Question about Tefal Ultimate Autoclean Fv9550g0 2600 Watt Steam Iron
Water leaking from tank on initial fill - Tefal Ultimate Autoclean Fv9550g0 2600 Watt Steam Iron
Shark iron leaks water from the bottom of the body where the power cord come out. could it be a crack in the holding tank? Is there a way to fix it,or will I need to purchase a new iron?
It is hard to assess what would be the cause, but I think your diagnosis may be correct, of a possible crack, or a tube has come loose. You tube has instructions on how to disassemble and iron if you are up to it and have the tools. Then you'd have to order a replacement part, and re-assemble. I'd just go to walmart & buy a new iron! But that's me! :)
Iron Disassembly Process
Nov 16, 2016 | Irons
Leaky tank cap
you must test the valve +bent pin, weak spring+or improperly SEALED valve, this often will cause the problem.
God bless you
Jul 25, 2012 | Irons
A stink bug climbed in the water chamber and we can't get it out. is there a solution?
Slowly fill the water tank with water. The stink bug should rise to the surface. Continue filling slowly and the flow of the water out of the fill hole should force the stink bug out! Remember as you're filling you must use something that will NOT block the fill hole or the water cannot drain and your "little friend" won't be able to be flushed out by the flow of the water.
I hope this helps!
Mar 07, 2011 | Rowenta Professional DX8800 Iron
A PIECE BROKE OFF OFF THE MAIN BODY WERE THE
Try filling the hole with some fibreglass resin ( the stuff that motor car shops sel for fixing car bodies). This would provide a quick setting, hard filler.
Dec 14, 2009 | Rowenta Commercial Garment Steamer - White
Leaks water out all the time. Clothes wet or rust marked.
OMG, how frustrating to be ironing and water shoot out everywhere from this iron....So, to remedy it, I have turned off the steam, use it as a dry iron, and have a spray bottle handy to spray as I iron...love the feel of this iron, but hate the water everywhere...
Sep 02, 2009 | Euro-Pro Shark GI490 Iron
How do you fill the water tank on the steamer conair model GS15RN?
FOR HOUSEHOLD USE ONLY
FILLING INSTRUCTIONS
1. Place the unit on a stable surface.
2. While holding the water tank with one
hand, move the release lever toward the
power cord.
3. With the reservoir released, pull up on
the reservoir to remove it from the body of
the unit.
4. Turn the reservoir over, revealing the rubber
inlet cover.
5. Open the inlet cover and fill the tank
with everyday tap water (filtered water may
reduce hard water problems).
6. Close the inlet cover and return the
reservoir to its place, making sure that the
reservoir is secure.
Hope this helps! Hal
Jun 04, 2009 | Conair Compact Garment Steamer Iron
How to put water in the Tefal pro 2500
This type of iron is called a steam station iron.
The box is the water tank and it is this that you need to fill with water. You should be able to find a small spout on the water tank in order to fill it. These irons produce a huge amount of steam and should make the ironing a breeze once you get used to it.
Feb 07, 2009 | Tefal Irons
Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Sep 09, 2008 | Rowenta Steam Generator DG050 Iron
Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Jul 14, 2008 | Rowenta Perfect Iron
Water leak from fill button
the button may have been sealed with an O-ring at one time. It may have fallen off inside the reservoir
May 10, 2007 | Rowenta Professional DX8800 Iron
Tefal Ultimate Autoclean Fv9550g0 2600 Watt Steam Iron Logo
19 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
