Question about Pioneer 1000 Watt 5.1 Surround Sound System System
JVC TH-M45 Can I use the JVC sub and speakers and plug them into another dvd player?
    Problem Solver:
  • 15 Answers
No, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Posted on Jan 27, 2009
Th-m303 sub dont sound when playing dvd
Please try and connect the DVD using the coaxial or the optic cable so that the input is seperated to perrform on the amplifier with a true DTS.
Oct 26, 2011 | JVC TH-M303 System
The cord /with the pin on both ends that plug in the back of sub woofer & dvd player, i need the female ,plug that on the back of sub woofer
The part is called a Din connector. You may be able to find it at www.jvcservice.com You will probably need to use the sub-woofer or the system model #, it is not listed under th-c30
FYI replacing it is not very easy.
Mar 26, 2010 | JVC TH-C30 System
Connect a new dvd player at the home cinema set??!!!!
You can go for Samsung, Lg or any product of your choice. The most important thing is that you check the back of your old player to see the connections, and make sure the player you are about to by has those connections also so that you would be able to connect your old sub woofer and speaker with the new player.
Nov 06, 2009 | JVC TH-M45 System
I just replaced the cord running from the sub to the dvd player. now my sub will not turn on
hi,
steps to trouble shoot for sub-woofer detection :
1. please check whether the cord is securely connected at both the ends.
2. check if there is transmission through the cord (there'll be a small static through the cord if there is transmission.)
3. reset the dvd-player to default audio-output and then choose the 5.1 sound system which is the correct setting for the th-c6.
4. also check the settings in the th-c6 whether it is in 5.1 mode(whether it includes the woofer-as it can also simple use the stereo speakers)
5. now check the sound output in all speakers by playing any original home-theatre system enabled dvd.
the system will work perfectly if the cord is in good condition, otherwise please replace the cord again, and this time check it at the store.
cheers
Jul 17, 2009 | JVC TH-C6 System
CANT GET ANY SOUND AFTER CONNECTING THE DVD PLAYER.
have you plugged the leads to audio in on the tv? if it as front sockets us them they are input only some on the back are output.good luck .farr64
Apr 29, 2009 | JVC TH-C3 System
Connecting an Ipod to JVC TH-M45 System
you can hook up ipod 2 different ways. the one i will use will be with a 3.5 to 3.5 mini plug connection(on both sides of cable it has i.e. head phone jack connection) and then set unit to aux in and that will give you sound from ipod. another way is with red and white audio cables to 3.5 mini plug connection. connect red and white to audio in on back of unit,and then set unit to that source.
Apr 20, 2009 | JVC TH-M45 System
Help
What video out put you connected between JVC player and TV ?
Look at back of your JVC player for Video out (yellow color) pin, hook RCA cable there and plug it to Input-1 or 2 in TV.
Now select AV 1 or 2 (what ever you hooked) in TV by remote and hopefully picture will in TV.
need further help, let me know model number of your TV.
Oct 11, 2008 | JVC TH-M45 System
Jvc th-m45 shut off
shut off audio system is performed to protect it from damage due to high current consumption or short circuit in speakers try to disconnect subwoofer first and check if it is ok. the problem in your subwoofer or its cord-change the cord and check if it is ok thats fine if not change subwoofer.do the previuos for all speaker one by one.
if all above failed you must contact service center for help.
Apr 06, 2008 | JVC TH-M45 System
JVC TH-M45 DVD Problem
its not the direct tv. i had the same problem before mine got all messed up. all i had to do was go into my dvd menu and select playback and turn it off
Dec 28, 2007 | JVC TH-M45 System
Pioneer 1000 Watt 5.1 Surround Sound System System Logo
338 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
