Question about Electrical Supplies
New VARIMAX digital
I have a new varimax 75lb thrust digital trolling motor that I purchased Nov 2012 with maybe 20 hours total on it that has already had control board replaced because they said I shouldn't hook up big foot pedal. Got it back and now after a couple of hours of running at low speed it starts to act up when I turn it up to full power. Starts clicking and the power meter starts jumping up and down and I don't get full power at all.
  • chobeegators
    chobeegators Jan 25, 2013
    I tested it without the circuit breaker today and still the same results. Is it possible that once the batteries start to loose power this could happen?
2 Suggested Answers
SOURCE: new MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
Posted on Jul 15, 2009
My bow mount 43lb thrust foot controlled trolling motor is only working in one speed. It must be in rapid speed be cause the motor only works with selector switch on the rabbit and not on troll.
needs to go to a repair shop for a new resistor unit in the motor .or one of the wires going thru the shaft has broken .they fail dueto the constant flex from turning
Dec 16, 2015 | Boating
How should a 12 volt deep cycle battery last when trolling on #1 with a 30 lb thrust
It depends on the Amp/Hour rating of the battery and the amount of current your motor draws on setting 1.
Apr 17, 2012 | Minn Kota Endura 30 Freshwater Transom...
I need to replace the bearings in my Maxxum 65lb Thrust trolling motor.
If you never did this before , I strongly advise take it to a local shop....if you don't seal it correctly, you will end up buying a new one for water getting in.... I fix alot of things on my boat but not the trolling motor....your choice....GL
Jul 10, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
New MotorGuide VariMAX trolling motor does not run
May 23, 2009 | MotorGuide Electrical Supplies
Replacement of motorguide trolling motor prop
Motor Guide hubs come in two different sizes - 3" and 3.5". The 3" size is more for older and lower thrust models. Newer units use the 3.5. The size differences are between manufacturers too. MinnKota's are a little bigger. If you order a new prop, the only issue may be the depth of the prop. I had to use a longer prop nut wrench to tighten the Hydrilla Hacker I purchased.
Triton72
Mar 26, 2009 | Boating
Electrical Supplies Logo
37 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
