Question about Briel Multi-Pro ES-200A Espresso Machine
Is it possible to get replacement coffee grind holders
I have lost the 2 metal baskets(each a slightly different size) that hold the coffee grinds. Can I get hold of replacements. Hope you can help. Thank you.
  • 3 Answers
To purchase Briel replacement parts in US contact Electra Craft at Phone (201) 439-1700, e-mail:
Posted on May 20, 2009
Cuisinart grind & brew - spring in the filter area popped out. not sure where it goes?
Yes, you place the spring into the tube at the back. When you replace the basket holder, make certain you reach in behind the holder and guide the spring into the proper place on the holder. (Otherwise the spring will be forced to a permanent bend and not work as well. Can't find replacements for this spring on Cuisinart's website).
As for why it pops out better now, when you removed the basket holder and cleaned it, you also cleaned the plastic guides on each side. In normal use, these guides acculuminate coffee and tend to get sticky or gummy. When the door pops open, the sticky rails grab the guides and slow the sliding action.
Cleaning them restores the clean guide rails to slide open on. (Next time you clean the basket holder, remember to reach in and wipe out all the inner parts, including the plastic rails that the basket holder slides out on. These get coated with coffee as well. And the place around where the grind basket fits over the ground basket. This area always gets sticky with old coffee. Just use a wet paper towel and clean everything. (But remember to be careful when you reinstall the basket holder so that the spring fits back properly.
Dec 04, 2017 | Cuisinart Grind and Brew 10 Cup Coffee...
Grinder appears to be grinding, but not ground coffee ends up in the basket. Metal door underneath the grinder is closed.
Empty grinder and chek nothing is stucking to the opening plate If not then replace the solenoid that open the shuter from where the coffee go to grinding chamber Thanks Please rate my work
Sep 06, 2011 | Microwave Ovens
With the BES860 set to Dual Wall for full automation, even on the lowest auto grind volume setting, the grind volume is too large and it spills over. This is on double setting and using the double filter...
If your using the dial gauge with a dual wall basket, you need to leave the dial in the dual wall setting. If you move it beyond the dual wall setting, you are basically adding more volume to the basket. Leave it in the dual wall setting for dual wall baskets.
Otherwise it may be faulty, it could be your grind setting, try it on 13 and see how it goes.
May 07, 2011 | Breville Fresca BES860 2Cup Coffee Maker
I have a grind and brew and can't get the grinding basket out to wash.
Open the reservoir lid. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use.
Sep 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DGB-700BC grinds but no grounds in the basket.
Hi there, you have some kind of blockage, If the beans are going down, you need to remove the brewer unit and wash it, if the beans arent going down the exit of the grinder is blocked and needs to be removed, cleaned and replaced
Jul 26, 2009 | Cuisinart DCC-1200 Coffee Maker
My single cup portofilter on my ECM Giotto suddendly is pouring more coffee then it should. I'm using the same grind I've been using forever. My other portofilter (2 cup) works fine and still produces the...
How old is the coffee being used? Normally if you change baskets, the grind should be the same, because the single basket has finer and less holes in it than the double basket. The only difference would be the tamp then, since the coffee grinds works great with the double basket. You would also have to use a different volume of water to produce the coffee. To produce 2 ounces of espresso you need about 3 ozs of water,(about an ounces of water will remain in the coffee).
Jul 19, 2009 | ECM Giotto Espresso Machine
Rancilio Silva - coffee lost its punch
Try backwashing the group with purocaff.
Are you using coffee ground at the store or do you grind just before use?
How fresh is the coffee less than a month or more?
If more than a month(whole beans) it is no longer useful.
If more than a 3 days(ground), that is stale also. It will be very diffucult to get good espresso from that(not impossible, but difficult).
If using store ground, it cannot be ground older than a week(coffee loses flavor and taste minutes after being ground). Try getting less coffee more often and adjust the grind setting that you use. If you have always used setting 3 on the store grinder try 2.5.
If grinding at home adjust the settings on the grinder to a slightly coarser grind and fill the portafilter slightly over the top of the basket, now tamp to the indent(fill line) in the basket. that should be sufficient to pull a great shot.
May 17, 2009 | Rancilio Silvia Espresso Machine
Just bought machine. Filter holder is different from one described in booklet. It talks about the filter holder has been replaced by a spring systems that holds the filter in place. I got the big...
hi m.fleshman! in answer to your question, i paid $25 for mine's like a $25 paperweight. hold the coffee grinds basket up to a light-can you see light thru just one hole, or all of the holes? if just one, this passed quality control at the factory & shouldn't have passed. i imagine that details like this are rampant on this machine. if i had bought mine at the store instead of 2nd hand, i'd take it back for a full refund! otherwise, it may be that someone put the wrong filter in the package. it's also possible that you may need to take out the spring (if it's removable) from the bottom of the filter holder-i don't know b/c i bought mine used. hope this helps!
Sep 12, 2008 | Breville ESP8XL Espresso Machine
Delonghi Espresso Maker Issue
check the water temp and make sure the grind is not to fine. if both of these checkout ok then it may be a weak pump. you will have to find a replacement pump.
Mar 06, 2008 | DeLonghi EC140 Espresso Machine
Everything sounds like its working...but nothing.
It sounds like your filter is clogged.  This can be tricky to unclog, but use the pin that came with the machine.  I have had the most success when I use the pin and try to run H20 (no coffee) through the filter basket.  Sometimes takes several tries, but eventually blows out the clog.
Sep 14, 2007 | Breville Die Cast 800ESXL Espresso Machine
Briel Multi-Pro ES-200A Espresso Machine Logo
197 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
