Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Water overran ice maker tray
Water ran down and froze all over everything in the front of the freezer from the icemaker tray on down including the inside of the door. It appears the water inlet nipple dangling from the cieling of the freezer was aligned properly with the fill chute; but for some reason the water continued running even though the ice tray was full of water. What would cause this. Everything has been working fine for 1.75 years.
    Novelist:
  • 159 Answers
It could be one of two things. The fill cycle could be too long causing the water to overflow or the icemaker may not be ejecting all the cubes out of the tray. A normal fill cycle is very short. Maybe 6 seconds long. So I would check and see how long the fill cycle is and when it stops check and see how much the tray is filled with water. I would also check and make sure that all the ice cubes are ejecting next time you hear it harvest.
Posted on Jul 12, 2007
SOURCE:
My maytag mfi2568aeb french door bottom freezer has ice on coils in freezer and ice maker wont make ice
Sounds like the icemaker drain is clogged and the fill process overflowed the unit. the water then froze the drain and all overflowed water from icemaker. Remove icemaker and remove all ice from freezer and icemaker. Clean all drains. Reinstall.
Nov 19, 2014 | Refrigerators
Icemaker issues
If your ice maker still in guarantee or warranty period, then go to the seller and replace with a new one. If not then go to google and type in ice maker repairer in your area and you will find plenty of website of repairer.
Mar 15, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Water started pouring out of the icemaker and out the dispenser. When we opened the freezer door water poured out of the icemaker and down the whole freezer. Opened icemaker flap and water stopped. Turned...
Cindy, it’s either the water inlet valve that fills your ice maker or the ice maker itself that is bad. The ice maker itself controls the valve. It should come on for about 7 seconds to fill the tray. The valves do fail but not as often as ice makers fail. Its also possible that the fill tube to the ice maker is blocked with frozen water but since it made one tray that is unlikely. If you know someone that knows how to test the valve it would eliminate the decision of replacing the ice maker or the valve. Otherwise I would recommend changing the ice maker first. Hope this helps.
Feb 11, 2018 | KitchenAid Superba KSRG25FK Side by Side...
My ice dispenser quit working
There are multiple components that can cause this.
Open the door and put your finger in the ice tray. Is there any ice or water in it.
If so then the problem is likely the ice maker.
If not then the water supply is either stopped up or the water valve solenoid is broke.
If their is ice then the ice maker may not be making ice for other reasons. Is the Ice Level arm down? If so, the Icemaker has a clock like motor that is actuated by a temperature sensor.
Ice maker calls for water, solenoid fills ice tray, temperature sensor gets cold over about 45 minutes and closes the motor circuit telling the icemaker to dump ice.
If everything is right and still doensn't make ice, some mechanical aspect or the icemaker appears to be broken.
Thanks for using FixYa, Good Luck.
Mar 03, 2011 | GE Refrigerators
Icemaker on Hotpoint Model HSS25GFPAWW Refrigerator not working
try turning the temperature for the freezer down a little bit. it has to at least be around 17 degrees before the older ice makers start to work.
Jan 20, 2009 | Hotpoint HSS25GFP Side by Side...
Kenmore elite french door freezer on bottom
Odds are due to the fact the ice maker was left on for an extended time with a full tray of ice the mechanisms froze. You can take a hand held hair dryer and defrost the parts, just be careful not to get too over zealous and melt the plastic parts. It should only take a few minutes to defrost.
To avoid this problem from occurring again, I turn the ice maker off when the ice tray is full.
Regards,
Ann
Nov 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working
ONE OF THREE THINGS,THE INLET WATER VALVE ON THE BACK BOTTOM HAS FAILED,THE WATER SUPPLY TUBE IN FREEZER BEHIND ICEMAKER HAS FROZE,OR THE ICEMAKER ITSELF IS BAD,LET ME KNOW WHAT YOU FIND-MIKE
Jun 11, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice build-up in back of freezer
you probly got a water inlet spout froze over.. take out ice maker and look where water inters icemaker and see i that is froze
Aug 23, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Side by side fridge / freezer - Icemaker problems
What kind of ice maker do you have? Is it "Ice Maker Plus"? Pull the ice bucket out so you can get a better view. On the back of the freezer is a spout ramp that should connect to the back of the ice tray water deflector that the wire connects to. (I know, It's cold in there). The water deflector is connected to the back of the ice tray which sends the water to the tray. It should snap in.
Jul 06, 2007 | Whirlpool ED2FHSS Side by Side...
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
255 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
