Question about Sony NW-HD5 MP3 Player
'connecting to pc' is always showing on the display
I need some help pls.
How can i solve this kind of problem, i tried to reset but nothing happen if i press search button the display light ON it means that the button is working.
The charge controler was failed and the USB controler work all the time.Charge controler is SN412005RHLR.You can replace it by BQ24035 which is made by TI.and you can contact with me by the mail addr below:
fanxiaozi2002@yahoo.com.cn.
Posted on Apr 16, 2009
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
Dec 21, 2010 | Sony Walkman NWZ-E344 Digital Media Player
Memory not readable by PSP or Computer. HelP!
Dear Friend,
you have to check the Following
  • Make Sure Your MMC is NOT PASSWORD PROTECTED
  • Your Card Reader properly Connected to PC(Make Sure GOOD in Condition about the Reader)
  • Properly Inserted MMC to READER
  • Change USB port if Still Not Detecting
  • Try another MMC to Reader
  • Reinsert your MMC
  • Reboot your PC
Remove Lock of MMC(Lock might be in Left Side of Your MMC).Still you have Problem Please Change your CARD READER/MMC ...
YOu are done...Solved.....
IS this HelpED you ... Do RaTe mE...
you can Feel Free contact me... Thanks for Using FixYa
Apr 04, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
My Nokia N72 display does not work, the modem works and I can connect to internet, and check sms and send sms using pc suite, pls kindly help me MP
Dear Friend , Your Problem Might Be
  • Display Damaged
  • Display Connector Damaged
  • Display IC damaged
  • Some Components Related to Display Damged
Kindly Check above things..Your Problem Solved.....
You may feel Free Contact mE.........
Is this Helped you...Rate me....
Apr 01, 2010 | Nokia N72 Cellular Phone
My Zen Vision M 30GB mp3 player won't turn on, the blue light at the top flashes but the screen won't pop up, not even when i plug it in to charge it (which it usually does automatically). Now, i tried to...
Mine does the same thing, You just have to leave it plugged in for a long time, and after a while the black screen with the battery that tells you it's charging will show up.
Trust me, it'll happen.
Jul 20, 2009 | Creative Labs ZEN Vision:M Digital Media...
Configuration/browseing settings
Never configure it manually !
That means there are many settings are already saved in your Nokia device . Just discard them and try again.
If you couldn't discard them here is another solution :
Just restore factory settings and I'm sure that you'll solve the problem .To restore factory settings here is the way: Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 keys press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
then here is what to do :
Just call your service provider support center and they'll help you for sure . don't try it by yourself . let them help you . they are the only ones , who can help you correctly .
your rating is very important for me , that's why I've helped you .
good luck .
Mar 06, 2009 | Nokia 3110 Cellular Phone
CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | ASUS P5PE-VM Motherboard
Hands on display and hanging there
When you get this kind of problem with a Tomtom device always start with the memory card, so: 1: remove the card, clean the contacts and if you have an air duster (available from any good hardware store/electronics store) clean the card slot, then reinsert it. 2: make sure the card is readable on your PC to ensure it doesn't have a problem. if this doesn't help then 3: format the card and reinstall the maps & software on to it. 4: make sure the card is reinserted correctly. Next is the battery, if you've not used it for a month leave it switched on until the battery runs out, switch it on again and it should stay on for a moment then switch its self back off, repeat this until it will not switch on anymore and then charge it for at-least 16 hours before trying it again, this will re-calibrate the battery. Diagnosing a problem is a process and this is just the start of it, don't be disheartened if this doesn't help, just message back with the results.
Aug 27, 2007 | Tomtom GO 700 GPS Receiver
Sony NW-HD5 MP3 Player Logo
145 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
