Question about GE Monogram ZDI15C Automatic Icemaker
GE Monogram leaking water on right side bottom door
I have a GE Monogram refrigerator side by side Model # Z1SB360DRC thats 3 years old. The refrigerator started leaking water from the bottom of the right door. It seems to be leaking from the top of the right door at the hinge area and draing to the floor. I opened the top access door and could not find the leak. Any help you can give me woould be appreciated.
Michael
  • naper920 Jan 25, 2009
    This is not the fix for the problem.
  • Anonymous Mar 16, 2014
    Water leaking from water intake valve
I have the same problem. Open the top door to the equipment. There is a pan under the compressor. A black hose runs from the left side to this pan and drains water into it. The pan over fills and runs down to the floor on the right side of the refrigerator.
Posted on Dec 17, 2012
    President:
  • 1,214 Answers
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Posted on Jan 24, 2009
  • Mark Egan Jan 26, 2009
    Does the leaking water appear to be running water like from a water source of some type? Or is it water accumulation due to condensation?
    You response seems to be somewhat judgmental that you may already know where the problem is. If you feel there is more information that would help in solving the problem, please provide it so that others and myself have a btter idea how to direct you in resolving the problem.
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
Hello. My G.E. Monogram water dispenser trickles water after we get water from it. We have to keep a cup there to catch the excess water. How do I fix it so it stops as soon as we get water out of t
Try replacing the Water Valve. It is located in the back of the refrigerater, left side. You should see three tubes connected to it. This part fixes the following symptoms - Leaking water, Water dispenser will not dispense water, Ice maker will not make ice and Ice maker won't dispense ice. GE part#WR57X10032. The Water Valve is extreemly easy to replace. Only takes about 15 mins total time to remove, install and confirm. I just replaced mines..my problem went from leaking water to no water was dispensing at all. I have the GE Profile, it uses the same water valve as your GE Monogram. There is a You Tub video that also shows how to replace. Good Luck!
Dec 27, 2013 | GE Monogram ZISS480DRSS Stainless Steel
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
Ge monogram has water droplets in refrigerator side just along top right corner edge where top door gasket closes against refridgerator. Refridgerator seems to be holding temperature. Condenser is above...
The gasket may have worn some causing an air leak,.and you
are seeing water condensation from the leak. Try adjusting
the door hinge. Close the door on a piece of paper and see if
you can pull the paper out. Adjust the hinge until the paper is
tight.You may have to adjust both hinges to align it properly.
Feb 08, 2018 | GE Monogram Side by Side Refrigerator
Water leaking. Mongram zic[s]360 (frig on top, pullout freezer on bottom with ice maker. no water dispenser). Leaks with water supply cut off to icemaker. Ice forms on bottom. Several years old but we...
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
Jan 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
My GE monogram built in refrigerator is not staying cold
GE Mono frig are built with shut off senser on the compressor. Wipe the condenser coil with damp cloth. This will resolve the problem. This lession cost me $160.00 from GE frig tech guy. Not to mentioned using my clean cloth and wiped for just 5 minutes.
Nov 07, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Ge Monogram built in side by side. Water and Ice
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
Jun 10, 2017 | GE Profile PSW26P Stainless Steel Side by...
GE monorgram frost in the ice shute
Sounds like the ice door in the dispenser isn't closing properly or all the way which lets warm air in condensates then freezes.
Oct 22, 2007 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZDI15C Automatic Icemaker Logo
624 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
