Question about Activision Mysteryville 2 for PC
Mysteryville 2 will not let me select the gems to match them
I'm on leave 17-3 task. When I try to select the gems to match them it does not let me when I tap it. I tap one gem then the other and it does not work.
I have a 17" Gem
You shouldn't need to install software for a monitor to work. What you may have to do though, is configure your display settings to allow an external display. Your laptop might have a function key to do this. Try clicking the function key + the key that looks like a monitor display on your laptops keyboard. This should activate the external display port. You might also try going into the control panel, select display and enable the secondary display. Also a 17 inch display probably has a screen resolution of 1024x768 or 1280x1024 so make sure you don't set the resolution any higher then that or the display might not show anything.
Chris
May 20, 2011 | 3G Technology GEM GL-822A/B 17" Flat Panel...
Tip
How to create a daily enhanced Disk Cleanup task in Windows 7
So you want your Windows 7 Operating System to perform a daily enhanced Disk Cleanup? Well, so do I. So lets get this party started.
Step 1. Click on Start and then click Control Panel.
Step 2. In Control Panel change the View to Small Icons.
Step 3. Now click on Administrative Tools.
Step 4. Now double-click on Task Scheduler.
Step 5. On the right hand side of the Task Scheduler window, click on Create Task.
Step 6. In the Name field, you can type "I love crickets", but to make our task easier to find and manage, I would suggest you label it for what it is, ie., Daily Enhanced Disk Cleanup.
Step 7. In the Security Options area, you are asked to use the default account, which is the account you are currently logged in with. If your account is not an Administrator account you will not be able to create this task. Also, if your account does not have a password, you will not be able to run this account.
Step 8. We want to run this task while we are not actively using this machine, so let's select the "Run whether user is logged on or not" radio button.
Step 9. Leave the "Do not store password" checkbox unchecked.
Step 10. Select the "Run with highest priveledges" checkbox.
Step 11. Leave the Hidden box unchecked as well. We wouldn't want to make it harder for us to find the task if we have to edit it.
Step 12. Click on the Triggers tab.
Step 13. Click the New button.
Step 14. For Begin the task. select "On a Schedule".
Step 15. Select Daily to Recur every 1 days.
Step 16. Change the Start time to 2:00 AM
Step 17. Now check the Enabled checkbox then hit OK.
Step 18. Click on the Actions Tab.
Step 19. Click the New button.
Step 20. In the action dropdown menu, select "Start a program".
Step 21. In Program/script, type C:\Windows\System32\cleanmgr.exe
Step 22. For Add Arguments, type in /sagerun:1
(Please note: To utilize the /sagerun:1 argument, you must follow the steps outlined in my previous article located here.)
Step 23. Hit OK.
Step 24. Click on the Conditions tab.
Step 25. Select the "Wake this computer to run this task" checkbox.
Step 26. Hit OK to close the Create Task UI. You will be prompted for your password or the password you used to create the task.
Step 27. Now test your task.
Step 28. In the task Scheduler UI, click in Task Scheduler Library in the top left hand corner.
Step 29. Right-click on the task you just created and hit run. Your task should run silently in the background. After a few moments, you can click on the History tab and check the status of the task as it stands right now. You will either see running or completed successfully.
Though this task was built using Windows 7, the same steps apply to Windows Vista.
on May 01, 2010 | Computers & Internet
Jeopardy does not record my name and score so I cannot continue to a higher level. I have reinstalled. When leaving the game I have to use control alt delete. How does this work?
It may not be saving due to the fact that you are closing it through task manager. Try looking for a better way to close the program without ending the task. That may fix it. If not, I'd say just use the Window Key + D to go to your desktop and try closing it by right clicking on the task in the taskbar and selecting close.
May 03, 2011 | Sony Jeopardy for PC (60017)
Ok I have tryed to buy gems 3 times over the last 2 day but it will not work I dont get the gems and my credit card keeps being billed a $2 charge for every time What do I do
I suggest going onto the developers site via iTunes and try finding a 'contact us' button and tell them your problem, you have the evidence that you're getting charged because of your bill statement.
Apr 19, 2011 | TeamLava Farm Story
I am looking for a power plug for my gem monitor #LCAO1F D3350382G
On eBay or Google Product Search or Amazon, search
GEM GL-822 power
or
GEM GL-822 12V 5A
There are a number available there. It is 12V DC, 5A
Apr 19, 2011 | 3G Technology GEM GL-822A/B 17" Flat Panel...
Need directions for game Princess Friends Forever
Disney Princess friends forever Game
2 to 4 players ages 5 and up
Goal: Collect the most Friend Gems as you and your Princess Friends Forever (PFFs) journey along the enchanted path to the castle
Contents:
1 board; 1 double spinner; 1 castle; 4 Princess movers; 14 Friend or Foe cards; 60 Friend Gems; 4 Gem Boxes
Set up:
Open the gameboard. Pick a princess, sit next to her corner, put her matching Gem Box in front of you and her matching Princess marker on the START space. All players do the same. Cinerella's color = blue, Belle's color = yellow, Ariel's color = green, Tiana's color = purple.
Place the castle in the center. Place the Friend Gems in the top of the castle. Shuffle the Friend or Foe cards and place the deck facedown on the playing area.
Play:
Youngest player goes first. On your turn, spin the spinner. The spinner's outer circle tells you how many spaces to move your Princess ahead on the path.
Collect a Friend Gem - any time you land on a space occupied by another player's mover, celebrate being PFFs by each collecting a Friend Gem from the castle! Put all the gems you collect in your Gem Box.
Note: Never peek at the color gem before choosing. Just reach in with eyes closed and pull out the first gem you touch.
Friend gem Spaces - If you land on a Gem Space (one large red heart), spin the spinner and watch the short end of the spinner arrow. The princess the spinner lands on is your new PFF! Your PFF moves her mover to join you on your space. Take a Friend Gem from the castle and give it to your new PFF and take another for yourself. If the spinner pints to a princess not being played, then only you will collect a Friend Gem. If the spinner points to your Princess, collect two Friend Gems.
Note: If another player is already on the Gem Space when you land on it, you each collect a Friend Gem before spinning the spinner and following the rules above.
Friend of Foe Space - If you land on a Friend or Foe space (Castle picture with words friend or foe), draw a card from the deck. A card picturing a Friend (a helpful character from a Disney Princess movie) will move you forward. Foes (evil characters from a Disney Princess movie) will cause you to lose gems.
Friend: If the card shows a Friend plus a number, move forward on the path the number of spaces shown. Then follow the directions for the space you land on.
Foe: If the card shows a Foe minus a number, give that number of Friend Gems in your Gem Box to any player or split them between several players. You can spin the spinner to help you choose. Note: You may not give a gem to yourself.
Trade Gems Space - If you land on a Trade Gem space (picture of 4 heart gems) this is a chance to trade with another player to get a gem of your own Princess color. If you land on one of these spaces, choose a player to trade with. You must each have at least one gem in your Gem Box to do so. Then do the switch. Give her one from your box that matches her Princess' color; she in turn gives you one that matches your color. If one of you doesn't have a matching gem, that's ok, a non-matching gem can be traded.
Winning the game - When a player reaches the FINISH space the game is over. This player gets three Friend Gems for reaching the castle first. Everyone counts their Friend Gems. Whoever has the most is the first place winner! Remaining players then count their gems that match their Princess color. Whoever has the most is the second place winner!
Feb 12, 2011 | Disney Toys
My moms 1998 Ford Taurus's battery dies with the cables normally connected. If you take one of the cables off the battery, it works fine. You just need to reconnect before you start the engine. We were...
It sounds like something is drawing power with the key off. It could be the GEM module but I doubt it. There is a draw somewhere. Connect battery and pull fuses one at a time to see if curent drain stops. You will need an ampmeter in series with the battery and the postive cable. Expensive. Get one from pick n pull salvage yard real cheap.
  • Check the following fuse junction panel fuses: fuse 23 (5A), fuse 20 (5A), and fuse 8 (5A).
  • Section 13-09A: Gauges/Warning Devices, Chime/Buzzer System 1998 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 03/16/1998
    Generic Electronic Module (GEM) Removal
    The generic electronic module (GEM) is connected to the rear of the fuse junction panel (14A067) .
    1. Disconnect battery ground cable (14301) . Refer to Section 14-01.
    1. Remove two nuts retaining fuse junction panel to dash panel (01610) .
    1. Pull upper ears of fuse junction panel down out of retaining bracket.
    1. Disengage locking tangs and disconnect three harness connectors from bottom of GEM.
    1. Turn fuse junction panel over and remove screw retaining GEM to fuse junction panel .
    1. Disconnect and remove GEM from fuse junction panel .
    Installation
    1. Follow removal procedure in reverse order.
    1. Tighten GEM to fuse junction panel screw to 1-2 Nm (9-17 lb-in).
    1. Tighten fuse junction panel retaining nuts to 4-6 Nm (36-53 lb-in).
      Item Part Number Description 1 14B205 Generic Electronic Module (GEM) 2 - Mounting Ear (Part of 14A067) 3 14A067 Fuse Junction Panel 4 - Screw (Part of 14A067) 5 - Generic Electronic Module (GEM) to Fuse Junction Panel Connector A - Tighten to 1-2 Nm (9-17 Lb-In)
    Dec 17, 2010 | Ford Taurus Cars & Trucks
    Installed windows 7 on a dell sx260 with gem 17 lcd cant get display drivers to work?screen all dis colored
    Try going to the Dell or Microsoft Websites and loading a new display driver for Windows 7. When I first got Windows 7, both my monitor and printers required new drivers for Windows 7. It seems that Vista and XP drivers for a lot of things don't work on Win 7.
    Good Luck
    Dec 08, 2010 | Scanport GEM GL-821A/B 17" Flat Panel LCD...
    I have a GEM 17" with power issues!
    Sounds like your power supply capacitors are causing the power supply to shut down. Or you have a short in the monitor loading the power supply. You should try a different power supply.
    Monitor Mike
    Apr 24, 2010 | Scanport GEM GL-821A/B 17" Flat Panel LCD...
    Gem Amplifier and cordless mics
    If the wireless mic has an XLR output that matched the corded mic input, the answer to your question is yes.
    Dan
    Jun 15, 2008 | Gem Sound Audio Players & Recorders
    Activision Mysteryville 2 for PC  Logo
    22 people viewed this question
    Top Activision Computers & Internet Experts
    k24674
    Bapco
    Are you an Activision Computer and Internet Expert? Answer questions, earn points and help others
