Question about Saws
What size blade does a duro model k3021 take band saw
the recycler
  • 22 Answers
SOURCE: Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Posted on Jan 12, 2009
  • 2692 Answers
SOURCE: Band Saw Blade won't stay on
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there.  If the back guide is a roller bearing I woud think you would want to roll all of the time.  If a solid bearing block natually a small space where it  will not hit is enough.
Posted on Jan 18, 2009
clyde2j2
  • 137 Answers
SOURCE: help with my dw100 band saw
Pull the plug on the saw, take off the covers on the upper and lower wheels of the saw.
You will see an adjustment bolt above the upper wheel and below the lower wheel, with the band saw in place on both wheels turn the upper wheel by hand, if the band saw moves to either side of the wheel use the adjustment bolts to center the band saw.
Posted on Jan 30, 2009
joboo1
  • 257 Answers
SOURCE: delta shopmaster bs 100 band saw
Hi, This Delta saw uses a 59 1/2 inch blade ( 1511mm).
Good Luck, this should Fixya!
Posted on Mar 06, 2009
  • 5 Answers
SOURCE: NEED BAND SAW BLADES FOR MY OLD BLACK & DECKER
sometime you can get lucky on ebay. thats one place you check. the best thing about it that it's nation wide. i found alot of odd items in there.
Posted on Jun 24, 2009
I cant seem to find the blade size for an older pro tech bandsaw model 3101. Is there a newer model that is compatible?
There should be enough adjustment on the tensioner to allow you to use any size blade that will be close to the original size. Set the tensioner/adjuster to the mid position measure the size of the blade, and look for one close to that size.
Nov 10, 2014 | Saws
Blade size for model 20314
I can hardly find information about your band saw. Here's a site that allows you calculate the band saw blade length. http://vintagemachinery.org/math/beltlength.aspx
I purchase my blades on sawblade.com . Hope that helps.
Oct 03, 2014 | Saws
What size blade for a craftsman bandsaw 113247110?
Your band saw uses 10" band saw tires and a 63 1/2" band saw blade. . Get band saw blades on sawblade.com
Sep 03, 2014 | Saws
What size of blade
The blade length is probably almost 100" , but I suggest you try to calculate the length , try this method Calculate Belt or Band Saw Blade Length VintageMachinery org
Jul 08, 2014 | Saws
I have a used bandsaw but i don't know what model
Band saws are measured by length and width of the blade so measure the length or just take it to the parts place and you should be able to get one of the same size unless its an old or off size no longer made but I dont see that being a problem. Try ebay for your measurements or even Grainger.
http://business.shop.ebay.com/Metalworking-Tooling-/92084/i.html?_nkw=band+saw+blades&_catref=1&_fln=1&_trksid=p3286.c0.m282
May 13, 2011 | Delta Saws
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
