Question about Intel Motherboard
NO SIGNAL TO MONITOR
NO SIGNAL I TRIED TO RESET CMOS . I TRIED MONITOR BEFORE ON THE SAME PC AND IT WORKED LIKE A WEEK AGO .MY VIDEO CARD IS LIKE 1 YEAR OLD . ALL MY FANS RUN . THE HARD DRIVE RUNS . EVERY THING ON THE PC RUNS BUT NO SIGNAL EVERY TIME
  • 105 Answers
Change the memory card, then reset the cmos. if problem persists change the video card, its probably bad.
Posted on Sep 19, 2009
Monitor turns on but there is no signal. Everything is connected
only thing u can try is maybe somehow monitor and pc are on diff settings take out cmos battery reset bios otherwise video card if u have one is dead or monitor one or other
Feb 26, 2017 | Computers & Internet
HP w2207 no vga input signal, no dvi input signal monitor goes to sleep
There is no signal coming from your PC.
excuse some of the solutions as sounding dumb, but we have to explore all possibilities.
Check the power cable going into the computer
Check the power input disconnect switch on the back of the power supply and make sure it is on
If the pc is plugged into a power bar, make sure it is turned on and the breaker isn't tripped
press power on the PC and make sure the lights are coming on.
now for the solutions that may actually help.
disconnect the power from the PC
if the video is on a card, remove and re-seat the video card
hook the power back up, connect the monitor and try again.
the CMOS on the computer may need to be reset.
I hate totally clearing the CMOS, so what I usually do is remove 1 stick of ram and power up. If the system is alive again, power down, put the RAM back in and power back up.
If that doesn't work, turn the system off, put the CMOS jumper to the CLEAR position for 15 seconds, put it back to the Normal position and then power back up.
Basically, if the monitor works on your friends system but not on yours, the the problem is your system, not the monitor (assuming it isn't working fine til it gets into windows...if that's the problem, you have a driver or configuration problem)
Jun 10, 2012 | HP Computers & Internet
Hi - I have a shuttle xpc sxh57 core i7 model. A couple of days ago - it stopped sending a dvi signal to the monitors. I have replaced the video card, tried clearing the CMOS and cleaned dust. The fans and...
I suggest try the HDMI connection on your machine and see if its able to give display, since you purchase a new Video Card I assume it have a HDMI port. Or try different monitor with a DVI port if you really want a DVI connection, If it works it means the DVI port on your monitor is faulty.
Hope it helps.
Apr 20, 2011 | Shuttle Computers & Internet
My wife went to work on the computer- then screen would not turn on. The power light was yellow. We unplugged and replugged in the monitor with no help. I finally did a hard reset of the PC and the monitor...
Yoy see the yellow power light because it is not seeing the video signal from your PC's video card, so that can be the possible cause since you reboot the computer and you get the signal back. Your computer may need to be looked at, try reseating the video card if it is not integrated into the mother board, reset the RAM, check to see if it has any caps with bulging tops in the mother board.
Jan 01, 2011 | Microsoft HannsG HU171D 17" LCD Monitor
When I turn on computer the monitor starts up briefly, then statement on screen says "no input signal" and monitor goes into sleep mode? I took it to Staples and they say I have bad motherboard....it's...
First, you should try the monitor on another PC to see if it works.
Then if there is still a signal error, try opening your PC case, blowing out any dust you find with compressed air, then re-seat your ram and video card. If you have on-board video, try removing the cmos (Bios) Battery or if you can find it, jump the bios reset jumper, then restart.
If none of those solutions work for you, try installing a slot based video card in either your, PCI, AGP or PCI Expess slot to see if your onboard video has simply failed.
Apr 08, 2010 | HP (D7580-60003) Motherboard
No monitor signal
make sure pc is off ,make sure video card is seated properly if it is try resetting cmos there is 3-pin jumper ususlly by battery and usually says reset cmos by it I have seen many differences according to mobo this can also be accomplished by taking out the mobo battery (the little round silver battery) if you have jumper take off 2 pins its on know put on other 2 for 1min then put back turn on, if removing battery take out then turn on pc
May 16, 2009 | Computers & Internet
No video output
I'm glad resetting the CMOS fixed it. (Posted as solution so you can rate the response.)
Mar 22, 2009 | EliteGroup NFORCE 570 SLIT-A Motherboard
No video, monitor and video card are good
There 3 possible problem with your board...
1. Processor
2. Ram
3. Bios
Check one by one
Nov 25, 2008 | Soyo SY-KT333 DRAGON Ultra Motherboard
Intel Motherboard Logo
202 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
