Question about Denon AVR-5803 Receiver
When Denon AVR-5803 Is powered on, it's making a clicking sound
I have a Denon AVR-5803 receiver. I am not sure what happen to it. I turned it on, and all of a sudden it's making this rapidly clicking sound. when I engaged the power button, the indicator light shows that it is on, but the front display panel will not show any detail at all. I am not sure if one of the circuit board is bad. I unplugged the receiver from the wall outlet, try to reset, but my problem doesn't go away.
Thanks very much
  • 119 Answers
Some of these unit have a dimmer for the display however this doesn't sound like your problem, I sure your unit is going bad. needs repair
Posted on Feb 25, 2009
I have a Denon 5803 and there's no power to the ac outlets and I'm getting no sound. I hadn't use it in a long while because I was overseas but nothing has changed.
Not to sure about the AC outlet problem but I have a Denon receiver and I have had the No sound problem with mine as well I've found it was the headphone jack you can get a headphone cable and spray it lightly with WD-40 then pull it in and out of the headphone jack a few times and you might have to leave it plugged in for about an hour if you can't get it to work another tip that might help is getting an air duster can and blowing out the dust I've found one or another to be very helpful because mine does this when it sets for awhile with no use Hope this helps out
Feb 16, 2015 | Denon AVR-5803 Receiver
Denon AVR 1601 with no sound output
Sounds like Audio ouput ic's. They're located on the inside of the unit on the big heatsink. get the part number(s) of them and call you local electronics store for parts.
Jan 29, 2010 | Denon AVR-1601 Receiver
Denon avr-1804 its turns back after 5 sec
Disconnect all speaker wires on back and then turn on. If it happens again, it's most likely a power supply problem. If it doesn't happen again, it was probably crossed speaker wires.
Dec 28, 2009 | Denon AVR-1804 Receiver
I have a Denon AVR-488..Can you help?
Sounds like you may be clipping your speakers. Check all speaker connections and make sure they are not touching, at all. If you are not using speaker ends and are simply twisting the wire and connecting to the speakers, just one strand touching the other post will cause this. Good Luck
Jun 02, 2009 | Denon AVR588 Receiver
Denon AVR-1500 Receiver turns on but only a red blinking light
Hi, I have a Denon arv1500 with a bad tuner. If you can't get yours fixed, would you be interested in selling it--I'd use it for parts.
If you still have it, and would be willing to sell it, let me know!
Mar 22, 2009 | Denon AVR-1500
Denon AVR-1803 keeps shutting down
check your speaker wires make sure none are touching each other this will cause a short and shut the reciever down
Mar 17, 2009 | Denon AVR-1803 Receiver
Hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Feb 25, 2009 | Denon AVR-5803 Receiver
Denon 5803 Onscreen Display will not display on the monitor.
Yes, you have to have a composite cable from monitor out on the Denon to a composite input on the tv to get on screen
Feb 17, 2009 | Denon AVR-5803 Receiver
Can Denon AVR-1403 take 250 volts AC power?
no it will be damged need hi end monster power strip hd700 or better off ebay that will go 1st and alarm will sound on it
Jan 10, 2008 | Denon AVR-1403 Receiver
Open Questions:
Denon AVR 5803A upsampled digital inputs I had 2 questions you might be able to help me with. Both relate to my Denon 5803A signal processing. I have just purchased a Cambridge Audio Azur 840C CD player with both digital and analog outputs. The CD player upsamples standard 44.1 khz to 48, 96, 192 for digital output (and 384 for conversion in the CD player for analog output). The Denon is listed as having DAC's that operate at 192, yet when I upsample the CD digital output to 192, the denon switches to 'analog' from digital, and plays nothing through the digital coax input. If I take it down to 96khz, it plays (and lists as 96 PCM on the front panel when in 'auto' mode). So first question is how do I take a 192 khz digital signal into the Denon. I had thought the "A" designation/upgrade allowed for this. 2nd question - if I take the analog out from the CD player to the analog in on the Denon, does the Denon convert back to digital in order to 1) split the signal to the sub vs. the mains at 80 hz (or is/can this be done in the analog realm), and 2) play in 7.1 channel stereo (I know some signal processing happens for center channel, but I don't use this technically 6.1 channel). Net, does the left and right channels for front, side, and back have any signal processing in the digital realm on 7.1 channel setting. I ask because the CD player actually upsamples to 384 khz before converting to analog for a very good signal. yet I like a crossovered signal for sub, and enjoy 6.1 music at times. Thanks for any help you can offer.
Feb 28, 2017 | Denon AVR-5803 Receiver
Denon AVR-5803 Receiver Logo
296 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
