Question about Pioneer AVIC-F700BT Car GPS Receiver
Pioneer AVIC F700BT
I cannot set my phone up and only settings menu I can use is the AV settings all menus including phone is greyed out? WHY??? Please help...
  • 3 more comments
  • raymondjr67 Jan 28, 2009
    Please describe the specifics of your problem below. We'll add
    your post as a comment to dcaplicki008's Pioneer AVIC F700BT problem, and notify you when a new solution is offered
  • marley212 Feb 16, 2009
    i hacve the same problem the only settings i can click on are AV SETTINGS or AV SOUNDS and everything else is grayed out.....
  • jking45 Feb 18, 2009
    I have same problem my iphone recognized it one time now it cant and the only settings i can access are the av settings???
  • Anonymous Feb 21, 2009
    everything greyed out
  • diegoac12 Mar 30, 2009
    everything is greyed out
    only i can use is : AV AND ASOUND SETTING WHY????
The emergency brake must be on
Posted on Mar 14, 2009
I also have the radio. It won't allow you to change the other settings until you connect the parking brake wire. There's an override that you can do if you choose not to connect it. Look under Avic411.com for help.
Posted on Feb 14, 2009
Pioneer avic 700bt
The Avic F700BT does not have a DVD player, it only has a CD player. If you want DVD capabilities you need the Avic F900BT.
Mar 31, 2010 | Pioneer AVIC-F700BT Car GPS Receiver
AVIC-F700BT Destination Menu-Address isn't lit up. Can't input.
It turned out that one of the harnesses wasn't connected...:-) I only noticed when I took the unit out and checked the connections.
Jan 10, 2010 | Pioneer AVIC-F700BT Car GPS Receiver
I HAVE A PIONEER AVIC-F700 AND I CAN NOT GET SOUND FROM MY IPOD..
If your avic recognizes the iPod and shows the songs being played, but you can't hear them, do this. Go to main menu, choose settings. Then go to av settings. On av1, make sure it says iPod. When it does, you'll hear the music.
Aug 12, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Ipod wont work
This could be due to the AV Setup. In the Settings Menu make sure that the source is "enabled" (i.e. switched on).
Best of luck
Jul 14, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Avic-f700Bt doesn't play DVD's
The AVIC-F700BT was not designed to play DVD's. If you wanted that capability you should have purchased the AVIC-F900BT. You can play video on the AVIC-F700BT from your iPod or USB Drive or SD Card or even from one of the AV inputs (mini jack on front or RCA's on the rear of the unit).
Jul 09, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
I am having the same issue
try this, Press:
"menu"
"settings"
"AV settings"
"AV1 Input"
then press it untill it says ipod, instead of off.
Jun 25, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Pioneer Avic-F700BT worked perfectly fine for 7 months but....
Hello!
My pos just did this today after I got in a hot car (had windows up for security).
Symptoms:
Briefly displayed the PIONEER default splash screen, LED lighting was the default ... light/bright pink (to match pioneer?).
Then screen goes black, then backlight gets fully dimmed and LED dims to darks white (R,01G,01B01)
Wouldn't really respond to anything... but plays CD in background.
I had a brainstorm while sitting in my car at ACC (ignition) and reading the lame online TS guide.
I turned my car to ON and put the gear shift in REVERSE.
The screen flashed to the password, and flashed black again....
Some how the system stablelized after some time and I resurrected it*.
* After tinkering I found ALL settings except the NAV data/settings had been lost.
In addition I believe corruption has occured in the memory holding the voice data. TTS... that phone thing voice command wont display when i press down on the Multi-nav? dial. Also system crashes when I try to access language settings. Sometimes a Windows CE error message bled thru reporting a fatal application error. Illegal operation request...
Hope this helps. I think my POS is going back to cartoys before my 30days is up.
Pity
Jun 05, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Gps map upgrades / updates
The site www.avic411.com is probably the best place to find information on this.
Firmware for the F700BT is available on the pioneer website.
Software for the PC to be able to create POI's (Points of Interest) is also available from Pioneer.
Jan 19, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
MY PHONE MENU SCREEN IS DARK AND I CANT ACTIVATE MY PHONE SETTING
The e-brake wire is required for these settings to be available. It has to be wired in as a safety measure. (So that the brake is engaged when you are fumbling with the settings, and not driving)
Nov 28, 2008 | Pioneer AVIC-F700BT Car GPS Receiver
Pioneer AVIC-F700BT Car GPS Receiver Logo
1,289 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
