Question about Maytag Neptune MAH5500B Front Load Washer
What do nh mean on washer panel
It starts the washer cycle then stops and nh is on the washer panel
Stuck in wash cycle
More than likely the control panel is the problem, about $200 for the part on average. For more help and parts contact this website. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 29, 2017 | KitchenAid Washing Machines
Maytag atlantis washer stops mid cycle
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the fault repeats all the time to stop after a said period then it can be a fault on the panel board. check also the power supply to the board, check power to the processor.
Jan 14, 2013 | Maytag Atlantis MAV6000 Top Load Washer
My washer is saying F-51
This seems to be a common problem. If you hit stop/start each time the washer stops, the washer will continue further, allowing you to get through a load, but that is a temporary work-around.
You will need to contact the service department, and they will replace parts to fix it. One person had success with opening the control panel and reseating the connectors.
See this thread for more information.
Feb 12, 2012 | Whirlpool Cabrio Washing Machines
May tag 5000. f35 what does that mean
"F35" means Analog Pressure Sensor Failure
If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
Hope this helps.
Jul 09, 2011 | Maytag Washing Machines
My neptune washer stop working. has power but doesnt cycle. shows a FL code. cycle i mean as spin to start washing
FL means that the door isn't locked properly. Make sure that its locked tightly and restart the cycle
Feb 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Sep 21, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
Kenmore washer starting
"FL" is an over fill indication. Unplug the machine first (if you haven't tried that already) in an attempt to clear. If the problem persists, check all connections going to your control board, which is located under the control panel. Take them off one at a time and look for any contacts that may be corroded or dirty. This could be an indication that you have a bad control board, or a pressure switch that is starting to malfunction. Let me know if this helps.
Jun 22, 2007 | Kenmore 24082 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
