Question about Dell 1135n AllInOne Laser Printer
My dell 1135n laser printer will not print because it is offline
We moved printer but hooked everything back up the same but now it says its offline and wont print anything. It is connected wireless
    Master:
  • Dell Master
  • 155 Answers
Well, when your dell printer say's offline, this problme usually comes because of so many reasons, some time we face such kind of problem only because our printer is not connected to the wifi or sometime there could be some other issue. for more information you may visit : How Do Fix Dell Printer Say Offline Using Windows Laptop Fixotip and follow the instructions to fix the dell printer problem.
Posted on Sep 16, 2017
    Problem Solver:
  • 8 Answers
I was also facing same issue with my DELL printer it shows offline. I tried a lot to fix that however I was not able to fix that. I got this link http://www.printer-techsupport.com/Dell-printer-support.html over the internet. I just visited and made a call on their toll free and got instant help for my DELL printer.
Posted on Mar 21, 2016
Corysf62
  • 188 Answers
SOURCE: Dell Laser MFP 1815 wont print
The printer status showing offline is more then likely a computer issue then the printer. On the printer, use the menu to select "reports" and then select the printer settings report. If the printer prints the report, then the printer itself is working, and it is a communication issue between the printer and the computer. If you are connecting to the printer with a usb cable, then try moving the usb cable on the computer to another port. If this does not work, try deleting and reinstalling the printer.
Posted on Sep 28, 2008
  • 73 Answers
SOURCE: Dell 1710 offline cannot print
Can you right click on the printer and select "use printer online"?
Posted on Feb 10, 2009
  • 50 Answers
SOURCE: status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Posted on Mar 24, 2009
97F350diesel
  • 1326 Answers
SOURCE: PRINTER "OFFLINE" FROM PC CONTROL PANEL, PRINTER SCREEN READY
Make sure you have the ethernet cable plugged into the printer/network and is working properly. The toner replacement doesn't affect the network functions of the printer
Posted on Aug 06, 2009
joelr2005
  • 464 Answers
SOURCE: Keep getting "Printer Offline" from Dell 1700 printer
go to the start menu
click on run
type services.msc
on the list go to Print Spooler
double click on print spooler and select automatic on startup type
now press on start.
if that doesn't work go to this microsoft website and click on the Fix It icon with the little man holding a wrench. run this and it will fix it.
Posted on Jan 10, 2010
Manual feeder paper empty
Turn it off, wait for a while then turn on again. It should rstore operations if there's no ptoblems. Otherwise have it serviced (it will come up with an error code)
Mar 07, 2015 | Dell 1135n AllInOne Laser Printer
On my dell 1135n the scanner says not connecting, have unplugged the power and the usb port cables but have not fixed the issue
It could be the network connection or PC that your printer is plugged into. Try swapping it with another printer that you know works. If it still fails, you have isolated the problem to the printer itself.
Oct 08, 2014 | Dell 1135n AllInOne Laser Printer
How to replace fuser in Dell 1135N printer
Contact nearest Dell printer technician Center or Dell customer service center. If not available then visit this link i hope solved your issues.
Read More...Dell Printer Support
Thanks,
Jul 23, 2014 | Dell 1135n AllInOne Laser Printer
How do i scan to pc on network with Dell 1135N
Have you ensured that the printer is attached to your wireless LAN - very often it is worth trying to disconnect it and reconnect using the proper password etc.
Feb 12, 2014 | Dell 1135n AllInOne Laser Printer
Dell 1135n driver
Go to dell.com input your model number then go to drivers and support section look for that driver.
Jul 25, 2012 | Dell 1135n AllInOne Laser Printer
DELL 1135N WILL NOT SCAN MULTIPLE PAGES TO ONE FILE
When you are at the option to "scan to" and you change it to PDF, change the file name and it saves it as that one file. If you don't change the file name it does multiple sheets.
May 16, 2012 | Dell 1135n AllInOne Laser Printer
My Dell 1700n Printer keeps showing up as offline. I have a Dell Optiplex GX520 PC. My printer has been working fine, I moved the printer to a new PC temporarily and then moved it back to my PC and now...
hi
i suggest you reinstall the drivers on the computer(s) which will use the Dell 1700n printer.
let me know if this helps
if you need the drivers go to this link all you have to do is select the operating system (go to My Computer, right click and properties, will give you the OS)
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&ServiceTag=&SystemID=PRN_LSR_1700N&os=WW1&osl=en&catid=&impid=
Nov 03, 2010 | Dell 1700n Laser Printer
Sep 25, 2008 | Dell 1815dn All-In-One Laser Printer
Dell 1135n AllInOne Laser Printer Logo
428 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
