Question about Locks & Locksmithing
Replacing set screw on Kwikset door handle S2B
4 Suggested Answers
  • 10 Answers
SOURCE: cannot remove disk that covers screws to tighten my lock
The screws are located on the non locking side of the handle. To get the cover off most pop off by placing a small screwdriver behind the edge and gently prying. Paint/varnish will make this harder so you my have to take a razor and cut around it.
Please rate.
Posted on Jun 05, 2009
rsmith972278
  • 160 Answers
SOURCE: the key for my kwikset door handle lock won't
The answers to your problem are very numerous.
Usually what has happened is that when the lock was installed the pins (the part of the lock that rides on the cut part of the key) were not facing down. This allows dirt and debris to collect in the pin holes and also if a spring breaks it won't push the pin up to the cut part of the key. Some locks you can't even rotate to a position that faces down.
What I suggest is removing the knob or lever lock from the door and blowing out the key hole with compressed air. Work the key back and forth through the lock and blow it out again. If this doesn't work ... try and get a refund or a replacement from wherever you got it. Remember your time is worth money and so is your frustration. Don't waste allot of time trying to fix something that can be replaced relatively cheaply.
Thanks,
RSMITH972278
Posted on Oct 13, 2009
  • 35 Answers
SOURCE: have a kwikset bathroom door
Wiggle the backset a few times while pulling on one side or the other. Certain brans have a catch and will opnly release when this is done.
Posted on Feb 02, 2011
How do i attach the door lever?
http://s7d5.scene7.com/is/content/BDHHI/24910-04
Kwikset lever handles are held on with hex set screws. A wrench is included in the package. It's either a 3/32" or 2.5 mm. Note that the lock must be unlocked to remove or install the outside handle.
Sep 06, 2014 | Kwikset Brooklane Venetian Bronze Entry...
I'm replacing my front door entrance with a kwikset Shelburne Tustin lever 800SEXTNL 15 SMT CP. the hole is in place from the old hardware. I can't find the instructions. How do I secure the bottom part...
Her is the link to the installation guide for your lockset, which you can cut and paste into your Browser. It is a PDF file, which requires that your have a PDF reader like Adobe Reader installed on your computer:
http://s7d5.scene7.com/is/content/BDHHI/28741-05
Apr 04, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
The inside door knob came off of the Kwikset keyed door lock. How do I re-attach the knob?
There is probably a small set screw (hex head) on the bottom of the knob. If that doesn't work try just pushing it back on.
Feb 24, 2011 | Hardware & Accessories
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
Have a kwikset bathroom door handle. Want to put on a new one. I took screws off but handle won't come off. How do I release the handles?
Feb 02, 2011 | Kwikset Locks & Locksmithing
I am replacing my door knob and replacing it with similar lock door knob by Kwikset. I measured from the end of the door to the middle of the hole where the knob goes into which is 2 3/8". The problem...
Most kwikset locksets will work on either 2 3/8 or 2 3/4 inch setback. There should be two holes on the latch where door knobs fit thru the door. If yours does not have this option I would suggest that you get one that will match your setback.Hope this helps.Thanks.
Nov 16, 2010 | Garden
Replacing door handles and the "eschosions?" are not screwed on how do you remove
Installation instructions:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Kwikset has a one year warranty protecting the electronics and covers mechanical function and finish for the lifetime of the lock.
This link includes the info and contact information:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Oct 07, 2010 | Kwikset 909 909-L03 Lifetime Polished...
Change batteries on kwikset pushbotton lock.
If it's the lock I think it is, all you need to do is to remove the two screws on the inside of the door that holds the lock to the door. Pull straight out on the whole assembly. You should see the exposed battery once you have removed the outer case and handle.
Hope This Helps,
RSMITH972278
Nov 10, 2009 | Kwikset Professional Door Lock...
Cannot remove disk that covers screws to tighten my lock
Please rate.
Jun 03, 2009 | Kwikset Professional Door Lock...
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
61 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
