Question about Panasonic Lumix DMC-FX01 Digital Camera
Buttons stopped working
I only recently bought my Lumix DMC-FX01 a few months ago and have been quite careful with it - I bought a hard case for it and everything! This evening while looking through photos on it I zoomed in on an image and when I went to zoom out none of the buttons worked. Now I can switch the camera on and off (and the lens comes out when I switch it on and withdraws back in when I switch it off as always). However apart from the on/off button the only other thing on the camera that works is the mode wheel on the top. All other buttons do nothing. I've tried taking the battery and memory card out and putting them back in but that didn't do anything. I'm sure it's within warranty but I can't find my warranty card anywhere! Please help!
  • 1 more comment
  • jmiac Feb 28, 2009
    Great writeup from Guest. I used this procedure to take apart and check all the top buttons on my camera- which wouldn't even turn on.
    Here's a mod to the procedure:
    You do not have to remove the display connectors- just be gentle and flip the LCD display to the side and out of your way.
  • moscowfish Mar 31, 2009
    Thanks! I've exactly the same problem..turn on camera and it goes straight into extreme zoom and seems to freeze..scene mode constantly scrolls..it wont take pictures and the review mode is stuck on one picture (otherwise it works great..haha..). I took my camera mostly apart trying to get at the zoom toggle switch but I got stuck at a certain point of disassembly. Thanks to this post, I now know how to get past the point where I was stuck and get under the toggle to get at that piece of thailand sand that I think is wedged under there..Panasonic would surely charge more than the camera is worth..but I love this little camera and can't wait to get it working again..I'll let you all know the outcome..just got to find that little screwdriver again, and carefully shepherd those tiny tiny screws!
  • kaesermann May 04, 2009
    I had exactly the same problem and solved it with the clear description of Guest. I did not disconnect the display, so it went quite rapidly. The reason of the problem was fine sand penetrated. I washed it out with Contactclean spray.
    The camera works well now, however it appears a dark dot on the display that gets more distinct in the tele mode. It seems to be dirt inside the lens.
    Mnay thanks for your advice Gerhard
If yours still zooms in all the way when you turn it on, then I had a similar problem with mine. When I turned it on, the camera would zoom out all the way and the other buttons wouldn't respond. If I switched it to review, it would just cycle through all the pictures, so I figured somewhere the zoom lever was stuck inside. I don't know a lot about cameras, so I sent it in to Panasonic (it was still under parts warranty), but was informed that due to "grit substance" my warranty was voided and it would cost $179 to repair. Since I could buy the same camera used at www.keh.com for that price I told them to send mine back and I'd take a shot at fixing it (since I was pretty sure it was a mechanical problem). Here's what I did with a $1.79 glass repair screwdriver. Remove the battery and take out all the visible screws on the outside (2 on the right, 1 on the left, 3 on the bottom). Lift the back panel at the bottom edge, and it should pivot along the top edge until you can remove the back. Then unplug the two ribbon cables (the small one has a latch on top and the larger one has a black latch on the side that you need to lift). BOTH have hinges, not just the smaller one like other posts have said. Next you need to remove the front panel. There are three silver screws placed around the lens unit (look down inside, and you'll see them attaching it to the front panel). Remove these, and you should be able to remove the front (lift at the bottom and it pivots along the top edge). Now you should be able to pop off the top cover (with the zoom, power, etc). Now if you look at the bottom, there are two screws holding the board to the cover, remove these and you've got it apart. On the top right side of the board, you'll see where the external zoom switch pushes a very small black lever. This was where the problem with mine was, the black lever was stuck over. You can use the tip of the screwdriver to pop it back to the center position. Now make sure that if you push it one way or the other that it will recenter on its own. Mine didn't, so I had to pop the small silver cover off where the lever is with the flathead tip of the screwdriver. Be careful here. The lever just sits on a peg, and has very small gears that move a slide bar. If either of these fall, you may never find them again. I took both the lever and the slider off, cleaned them, and got it so it would recenter easily again. Then I put them both back in, popped the cover on (you may have to pry out one of the sides slightly to get it back on), and the lever works fine now. I wouldn't be surprised if your camera has this same problem. If it's something else, it's still probably a problem with this mechanism that you could fix. Anyways, reattach the board to the top cover, and pop it back onto the camera. Now insert the battery, and turn it on to see how it works. Even without the screen, you can try the zoom. If it all works, then all you need to do is put it back together in the opposite order you took it apart. When reattaching the LCD ribbon cables, make sure the hinges are open, insert the cable, and snap down its latch. Hopefully that works. I don't know much about cameras, but it wasn't too hard. Just work slowly and carefully.
Posted on Aug 19, 2007
I had this problem with my FX01 - went back under warranty and they replaced the board. I *thought* all the buttons weren't working until I put it in Scene (SCN) mode - turns out it thought the 'up' button was being held down constantly.
Posted on Aug 13, 2007
Thanks! 'Guest' had it nailed! I followed the instructions - very good. The only clarification is that the 3 "silver" screws that hold the front onto the lens assembly are really black screws and they are seen from the back, down deep in some recesses so they were hard to find. It isn't the 3 silver screws near the center that hold the sensor onto the lens assembly.
Posted on Oct 15, 2008
Thanks guest.
we followed your instuctions to the letter. Only one small hiccup where we didn't line up the shoot mode button before we put the casing back together, so had to take all apart again, align and then put back together! If anyone else uses this solution don't forget to check your shoot mode button is in the right position before putting the casing back together!
Otherwise a very good, step by step set of instructions that probably saved us a small fortune.
Thanks.
Posted on Jan 25, 2008
    New Friend:
I tried but one only screw didn't want to exit and I ruin its head so now it become impossible to remove it from the camera. Is it possible to remove the dust with compress air or something similar?
Posted on Nov 11, 2009
If the zoom buttons get stuck by sand or dust, you cannot take pictures anymore. After a few repairs of the zoom button - the mechanism is very tiny - there is a slider with teeth of a size smaller than in a watch - zooming with your camera is no longer possible - tiny bits simply break off. Then the only (economic) option is to place some external buttons:
total cost 0.80 Eur. The buttons can be bought in an electronics shop. You need a tiny soldering iron especially to connect the wires on the switch. It is better to remove the cover of the (remains) of the zoom switch.
How to open the camera and get to the zoom switch is explained elsewhere on this site. After a few times you do it in less than 2 minutes.
Posted on Jun 04, 2009
Thanks so much, Guest! I followed your instrucitons and the camera is working again. I can't believe I was actually able to fix it. It took me about 3-3.5 hours, but all is well!
Posted on Nov 25, 2008
    Genius:
  • 2,985 Answers
If you have the Purchase receipt- then take it back the the seller. Go to the Panasonic web site and check out the Tech support team.
Posted on Jul 13, 2007
SOURCE:
Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
Aug 23, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Lost Lumix simple viewer C D for Panasonic Camera DMC FX01
If you are looking for drivers in that CD, click Panasonic Support and check drivers list of DMC-FX01 at bottom of page.
and if you need Software CD, please contact nearest Panasonic service center.
May 15, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
When I zoom useing my panasonic lumix DMC-FX01 it turns off
Have you had problems when you turn it on and off from scratch before? It sounds like you have a problem with the lense extension. Now if you are lucky, it's just a bit of dirt in there and the best cure (I know, it sounds horrible) is to put the end of a shop-vac over the lense when it's closed and it will probably **** the obstruction out. If you are less lucky, the problem is with the gearing inside and in the middle of the luck-vs-effort range it could just have been bashed, in which case, you can try and push it back into alignment but be careful with it (he says, after he hit his last one with a large lump of wood to put it back).
Good luck :)
Apr 05, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic lumix dmc-fx01
If the dark spot is not focused, it could be on the sensor. Otherwise, check the lens for any dust particles. If you can't find any dust, take the camera to an authorized service center.
Aug 20, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic lumix dmc-fx01 won't focus
See the post for the same camera: "Buttons stopped working": there is a small 2 position switch connected to the zoom button. In my camera the zoom switch was stuck in one of the extreme positions. You have to put it back in the middle an re-assemble.
Mar 29, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
I broke the lcd of the camera
There is a guy in South Carolina who has lots of used parts for all the Panasonic Cameras at reasonable prices. I bought the LCD for mine and it works like new. I think his email is [email protected]
Nov 22, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
My pansonic lumix -fx01 digicam isnt responding ...seems sort of hung..
You can call  (044) 22352501
check this website for frequent issues with DMC FX01's
http://panasonic.jp/support/global/cs/dsc/faq/fx01/answer.html#q1
My only direct suggestion is to take the battery out for a few minutes and then replace it. Failing that, try running the camera with charger without battery installed.
Nov 14, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
The scene mode is in one loop!!!!!
I had this exact problem. The FX01 thought I was holding down the 'up' button! I sent it back under warranty and they replaced the board. However that doesn't mean it was unfixable; it's just cheaper for them to replace boards than test them and fix them. IMO.
Aug 06, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
919 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
