Question about Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter
Ts420 fuel leakage in airfilter - Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter
Still ts420 concrete saw fuel line placement?
its a stihl chainsaw motor adapted into a concrete saw
Stihl Ts420 Parts
shoudnt have to take too much apart
take off air filter cover to see the carby
Apr 30, 2017 | Garden
Ts420 chop saw fuel in crankcase and exhaust E
Hole in the piston or a badly scoured cylinder wall or broken rings
Apr 19, 2017 | Garden
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 | Stihl TS420
Having a hard time starting my ts400 concrete saw
spark plug color of the spark good compression good ????
tank ariation good ? fuel hose not porous , carburetor get no fuel by a sludged tankfilter or fuel tap a bad airfilter clogged nozzle and last possibility the gaskets and crankshaft seals are leaking ?
Look also if you remove the muffler to the
the state of the piston if there are grooves then you no that it will not function and the L+H adjustments in combination of the used fuel are bad or your airfilter or gaskets are not good
Aug 01, 2015 | Saws
My stihl ts420 muffler screws won't tighten
possible over tightened and cross threaded
Feb 26, 2015 | Stihl TS420
Ts420 when you try to prime it gets tight with no fuel going into carby. primer is pumping fuel
check the primer base isnt blocked, check carb diaphragms, replace if necessary and clean carb.
Apr 02, 2014 | Stihl Garden
Stihl saw cuts out when machine is tilted forward on ts410 anybody else have this problem
Fuel pick up will be your problem. Buy new fuel filter and fuel line from in tank to carby. Most likely a split in the fuel line in-tank
Feb 13, 2014 | Stihl Ts410 Ts420 Cut Off Saw Piston Kit...
Sounds like a shorting out, or rough idle-suspect valve leakage or cracked head?
Chainsaws dont have heads.Could be leaking crank seals,carbi needs kit,coil crook if problem starts when saw hot.Check airfilter,mix fresh batch of fuel.Remove chain to check motor running.reset mixture screws,all the way in and one and a half out as a starter guide
Sep 18, 2013 | Garden
Stihl madel ts420 how to change air filter
There are 4 torx screws on the black back cover. Here is the owners manual. It is explained on page 33.
Stihl TS420 owners manual
Jun 22, 2012 | Saws
My Brand new Stihl ts420 cut saw wont run full throtle, smokes white, and leaks fuel out of exhaust filter. it runs like the choke is half on.
This sounds like the carb is flooding, there is a rubber tipped needle under the metering side of the carb, this may be leaking, before replacing the needle make sure the air filter is not blocked, replace with a new filter and try again
Dec 14, 2011 | Stihl Ts 410 420 Cut Off Saw...
Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter Logo
46 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
rlev_7
Level 1 Expert
Spud Howell
Are you a Stihl Saw Expert? Answer questions, earn points and help others
