Question about Krups Kitchen Appliances - Others
Broken knob tt619050 - Krups Kitchen Appliances - Others
How to replace the knob and stem on a frigidaire range?
Stem is part of control switch need to replace control .....
Knob is probably fine, just pull out shaft from knob use old knob on new switch as long as plastic knob is not broken
Aug 12, 2014 | Frigidaire Kitchen Ranges
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
Pressure regulator knob broken
Do you think the knob is broken because it is loose? It should be loose and move easily over the valve. If it is really broken, you should contact the customer service of the home shopping channel where you purchased it.
Feb 06, 2014 | Cook's Essentials CooksEssentials 3 Quart...
The knobs are broken and cannot be used I need
I went to an appliance store and they had them. Thanks.
Jan 06, 2010 | Whirlpool Timer Clock Knob
My timer knob is broken. How can I order only that part?
I would advise you to call Kitchenaid Customer Service. They would be able to send you a replacement timer knob at no cost. You may simply pull off the broken timer knob, and the new knob will snap in with ease.
Their toll free telephone number is 1800-541-6390.
Jun 16, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Knob broken
go to this site and you will be able to order a new knob.
http://www.repairclinic.com/0047_13.asp
Feb 11, 2009 | GE Kitchen Ranges
Broken knob
you can probably get a substitute knob from radio shack - replacement knobs. it may not have the markings you desire but at least you'll have a knob you can rotate.
Dec 25, 2007 | Crock Pots & Slow Cookers
Program selector know is broken
First thing i would do if it is not selecting a different cycle is take the knob off and check to if the inside of the knob is broken and hust turning on the shaft, other then that it proberly is electronic replacement.
Oct 27, 2007 | Miele Novotronic W1930 Top Load Washer
The timer knob broke - can't find replacement
Assuming it has broken on the shaft then you could pry the broken bit off the shaft and take the knob and broken piece to your domestic appliance parts stockist. The shafts are usually a standard size and there might be a similar knob that you could replace it with.
Oct 02, 2007 | Solis Maestro Electric Burr Grinder
Kitchen Appliances - Others Logo
42 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Henry  Thomas
Henry Thomas
Mike
ArcFlash
Level 1 Expert
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
