Question about Canon i950 InkJet Photo Printer
Canon i950 won't print
I don't think that the cartridges are very old. Maybe about a year, but they looked to be in good condition. Would this really cause my printer to do this? I don't even have to ask it to print anything. I starts flashing orange after I turn it on.
  • 5 more comments
  • megenfaulkne Jan 25, 2009
    I can't find your comment on how to test the cartridges.
  • megenfaulkne Jan 26, 2009
    Three were definitely bad, so I replaced them all. Still getting the same green light, 7 orange lights, and green light.
    If there's a way to get the print heads clean other than the deep clean cycle, I'll give it a try. I did do the deep clean cycle a few times the other day before I started using it since it'd been a while since the last time the printer had been used. I guess it's worth a try if there is another way.
    Not really, but I don't have the greatest eyesight/light in the room to really see with. If you know what solvent I can use, I'll definitely try it.
    Doesn't really look bad to me.
    I was afraid of that. Well, thanks for your help.
  • megenfaulkne Feb 05, 2009
    Nothing worked. I went & dug my old printer out of the basement & got it working. Thanks for trying so hard though.
    President:
  • 1,214 Answers
Megan,
Check my last comment to you to test the cartridges.
I've got to run for a night out, but will be back on later, or in the morning. We;ll get this working for you for your class.
Posted on Jan 24, 2009
  • 5 more comments
  • Mark Egan Jan 25, 2009
    Take the cartridges out of the printer.
    Using a folded paper towel, place one of the cartridges into the paper towel print head end int the paper towel. Hold both tightly with the print end pointing downward, and swing down real hard. Check what the ink pattern looks like on the paper towel.
    Do the same for all the cartridges.
    The pattern of ink left on the paper towel should be the same for each catridge. If not, try the test a few more times with the cartridge that's missing a good pattern. That cartidge is the one that needs' to be replaced, and if one needs to be, they probably all need to be, with new, fresh cartridges.
    Let me know what you find.
  • Mark Egan Jan 26, 2009
    OK. You probably need to do a reset on the printer.Let me look at the manual, and I'll get back to you shortly.
    This may not be good news. I am going to guess you don't use this printer often, and not only have the print cartridges dried up, but ink has dried up in the print head.
    You can try to do a deep clean per the instructions in the manual, but there are no guarantees that this will fix the problem.
    I would email the file you need to print to a friend and have them print, try the deep clean cycle a few times, or, go get a new printer.
    There may be a way to get the print heads clean other than the deep clean cycle, but I am trying to get info to you in order to meet your deadline. Let me know how you want to proceed, and I'll give you more direction.
    I'll see if I can find more info on this unit to see how difficult it will be to manually clean.
    Deep cleaning may just make things worse if you've already tried it.
    Is it possible that when you take the cartridges out, that you can see a buildup of ink down in the bottom of the carrier where the cartridge supplies ink to the print head? If so, I'll see if I can determine what type of solvent will cut the ink, and you can use a that and a cue tip to cut and clean the old dried ink out of that area.
    Get a flashlight or move a lamp over to look down inside. You'll need to do this anyway if we find a way to solvent clean the head.
    It looks to me like your best bet is to replace the print head. I found several places online where you can order it.
    The Canon P/N for the head is QY6-0043-000
  • Mark Egan Feb 04, 2009
    Megan,
    Did you get this going? Sure would appreciate a rating, and if you could make it a FixYa, I would most appreciate it.
    But even more importantly, did you get it going?
After working for years, my HP All-in-One Printer stopped printing jobs suddenly, giving me an "incompatible black ink cartridge" message on the computer & an error light on the printer;...
sometimes they just defect and burn out.. place and old/empty/dry one if you have, if the error disappear you now that your cartridge just failed and you need new one.
Sep 20, 2011 | HP PSC 1315 All-In-One InkJet Printer
Overflow ink reservoir in canon i950 printer is full so it won't print
Dear jhurst, see a small door at the back of the printer. (in some printer it is in bellow) which is screwed. Unscrew it. There is a small pipe, which always filled with waste ink. clean it. start the printer, it will work.
Sep 01, 2011 | Canon i950 InkJet Photo Printer
Print nozzles must be blocked. Have to deep clean
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 16, 2010 | Canon i950 InkJet Photo Printer
Poor qualiyt text
Don
Feb 15, 2010 | Dell 926 All-In-One InkJet Printer
Printer cartridge problem ( Printer HP officejet 5610 All-in-One)
you need to replace color cartridge
or refill an old one if you have one
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Dec 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Poor print quality and I don't think it's the ink cartridge
TRY TO ADJUST THE MANAGE COLOR LOCATING ON YOUR COMPUTER FIND IT AND ADJUST THE DARK COLOR
Dec 02, 2009 | HP PSC 1410 All-In-One InkJet Printer
Purchased a Canon i950 for years ago... printing beautifully... did not use for the last two months and now has just stopped printing... reinstalled driver, still same problem - does not print a test page...
Check if the printer status is ready under Control Panel- Printers.
Make sure that correct port is used (Printer properties- Ports tab).
Also, check if the printer is online. Control Panel-Right click printer and choose Use Printer Online.
Hope this helps.
Jul 30, 2009 | Canon i950 InkJet Photo Printer
Mfc not used for 3 years. seems be printing but no ink comes on paper
It is my belief that ink has dried in the all-in-one printer ports.
Ink flows through minuscule, little ports, (Holes), in the ink cartridge.
These are covered by metallic foil tape when you get a new ink cartridge, that you are instructed to remove, before installing.
On the all-in-one printer, it has matching holes. When the ink cartridge is installed, it's holes line up with those holes. I think ink has dried in these holes, on the printer.
It would be my suggestion to clean these holes. It's not hard, you use a warm water, damp clean cloth.
-> Printer Unplugged from power
Open the printer to remove the ink cartridges. It is at this point, that I would advise donning a pair of rubber gloves. (Dish washing?)
Helps to keep the ink off of your hands, and fingers, just in case.
(The ink cartridges are open now)
Remove the ink cartridges. Soak a clean, lint free cloth, in as warm a water as you can stand. The warm water helps to dissolve old dried ink. Wring the cloth out until it is damp, NO drips.
You should be able to judge where the holes are in the printer body, by the area on the ink cartridge. Wipe in one direction, on this hole area. (The holes are so tiny, that you won't really be able to see them. {Or maybe I need better glasses! lol!}
Wipe what you think is the area. Looking at the ink cartridge, and where you removed the tape from the cartridge, you'll have a pretty good idea.
Once you wipe across, and pick up ink, I suggest using a different clean area of the cloth, and do it again. I would do this procedure, until there is very little, or none, picked up by the cloth. (Ink)
Once you are satisfied that this area is cleaned, I would use a hair dryer to speed up drying. You don't want this area to be wet, when you reinstall the ink cartridges. Hair dryer on low, keep it constantly moving back and forth.
When you are satisfied it is dry, reinstall the ink cartridges. Close the printer case. Plug it back into power. (Hands dry, no gloves. Not trying to insult your intelligence)
Turn the printer on. Wait until it resets itself. I would now go to the Diagnostic section, and do diagnostics. Then align the heads, and print a test.
May 22, 2009 | Brother MFC-5840CN All-In-One InkJet...
Pictures look fuzzy and not sharp when i print them . Does my printer need cleaned? Or is it time for a new printer. Mine is about 8 years old.
Try to replace a new cartridge for your printer...I think your printer is working properly...
if the phenomenon still exist..
its better to flash it with a new firmware.
maybe the signal that the printer sent to the cartridge is not enough...^_^
May 13, 2009 | HP DeskJet F380 All-In-One Printer
Canon i950 InkJet Photo Printer Logo
270 people viewed this question
old marine
old marine
