code in again but now the channel just changes. I appreciate any help on this matter. My installer is also stumped.
    Genius:
  • 1,011 Answers
Sir,
If volume is too high reduce volume it may be solved by within in 1 week.
thanks
good luck
Posted on Jan 25, 2009
  • 15,935 Answers
Particularly in some Toyota/Lexus/Scion vehicles, you may
need to enter the toggle code to raise the level to HIGH so
the satellite radio level matches the FM/CD levels more
closely. Here’s how:
1. Turn stock audio system on
2. Switch to SAT operation
3. Rapidly enter using the stock radio preset buttons
the following code: “162534”
4. The audio level will toggle to the new setting, which
will be immediately audible if the code was both
promptly and correctly entered
5. If no audible change, enter the code again
6. Check the audio level on similar channel from
Sirius vs. FM, then try CD
Note that some variation in audio levels exist between dif -
ferent sources. You may nd that FM is louder when compared
to CD or satellite radio or vice versa and this by as
much as several dB. This is normal in our experience and
should not be a concern. Leave the audio level toggled to
the setting that matches the other sources most closely. If
you hear distortion on the SAT source even when the stock
radio is playing at low volume, you may need to toggle the
audio level to LOW.
The default settings on the interfaces as shipped are as
follows:
TOYSC1: default setting = LOW
HONSC1: default setting = HIGH
The rst time you toggle the TOYSC1, it should go to HIGH.
The rst time you toggle the HONSC1, it should go to LOW.
Conrm the change by listening.
If your vehicle does not come equipped with XM radio, it must meet one of the following requirements:
  1. CD only headunits, CD/Cassette headunits, and 6-CD Changer Headunits must have a "SAT" or "XM" button.
  2. The headunit must have a monitor or a touch screen monitor.
Unfortunately, there is not much more you can do about it. It is a known problem with the hon-SC1. If it is set to HI - thats the loudest it will get, and there is no other option.
  • blueextc3221
    blueextc3221 Jan 25, 2009
    For all my customers, I suggest a standalone reciever...
    Mainly because of adaptability issues, but also because of the following...
    1. FM Modulation install is quicker and cheaper (parts & labor).
    2. A standalone reciever can be moved car to car (or home) without the re-activation fee of $75.
    3. Less compatibility issues (like the one you are experiencing).
    4. Can be installed in any vehicle directly with an AUX port
    It may SEEM more convenient to adapt to a factory installed system, however the disadvantages far outweigh the advantages. I'm sorry your salesperson/Installer did not recommend a standalone unit.
    Good Luck - Thanks for using FixYa - A Fixya rating is appreciated!!
    Sergeant:
    Champion:
  • 435 Answers
Hi, turn off the heater. Check all the harnesses. Check each speakers one my one.
Volume might be low, if one/ two of the speakers dont work.
Check all the connections again.
  • Sirius Master
  • 19,396 Answers
If preset did not fix the low volume problem, then that means that there is a contact.
In that case there is need to verify the system wirings.
  • 10,515 Answers
The volume is low because of a factory preset on the HON-SC1 piece; this can be resolved by:
1. Turn stock audio system on, switch to SAT operation.
2. Rapidly enter on the stock radio PRESET buttons the following code: “162534′.
3. The audio level will toggle to the new setting, which you will hear immediately if the code is entered correctly and quickly enough.
4. If no audible change, enter the code again.
5. Check the audio level on similar channel from Sirius vs. FM, then try CD.
The HON-SC1 ships with a factory setting of HIGH, but it may have been toggled into LOW by accident.
Take care.
  • 916 Answers
Please check here there are multiple fixes possible I used the second one myself without any problems.
Chrysler 200 convertable how to put pictures on radio
SiriusXM Connect Vehicle Tuner - Shop - SiriusXM Radio
https://shop.siriusxm.com/xm/ctl10600/cp49759/.../c...
Sirius Satellite RadioMy Account. I'm a Subscriber ... Image 1 SiriusXM Connect Vehicle Tuner · Image 2 ... Add Satellite Radio to any SiriusXM-Ready™ car stereo receiver. Connect ...
[PDF]User Guide - SiriusXM
www.siriusxm.com/.../pdf/SkyDock_UserGuide.pdf
Sirius Satellite RadioThe XM SkyDock incorporates an XM Satellite Radio Tun- er . A special .... image to match the XM SkyDock's .... found on the My Account screen (in Settings), ... Button: Tap to tag the current song and add it to your tagged song list . For.
Dec 10, 2015 | 2011 Chrysler 200
How do i set up the sirius xm
This radio is SiriusXM *READY*. You will need to purchase and install the *optional* SiriusXM-Connect Vehicle Tuner kit (tuner, antenna, cables, hardware) specific to your radio - linked below:
SiriusXM Tuner:
SiriusXM SXV300v1 Connect Vehicle Tuner Kit for Satellite Radio
Manual (.pdf):
http://www.clarion.com/us/en/pdf/CZ702_Manual.pdf
Jun 11, 2015 | Clarion CZ702 Car CD/MP3 Player - 76 W RMS...
Why can't i get oprah on my sirius radio natalieromyn@shaw.ca
On Sirius radios, some programs require a subscription to the "Best of XM" and on some XM radios, you need a subscription to the "Best of Sirius" to get their programs. Call XM/Sirius and ask them, but I think that you have to pay extra for the "B.O.XM".
Jan 18, 2011 | Sirius Sportster 5 Satellite Radio...
I have a Siriusconnect Home Tuner and an XM Ready Receiver. Will they work together? What do I need to make the connection from the 8-pin mini DIN on the Tuner to the XM connector on my Denon AVR-587?
Not gonna work, sorry to say. You need the little two-piece "XM Ready" tuner unit (with antenna) to plug into your XM Ready receiver. Sell the Sirius Connect Home Tuner and buy the XM unit. XM unit still available at some Best Buy stores.
Sep 19, 2009 | Sirius Satellite Radio Receiver
Replace satellite system in 2007 saturn aura xr
If you are looking to convert your radio from XM to Sirius, there are a number of kits available by typing 'convert radio from XM to Sirius' into your favorite search engine. But why bother? XM and Sirius have merged and you can now get Sirius programming on the XM band.
Mar 01, 2009 | 2007 Saturn Aura XR Sedan
Need to disconnect XM Tuner
the xm receiver is in the left rear quarter of van looks like between wheel well and rear of vehicle this is drivers side
Jul 17, 2008 | 2007 Honda Odyssey
Satellite Radio
 Yes, but it will require a tuner adapter so that your deck will properly recognize XM. However for my deck I noticed that "Sirius" will still be displayed as the satilite provider on the display menu. Confusing but don't cause much concern.
May 22, 2008 | Car Audio & Video
Sirius vs. XM
Hello pdweidner,
The CN-NVD905U is fully satellite ready and is compatible with both Sirius and XM. To change services you will need to purchase and install a XM compatible tuner and antenna to replace the Sirius tuner and subscribe to XM service.
Best regards,
Ken
Go Ahead. Use Us.
May 13, 2008 | Panasonic Strada CN-NVD905U GPS Receiver
SAT Radio installation
What you need is the SCC1 (Sirius tuner) and the KCA-SR50 (Kenwood adapter). The ESN number can be found on bottom of SCC1 before you install it.
Mar 17, 2008 | Kenwood KDC-MP435U CD Player
Sirius HONSC1  Interface for Honda/Acura Logo
772 people viewed this question
Top Sirius Car Audio & Video Experts
xxxxxx xxx
Are you a Sirius Car Audio and Video Expert? Answer questions, earn points and help others
