Question about Magic-Pak 64HWC4-09-301P 2.5 Ton 10.6 SEER Gas Heat Electric Cooling
How to clean a magic pak - Magic-Pak 64HWC4-09-301P 2.5 Ton 10.6 SEER Gas Heat Electric Cooling
The filter on our Magic-Pak is located right next to the condenser coil and comes into contact with the coil when the unit turns on. Is this a potential mold issue??
Everything about air conditioning is a potential mold issue. So yes, it is, but, that is where the filter is supposed to go. That is actually the evaporator coil that is being filtered, but, your filter should not be getting wet and if it is it's likely drying out before it becomes a problem. Monitor the filter, just be creative if need be to keep the filter off the coil, possibly spray coil with some gentle detergent and rinse with water to clean it and make the water run down it a little easier. Good Luck!
Jun 05, 2017 | Filter Heating & Cooling
When playing Mortal Kombat II second player keeps "popping" into game even though only one controller is hooked up?
Well try cleaning the game pack out with quips and rubbing alchoal it could just be dirty then or the worst case is that the game pack could have internal issues Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
Insert the Game Pak into the system. The Game Pak label should be facing the front of the machine (or facing up if you are using an original NES).
Make sure the Game Pak firmly clicks down into place.
Remove all accessories to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
Check the instruction manual for the game to see if it requires any special accessories to operate (such as the Super Scope, NES Zapper, SNES Mouse, etc.).
Do not blow into your Game Paks or systems. The moisture in your breath can corrode and contaminate the pin connectors.
Apr 20, 2013 | Nintendo Super NES Console
I have an old N64 and to play majora's mask it says i need an expansion pak so i ordered an expansion pak but when i replaced the jumper pak with the expansion pak the system still turns on but for some...
If your Nintendo 64 console operates without error when the jumper pak is installed, but fails to function when the expansion pak is installed, by process of elimination this most likely means that the expansion pak you purchased is defective.
However, prior to purchasing another expansion pak (or attempting to exchange/get refunded for it), make sure the contact points on both the pak and the console slot are free of any dust, dirt, or other contaminants. Use a lint-free, dry cloth to do this. Water and/or cleaning products can further damage the system.
If, after cleaning the contacts, it still fails to function, seek an exchange or refund.
Mar 03, 2011 | Nintendo 64 Console
I can't get any game to work. We used to be able to wiggle the game or take it out and put it into the console on a different angle, but now it won;t work at all. The power light still comes on on the...
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your game. Please check our game play help for assistance.
  1. Insert the Game Pak into the system. The Game Pak label should be facing the front of the Nintendo 64.
  2. Make sure the Game Pak firmly clicks down into place.
  3. Remove all accessories (with the exception of the N64 Expansion Pak) to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
  4. Check the instruction manual for the game to see if it requires any special accessories, such as the Expansion Pak, to operate.
  5. Check the list of specific game issues to see if there are any known problems for the game you are playing.
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product.
  • Controller Error Messages (e.g. No Controller Detected)
    1. Make sure you are using all licensed accessories with your system. Make sure both the controller is licensed and any accessories you are using with the controller (Rumble Pak, Controller Pak) are licensed as well. Unlicensed products may not be fully compatible with our systems.
    2. Slide the Power Switch on the control deck to the OFF position and unplug the controller. Plug the controller back in, making sure the controller-plug is firmly inserted into socket one (on the left front ofthe control deck). Slide the power switch on the control deck to the ON position.
    3. If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
  • Character Won't Move or Moves on its Own
    1. The most common cause of this problem is when the control stick on the controller is not in the neutral position when the N64 system is turned on. The neutral position is when the control stick is centered, as it is when you hold the controller while not touching the control stick. Recalibrate the Controller by using one of the following methods:
      • Turn the power off on the system. Make sure the control stick on the controller is in the neutral (center) position, and slide the power switch to the ON position. Be sure not to touch the control stick for the first few seconds.
      • During game play you can press the L+R+START simultaneously while the control stick on the controller is in a neutral (center) position.
    2. Consult the Game Pak manual for information on the primary directional control for the game. Some game paks use the control pad rather than the control stick for character movement.
    3. Try cleaning the controller (See Below).
    4. If possible, try another controller in the left-hand port. If you have a second Controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here..
  • N64 Sticky Buttons or Control Stick, or other controller problems Try the following cleaning procedures:
    1. Unplug the controller from the control deck.
    2. Get a clean toothbrush (no toothpaste) and a cup of warm tap water (not too hot). Do NOT pour or submerge the controller in any type of liquid.
    3. Slightly dip the toothbrush in the water (the toothbrush should not be dripping wet) and scrub the area of the controller around the buttons and control stick.
    4. Work the bristles down around the sides of the buttons and the control stick.
    5. After cleaning the controller, dry it off with a paper towel.
    6. Let the controller air dry for at least a couple of hours.
    7. Test the controller for proper response.
    If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 7. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
Transfer Pak
  1. Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
  2. Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
  3. Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
  4. Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
  5. Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
  6. Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
  7. If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
If the issue persists, the Transfer Pak may need to be replaced. For information on locating replacements for older products, please click here.
Controller Pak
  • Deleting Saved Information From Controller Paks Depending on the game you own, there are a couple of different ways to delete the saved information on a Controller Pak.
    1. While turning on the Control Deck, hold down the START button on Controller #1. If the programmers utilized this feature, a Controller Pak menu should appear. This menu will allow you to view and delete the contents of the Controller Pak.
    2. If the first option doesn't work, then the game pak will have a feature that can only be accessed from a game menu. For example, in Wayne Gretzky's 3D Hockey, you delete saved info from the Options screen.
    To find out the specifics of how the Controller Pak works with a particular game, check the game's instruction manual.
Expansion Pak
  • For assistance with installing the Expansion Pak, click here.
Jan 19, 2011 | Nintendo 64 Console
Nintendo 64 Transfer Pak...
Try cleaing the contacts on the games and the transfer pak itself, look up how to clean games on youtube.
Jan 27, 2009 | Nintendo 64 Console
Nintendo 64 Pokemon Stadium Transfer Pak Error
Its most likely the controller. When you put in the pack is it loose? You could try cleaning the GB game and trying again.
Jan 26, 2009 | Nintendo 64 Console
Nintendo DS game paks dont work
I think the internal baterry has run dry.It happend to me.So clean it out turn on and of power and it should work.
Jan 11, 2009 | Nintendo DS Lite Console
Cant play games on nintendo ds lite
I can tell you.You might have to clean the back metal strips on your Ds game or game Pak.Also the game pak's internal battery has runned dry.Use a cutip to clean inside (works on Ds games)Turn on and off the Ds muiltiples off times and it should have work.I tried it and it worked.
Dec 27, 2008 | Nintendo DS Lite Console
How to clean an Game Shark 3.2 pak and also an 3.3 pak?
A newer pack will be able to use cheats on it.
You can clean ALL your packs AND your game deck by diluting:
A cup of water
and a capful of Rubbing Alcohol
Mix them together, then rub the solution over the contacts of the carts and the game deck with a Q-Tip.
I did this, and I have not needed to blow into the cartridges yet, even though it's been a good 9 months since I've cleaned them.
Nov 29, 2008 | Acclaim Bust A Move 2 for Nintendo 64
Controller Pak Abnormality???
Sorry evilpacman, but you're wrong.
The N64 Controller Pak does indeed have SRAM as you state, but SRAM _does_ require a battery to retain its contents. The battery in question is a standard CR2032 or "coin-cell". The only gotcha is that it is a PCB mount variety, with the legs already attached to the battery casing. I'm currently looking for a replacement myself... farnell may have them but I need to check the footprint...
Jul 13, 2008 | Nintendo 64 Console
Magic-Pak 64HWC4-09-301P 2.5 Ton 10.6 SEER Gas Heat Electric Cooling Logo
50 people viewed this question
Top Magic-Pak Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Magic-Pak Heating and Cooling Expert? Answer questions, earn points and help others
