Question about Ricoh 3310LE Plain Paper Laser Fax
Reason call service 0500h
Why
Recieved e mail saying possible promble with your account callus before you use card their is a block on my card cannot use reason for block security reasons needs send proof of address sscard id
Hi, contact the email service direct this sounds like scam. Have you tried the service if it's ok then it's running properly. If the service had a problem they would have stopped your service.
Mar 19, 2016 | Computers & Internet
0500H Fatal Error
Witam,
0500H Heating roller warm-up failure:
The thermistor /1 does not detect the specified temperature and the warm-up cycle is not completed even after the lapse of a given period of time after the cycle has been started.
Relevant electrical parts
Fuser unit
Printer control board (PRCB)
DC power supply (DCPU)
Solutions:
1 Check the fuser unit for correct installation (whether it is secured in position).
2 Check the connector between fuser unit - PRCB PJ9 for proper connection and correct as necessary.
3 Check the connector between fuser unit - DCPU CN2 for proper connection and correct as necessary.
4 Change fuser unit.
5 Change PRCB.
6 Change DCPU.
Mar 12, 2013 | Konica Minolta Magicolor 3730 Dn Color...
@wanadoo.frKONICA 5400 DL MESSAGE ERREUR 0500 H MERCI DE MEREPONDRE
C'est apparemment le préchauffage du four qui n'atteint pas la température voulue
=== 0500H :Heating Roller warm-up failure The Heating Roller Thermistor does not detect the specified temperature and the warm-up cycle is not completed even after the lapse of a given period of time after the cycle has been started.
Source : Doc technique de la série 5400
Franck Horlaville TAM Software
Sep 12, 2011 | Konica Minolta magicolor 5430 DL Laser...
Unit just keeps turning off for no reason
well depending on heater make and model, there could be a number of reasons for this it could be that it despratly needs servicing (every year your heating appliance should be serviced yearly), as it will fill up with **** around fans and heatexchangers and will cause some heaters to turn of on over temp, it could also be an electrical fault, it could be a many of reasons so a good idea is to call your service agent and get cleaned and checked they might find a problem or they might just clean problem out of heater as i find service work has repaired more heaters than ones that i have repaired as break downs so servicing, but as i said there could be other reasons for it to do this if you give make and model next time it would help as someone would know if it only needed reseting or not you could try this disconnect from power source wait a minute or two then reconnect, i would still get it serviced!
Nov 21, 2010 | Heating & Cooling
I cont access net connection to my z400 phone.
the reason may be you have not received the gprs or wap set up from your service provider.please make a call to your service providers customer care and ask them to sent you the setup....and then try it once again.....it may be one of the reasons as i said.....if it is not the reason then please clarify your problem....thank you..
Jun 13, 2010 | Samsung Z400 Cell Phone
For some reason I cant send messages from my LG Rumor Touch I can recieve them and I can call and answer but I just cant send them it fails!
you may want to call your service provider and ask them to reset your account. Often this happens when an account had been suspended for some reason and then restored to service. Sending texts is the last component to be restored and for some reason sometimes doesn't automatically. I bet refreshing your account will help . good luck
Jun 10, 2010 | LG RUMOR Cellular Phone
Error message 0500h
Your fuser is not warming up. You will need a technician to look at it.
Mar 16, 2009 | Konica Minolta magicolor 5430 DL Laser...
Ricoh 3310LE Plain Paper Laser Fax Logo
15 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
