Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I keep geeting an f50 error code does anyone know what this is.I
Have looked all in it and cant find the problem
  • 318 Answers
This code means the unit is not sensing any motor movement. it could be the motor rps sensor, or a bad control board not sending any power to the motor.
try to turn the tub by hand and start over with a spin and drain cycle. if it still comes up with a failure, then it will probably need a tech to check if you are getting any power to the motor.
if you want to contact whirlpool and ask them if they will help you with the cost of repairs and then recommend an authorized service center.
Posted on Jan 30, 2009
What is code error F50 on my miele W3725 washing machine mean
I have today purchased a Miele 3985 machine with a know F50 Fault code appearing
Before I went to the expense of calling a Miele technician, I explored the blocked / clogged drain path
I removed the drain pipe and noticed there was a lot of 'residue' / gunk in there
I cleaned what I could, and blew through the pipe back into the machine
Then I did a cotton wash cycle at 90degrees, with a 1litre of bleach to clean the drain path
The wash looked extremely dirty during the cycle
It appears that this resolved the F50 fault code issue with my Miele 3985 Navitronic
Aug 08, 2014 | Washing Machines
F50 code and spanner
it sounds like it needs new brushes put on the motor or the belt is slack on the back of the machine when it is empty can you turn the drum freely by hand
Nov 18, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Keep getting F50 code cannot reset washer
There have been a lot of reports where technicians have been ordering RPS's prior to the common fix for the problem which is the control board. This is a common problem and the control board fixes F50 faults in most cases.
Nov 07, 2011 | Whirlpool WTW6400SW Cabrio Washer
What is f50 error and how to fix it
Hello there
The F50 error code indicates a stalled motor failure. Open the lid & see if the spin basket rotates freely. Look on the floor under the washer to be sure nothing has gotten in the way of the motor rotor. If everything looks good, you will need to have the motor checked with a meter to determine the diagnoses. Usually this type of failure will either be the motor assembly or a control board issue. ere.exe
Hope this is very helpful
Best regzrds richard
Dec 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer won't start spin cycle, error f50
The F50 error on the Whirlpool Cabrio / Kenmore Oasis points to the basket and possibly some obstruction keeping it from turning freely.
Please see the following PDF Service Manual for the Whirlpool.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Oct 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F50 Error Code on Whirlpool Cabrio Washer
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Aug 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code E000732-0001
This error indicates that it cant detect the scanner unit of IRC3220
Check the cable that connect the machine and scanner unit .switch off the machine disconnect the cable and reconnect it and switch on the machine again hope this will help
Jul 01, 2009 | Canon imageRUNNER C3220 Color Copier
Kenmore oasis and it keeps giving me a f50 code
Dec 12, 2008 | Kenmore Oasis HE 27082 Top Load Washer
F50 error code and Whirlpool Cabrio
JUST SPOKE WITH WHIRLPOOL ABOUT THE F-50 CODE. THEY SAID THAT THEY ARE AWARE OF THE PROBLEM AND THEY ARE PAYING TO FIX IT. ALSO THE CONTROLL BOARD AND THE RPS SENSOR MUST BE REPLACED TO FIX THE PROBLEM. THE OWNER MUST CALL WHIRLPOOL, NOT THE TECH, TO GET THEM TO PAY FOR IT. HOPE THIS HELPS.
Feb 08, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
193 people viewed this question
Dan Webster
Dan Webster
Sal De
