Question about Kitchen Ranges
Heilsa QCPS-28000 board circuit problems... I replace the circuit board but i dont remember how to plug the write wire to the write connector somebody can help me please?!?!?
2 Suggested Answers
  • 51 Answers
SOURCE: The burner motor stopped working and I can no longer order parts for my heilsa QCPS 28000 pellet stove. Could it just be plugged and if not are there universal parts.
If you are able to disassemble it get the motor out and clean and examine it. If it is a brushed motor Ace Hardware carries brushes for electric motors just take the motor with you to match the brushes. Use electronic components cleaner to clean the motor. It can be found at auto parts stores. Be sure to lubricate the bearings or bushings inside the motor while reassembling it
Posted on Oct 25, 2016
Oct 25, 2016 | Pool & Spa
Heilsa Pellet Stove Manufacturers Information
pellet stove tp440 Pool & Spa Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > pellet stove tp440
Pool & Spa Heaters pellet stove tp440 questions and answers. ... for a manual orinformation on this stove it is an older stove we just don't know how old. ... heilsa pellet stove model qcps-28000 my pellet stove is smoking how to change ...
General Infrared Sauna Heilsa Sauna Supplier, Find Best ...
www.alibaba.com/general-infrared-sauna-heilsa-sauna-suppliers.html
Suppliers who can match your search. .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter .... Infrared sauna room,Portable steam sauna,Infraredheater,Pellet stove,Clothes dryer ..... updates on topics such as trending hot products, buying requests and supplier information - sent directly to your email inbox!
Good Quality Far Infrared Sauna Supplier, Find Best Good ...
www.alibaba.com/good-quality-far-infrared-sauna-suppliers.html
Suppliers > .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter ...Infrared sauna room,Portable steam sauna,Infrared heater,Pellet stove,Clothes dryer ...compare heilsa infrared sauna with good infrared sauna accessories ..... buying requests and supplier information - sent directly to your email inbox!
Jan 06, 2016 | Pool & Spa
We have a heilsa pellet stove model#QCPS-28000 ,its dropping pellets to fast ,how do I adjust the feed.
  1. SET THE AIR INLET DAMPERS
It is not possible for the manufacture to factory set your stove to work properly without some adjustments. The dampers help control the amount of airflow supplied for combustion.
A damper PUSHED IN all the way, maximizes concentrated air flow to the burn pot. This will maintain a robust fire.
The Auger timing is designed to be run, in most conditions, with the dampers closed.
In some areas/conditions, it mybe necessary to adjust the damper open slighty in order to slow down the flame and allow the pellets to keep pace with the rate of burn. This should be monitored closely to ensure you have the propoer feed rate established. If dampers are opened too much, the rate of burn will be very slow and the pellets will build up.
This setting needs to be fine tuned to according to your location and elevation. It is recommended that you start with the dampers pushed in to start.
Feb 20, 2013 | Northern Tool and Equipment Pellet Stove -...
Heilsa pellet stove model qcps-28000
how to change control board on a heilsa pellet stove
Nov 27, 2011 | Pool & Spa
Replaced door lock on front load wash still hav Fdl code and door wont lock
I had the same problem you have and did the same thing, replaced the lock. Whirlpool must be making a million on all the door locks people are replacing. The problem is on the CCU circuit board, not the door lock. There are bad solder joints, also called cold solder joints, on the circuit board where the spade connectors and relays (5 of them) are supposed to be soldered tightly to the board. Do you remember the PINK wires going to a plug on the door lock? Those wires go directly to the spade connectors then pass the door lock info on to the relays. The cure is to remove the CCU case with circuit board, it's easier that way. Then remove the board and touch-up those joints I mentioned. The CCU case is located in the machine at the top in the back. You will break off some of the plastic tabs on the case, it seems whirlpool used the same bad quality control in their plastics division as they did in the manufacture of their circuit boards. If you're not up on your soldering techniques, you can remove the CCU case, with board, and take it along with this response to a good appliance repair shop and they should be able to help you out. Good luck.
Mar 02, 2011 | Whirlpool Washing Machines
Error code f/ dl
FdL code is a door lock code. The machine can't lock the door. The problem is often times the circuit board at the inside top of the machine. Relays on the circuit board tell the lock to do it's thing, but the signal dosen't reach the lock and the machine sends the code. The problem is cold solder joints on the circuit board connecting the relays (5 of them) and the spade connectors that the wiring uses to plug into the machine. The cure is to remove the circuit board and either yourself or a competent appliance repair shop, touchup all the joints for the items I mentioned. The plastic housing for the circuit board is made from a poor quality plastic so be careful and remember where all the wires go.
Oct 19, 2010 | Washing Machines
Brake lights quit working
Tail lights acting insane?
We had the same issue with our 2000 Pontiac Montana. Brake lights, turn signal lights, running lights, back-up lights and emergency flasher didn’t work at all or operated at random. The cause: poorly designed aluminum contacts on the tail light circuit board and wiring harness connector arced over and disintegrated with normal use.
Pull the tail lamp assembly, remove the electrical connector and look for burned contacts on the connector plug and the connector socket (they call this long plastic piece with the socket the circuit board: it includes the four bulb sockets. Replace the circuit board and the wiring connector.
You can DIY this job with basic auto mechanical/electrical skills and tools. The two circuit boards and the two connectors set me back $230 (2009 cost) for new parts. The electrical contacts on the factory replacement parts are improved.
I needed a T-30 torx driver to remove the tail light assembly (you need this to change out bulbs, too), wire cutters, wire strippers, electrical tape and an electrical lug crimper to do the job.
Aug 02, 2008 | 2003 Pontiac Montana
Need wiring diagram
i dont think u need a wiring diagram. you should check your wiper motor circuit board first. on my 94 s10 the wipers either worked when they wanted to and now they dont work at all. just either replace the circuit board yourself ($19.95 on ebay) or replace the whole wiper motor ($60 on ebay) and your wipers should work. just give this a shot as its a good place to start. i myself am going to replace the wiper circuit board as its cheap, and really easy to access and replace. all you need is a screw driver. good luck. and no, im not a GM Technician. just owned my truck since day 1 and always try to check vehicle forums for answers first.
Aug 01, 2008 | 1994 Chevrolet S-10
WD62 programmer wiring
hi robbie,
you can slowly try each plug to every slot in the board. they are not interchangeable. they have keys that would not fit to other slots.
i hope i was able to solve your problem..please rate me...tnx
drcool299
Jul 03, 2008 | Hotpoint Aquarius WD63 Front Load...
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
