I was shocked turning the unit on manually, and now it is continually changing channels and can only be turned on via remote. Please help.
SOURCE: Our coby 32" tv/dvd combo worked fine but tonight
Hello Should the player develop a malfunction, unplug the player for 30 minutes. After that, power on the player and the restore function should Parental Controls - Press the right direction button to access Enter Password. Input the 4-digit password to display parental control menu. The initial password is 0000. Change Password - To change the password, input the old password - -> input the new password- - >verify again. Please remember the password since the player's reset function would not revert the password. System Lock - Set the system lock funtion on/off. Set the lock function On to access the parental control setup.
Your Coby TV/DVD combo is locked I thinks. Your remote model number may be COBY RC-056 and answeres
First do this:
reset the player.
If it doesn't help reset the set to factory settings after resetting the password. To do this:-
Unrated Lock - Set the unrated lock on/off.
Reset RRT - Restore RRT to the default.
[Set parential lock to OFF, and you can set it after resetting the set to factory settings.]
If you wants any further assistance, feel free to contact me throughFixya.
SOURCE: My Coby 32 in tv
Hello
When autotuning the set goes throughs all transmitting channels, shows to be receiveing all channles, but seems to be tunes indefinitely, and no channels are locked, the memory IC inside the set has got damaged. In normal case, the TV will tune to all available channels at that tiime, in air or through the cable, whatever the case may be, tune up to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels.
The memory IC i stated above is a small IC with 8 terminals, and can be located very near to system control Ic, at system control section. In some sets, it will be SMD type [Surface Mount Device], and in otheres will be of DIL type [Dual In Line]. If it is a DIL type, it is very easy to replace. If it is SMD type, proper care should be taken when replacing it, not to damage any track on circutit board and nearby components.
Open your TV, locate the IC and desolder it out of the printed circuit board, go for a same type and number, replace it. This will solve your problem.
OK.
SOURCE: Coby 22in. TV/DVD Combo Digital
You could just reset back to factory defaults and let it rescan for the channels again.
SOURCE: I have a Coby TFTV
The tv still new only 1 week old?Yes,return it where u bought it and get a new tv replacement.No?This tv have a 2 long boards that call the LCD inverter boards each sides left and right sides of the tv.Could be etheir one of these two of this long LCD inverter boards it is dead.Must have electronic equipments to test to know exactly with one it is dead.These 2 long LCD inverter boards only job are to probvided a backlight to the tv LCD screen panel to get a pictures.Both of these long LCD inverter boards are not that exspensive and very easily to take the apart and replaced.Tries websites like Shopjimmy.com,Ebay.com to buy both long refurbishes LCD inverter boards for the replacement.
