Question about Swingline New-dx18-13 Medium-duty Cross-cut Shredder, 18 Sheet Capacity - 1758585
Swingline shredder leaking oil - Swingline New-dx18-13 Medium-duty Cross-cut Shredder, 18 Sheet Capacity - 1758585
Oil refilled, but won't pump after using Rocker arm numerous times can you "purge" the line??
Sadly we have no idea WHAt you are asking about . never saw a shredder that uses OIL or has rocker arms .
Feb 17, 2016 | Gbc Swingline CS50-59 Strip-Cut Commercial...
Why won't my shredder come on?
Plugged into socket? Paper jam? Bad switch?
Feb 26, 2015 | Swingline GBC ShredMaster GLX2030 Jam Free...
I have a red light next to an icon that looks like a door. The door is closed completely however it will not reset. Any suggestions? Thank you
Probably the sensor that checks for the door being closed has been bumped out of position or is dirty and cannot sense that the door is closed. Some shredders have a sensor that is mounted on a circuit board and they will go bad and the only way to fix it is to have someone replace that circuit board. Hope this helps!
Oct 02, 2014 | Gbc Swingline Products - Gbc Swingline -...
Swingline 100X no power
Try the obvious - check your power point is workinh by plugging a table lamp or whatever. Test the table is electrically ok. If OK get in touch with Swingline Support
Apr 25, 2014 | Swingline 100X Drop-n-Go Personal Cross...
HOW TO CLEAN THE INFRARED SENSOR ON A SWINGLINE EX100-07
how to clean the sencors on swingline ex100 shredder
Feb 22, 2013 | Office Equipment & Supplies
Swingline shredder. draweer is stuck
Try putting the device in the forward mode by pressing the corresponding button for several seconds. This should help clear up any paper that's stuck in the cutting head and put your shredder back in use.
Thanks
Sep 13, 2011 | Office Equipment & Supplies
Oil leaks into bin
Do you have an automatic oiler on machine?
If so, drain the oil, unscrew the reservoir plug and wrap threads with teflon tape.
Dec 12, 2008 | Fellowes Powershred 480 Shredder
Swingline New-dx18-13 Medium-duty Cross-cut Shredder, 18 Sheet Capacity - 1758585 Logo
75 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
