Question about Kenmore Dryers
Which way does the drum turn in the dryer
Kenmore 70 series-modle #96576200
  • 1122 Answers
SOURCE: kenmore dryer series 70 won't turn on
most of the time it is the door switch that goes bad,also you can check the main fuse inside the dryer on the blower box,and always make sure your dryer vent and wall vent are clear to vent,let me know what you find-mike
Posted on Oct 29, 2008
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
Ben-mrfixit
  • 68 Answers
SOURCE: Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
Posted on May 05, 2009
buffalonyman
  • 1865 Answers
SOURCE: motor runs but drum doesnt spin
The belt may have broken, you must open the dryer case and check the belt. If broken, you'll see it laying on the bottom
Posted on May 18, 2009
  • 534 Answers
SOURCE: when the dryer is turned on it makes a bussing
sorry to say but yes the motor has gone out.
Dave
Posted on Feb 17, 2010
Kenmore dryer 70 series drum not turning
http://www.youtube.com/watch?feature=player_embedded&v=bJ5TNlzHKhA
Jun 06, 2012 | Kenmore Dryers
I have a Kenmore Dryer it works but will not tumble i'ts a heavy dudy super capacity 70 series modle 110-64742400 you may need this to dwjr-ele-2406028-fm54
When the drum won't turn and the dryer is otherwise working it's usually due to a broken belt. Open the front of the machine to inspect the belt.
  1. Under the lint door remove 2 screws
  2. Use flathead screwdriver to pry up the top lid
  3. In the middle of the drum should appear a belt, if you see it, pull on it. If it is loose it's fallen off the belt tensioner. If there's no belt of if the belt breaks in your hands, you need a new belt.
A sample of the typical belt routing for your machine is available at the link below:
Kenmore Dryer Belt routing
Sep 08, 2011 | 2007 Toyota Camry
Have a Kenmore Haevy Duty 70 Series Soft Heat model #96576200, I set the time push the on button dryer comes on to start drying but shuts off within 30 seconds. Any suggestions would be appreciated
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
a
Sep 27, 2010 | Kenmore 700 6972 Dryer
Motor draws current, won't turn drum.
The motor has failed & needs to be replaced
May 05, 2009 | Kenmore Dryers
Kenmore 70 series electric dryer
do you get any heat at all? is the drum turning? if yes and yes you need to check the dryer hose all wall hole to see if it is clogged,clean both out and see if this helps,if no heat the main heater fuse might be bad,check that also,hope this helps you-mike
Oct 26, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
