Question about Tascam 2488 Portastudio Multitrack Recorder System
Problem importing files to Tascam DP02-cf
I have tried to import a variety of wav files into my dp-02cf, but the only ones it will show on the lcd display are the ones imported which were created on the unit itself. I have made sure all the others I have tried to import are mono, 44.1khz, 16bit wav. files. They show up in the wave file on the fat partition when viewed on my p.c., but not on the DP-02cf's display.
They don't mention in the manual that in addition to being 44.4khz, 16bit, mono, the wav file also has to be at a bit rate of 705kbps. Using Audacity (freeware) you can convert most any audio file into the necessary wav format for the DP-02cf to use.
Posted on Jan 25, 2009
DP-02CF Exports files to PC, but reads no file found when importing wav.
The answer is in the troubleshooting section of the manual:
http://tascam.com/content/downloads/products/241/E_DP-02&02CF_web.pdf
Page 53:
"Why can't my computer "see" the unit files"
Mar 01, 2011 | Tascam Dp-02cf Digital 8-track Recorder
From iTunes, I have converted the m4a track to WAV and then copied that over to my Tascam DP-02CF via the USB connection. When I go to import the track it says "Import file not found". What am I doing...
Your wave file is probably in stereo and you need to change it to mono. I use the free Audacity program to do this.
Once you have uploaded your wave file into audacity on the left side click on the down arrow which will bring up several options, click on the 'split stereo track' option. Then delete one of the tracks. You can then export the file as a wav file, you might want to rename with mono in your name so you don't write it over your previous stereo file. You can then import the file into your DP-02
Feb 14, 2010 | Tascam Dp-02cf Digital 8-track Recorder
What do I do when importing wave files from my computer and then it says "IMPORT FILE NOT FOUND"? What do I do next?
Just got mine to work today. First of all, you must have a mono WAV file. I used AVS Audio Converter 6.1 to convert my stereo WAV file to mono. I used the PCM codec, Channels set to 1/0 - mono, and the bit rate automatically was set to 705 kbps. No other format would work for me. I figured it out by exporting a file to see what its specs were. The bitrate must be 705 (which is half of the normal stereo 1411 kbps). Hope this helps anyone else with a DP-02.
Feb 12, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Poor Recording Level on the Tascam DP-02CF
When I record on DP-02/CF Tascam I can't get the music to play back. Do I have to do something other than rewind to be able to hear it? Albert S.
Feb 08, 2009 | Tascam 2488 Portastudio Multitrack...
Dp-o2 wont Import wav files from my pc
For wav files to be imported to the DP2 have to be 'mono' wav files. The DP-02 won't even show stereo waves in the fat area. So make sure you are converting any stereo wav files into mono first. That's usually the problem. They should also be 44.1 khz sampling frequency and 16 bit (I believe the DP-02 will accept a 24-bit wav, but the file will be truncated rather than dithered down to 16 bit while importing which may not be ideal for quality).
Hope this helps,
bd.
Jan 26, 2009 | Tascam 2488 Portastudio Multitrack...
Load imported songs on tascam dp02 cf
Make sure you have the song loaded first. In this case it sounds like you are importing into a new song, so make sure that you have a new song created and loaded prior to importing.
Then go to the menu by pressing the 'MENU' sutton and from there select 'WAVE' and then 'IMPORT TRACK'. You'll see the list of wav files on the fat partition of the CF media displayed. Select the wav file with your beat track on it (use the DATA DIAL or up/down arrow buttons to highlight the right wav file) and press the 'YES/ENTER' button. You'll be prompted for the track to import into. Select Track01 and press the 'Yes/Enter' button again and the WAV file will be read and inported into track 1.
Please note that the wav file should be a 44.1 kHz, 16-bit and a mono wav before trying to import it. If the beat track was created as a stereo wav you'll have to go into a wav editor like Audacity and resave the file as a mono wav file first. Also for a wav with a bit rate higher than 16-bit, the DP-02 is going to truncate the bits rather than dither and this might effect quality adversly so you might want to make sure that the file is properly saved as 16-bit prior to attempting an import to avoid this.
Hope this helps.
bd.
Jan 10, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam DP-02CF: How to transfer files to my computer?
You can't see the fat partition from within the DP-02. It's there, but only your PC will be able to read the contents of the fat partition when you have the USB 'opened' on the DP-02. The manual states that if your CF card is less than 5 Gb in size than you will only see/be able to select one partition. The default CF card that comes with the DP-02CF is only 1 Gb.
If you've created a backup or exported your wav files properly and everything is working ok with the CF, then you should be able to see backup or wav files showing up in the fat partition while connected to the PC. Even if nothing is backed up or exported you should still see the directory structure from your PC with the three folders, BACKUP, WAVE and UTILITY. As you are not even seeing these directories, what may have happened is that the fat partition had become corrupted or these folders had gotten erased.
I would have thought that reformatting the FAT partition would have fixed this problem however and that the DP02-CF would automatically recreate the required directories on the CF media after a reformat. The manual is unclear on this however.
So a couple of things you could try:
1. You describe opening the USB connection as 'push the USB button and then hit enter'. I was assuming you meant that you were selecting 'usb' from the menu and then pressing the 'enter' button to open the usb connection. You may wish to verify that the usb connection is being opened properly first.
2. If the connection is opening ok, and after a reformat you still aren't seeing any folders in the fat partition while connected to your PC with the usb open, you might wish to try to recreating those directories in the FAT partition yourself. While accessing the FAT partition (DP-02CF's removable drive) from the PC create the three directories exactly as named in the manual (WAVE, BACKUP, UTILITY). If that works, disconnect from the PC, try exporting a track or backing up a song again, and reconnect to the PC to see if you can see/access those files now.
Best of luck.
bd.
Jan 02, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam DP-02 cd player...
You cannot rip a CD directly into the DP-02 using the unit's CD drive.
Your choices for doing what you want are:
1.) Rip the CD into .wav files onto your PC using ripper of your choice. Then you'll have to edit the resulting .wav file using a program like 'Audacity' (which is a free one) and convert the stereo wav files into 2 mono wav files. You'll have to save the mono files with dos 8.3 filenames and then import them into the DP02 using the instructions for importing wav files in the manual. To preserve the stereo, import each mono wav file to a separate adjacent track on the DP02 and then pan one left and one right.
2.) You could play the CD on a stereo and connect the stereo outs to the two inputs on the DP02 to record the CD track. You'll need patch cords which are RCA (mini phono 1/8" jack) to regular phono (1/4") to do this.
Cheers,
bd.
Nov 09, 2008 | Tascam DP01 All-In-One Recording Package...
Can't import song from PC to DP-02 Unit and the Manual STINKS!!!!!
You shouldn't have to do any formatting. If you copied a wav file onto the DP-02 while connected with the USB and with the USB connection open, then you were already accessing the fat partition. One thing to be aware of is that the DP-02 only works with mono wav files. So if the wav file from you PC is being saved as a stereo wav (which is the default for most programs) then you'll have to specify mono instead. The DP-02 only works in 16 bit as well so on your PC you should be saving and wav files you wish to import as 16 bit, 44.lkHz mono wav files). That should be about it.
Hope this helps.
bd.
Sep 30, 2008 | Tascam 2488 Portastudio Multitrack...
Failure to read WAVE file when trying to import a track.
Wav files need to be in mono to be imported into the dp-01. Fruity Loops and a most other programs by default save wav files in stereo. You'll need to save the files again as mono wav files before attempting to import them into the dp-01.
Cheers.
bd.
Jul 16, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam 2488 Portastudio Multitrack Recorder System Logo
688 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
