Question about Juki DDL8300N Sewing Machine
Juki DDL-8300N upper thread keeps breaking
The upper thread keeps breaking when I try to sew.
SOURCE: question==>JUKI dnu 1541 or ddl 8300n
Might I be so bold as to disagree with Allmakes.
Why would a manufacturer build different models of industrial. They are designed for differnt jobs. The 8300 is a high speed garment machine, the 1541 is a compund feed upholstery machine. The motor is the same HP and does not affect the ability to sew heavy. The garment machine will sew garment weight leather just fine but you will have problems getting the fabric to feed properly particularly over seams. The other issure you may find with a garment machine is it's ability to handle heavier threads. I suggest that the 1541 would be a better choice for making bags and purses.
Posted on Feb 19, 2008
yalmer
  • 549 Answers
SOURCE: threading a juki ddl 5530
Go to this link and you will find how to thread your machine.
Posted on Apr 02, 2008
  • 5 Answers
SOURCE: threading juki DDL-227 machine
There is a free download threading diagram for the DDL-227 here:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
Posted on Mar 23, 2009
Zenqi
  • 208 Answers
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
Posted on Jun 17, 2009
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
Posted on Aug 20, 2009
Juki 8300N
Dear Rosemarie,
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
Cheerup and Be Happy always
Mar 27, 2008 | Juki DDL-8300
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
Nov 21, 2016 | Juki Sewing Machines
I have a 2011 Juki DDL-8300N. Has always worked fine but while sewing on denim it suddenly seized up and stopped sewing. The needle is in the lowest postion through the jeans. I am unable to turn the
Your needle probably bent and got jammed. clip threads top and bottom of the fabric and remove... then get in the bobbin area and look for issues.
Sep 30, 2012 | Juki DDL-8300
My JUKI DDL-8300N has locked up on me can u help me fix it?
if its not mechanical the thread has bound up the hook. spray hook all over with oil and let sit for a day then use hand wheel to force hook to turn, u will not damage machine. gp back and forth.
Jun 11, 2011 | Juki DDL-8300
My thread is breaking when I'm sewing on my Juki DDL 555
MAKE SURE YOU HAVE THE RIGHT NEEDLE FOR THE THREAD YOU ARE USING, AND THAT THE SAME THREAD IS ALSO IN THE BOBBIN. CHECK UPPER TENSION, BY PULLING SLIGHTLY, IF IT'S TIGHT, LOOSEN THE UPPER TENSION.YOUR THREAD MAY BE THE WRONG SIZE OR TYPE FOR THE SPEED YOUR SEWING., and the needle your are using( sorry about the caps lock)
Oct 18, 2008 | Juki MO-644D Mechanical Sewing Machine
Question==>JUKI dnu 1541 or ddl 8300n
Jan 26, 2008 | Juki DNU-1541 Mechanical Sewing Machine
Juki DDL8300N Sewing Machine Logo
55 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
