Question about Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop
Trying to add another internal hard drive to Dell Dimension 3000
I am trying to add an additional internal hard drive to my Dell Dimension 3000. I ordered it from Dell so I would think its compatable. It is a Western Digital 160 GB 7200 RPM Caviar PATA Internal Hard Drive. There are two connections for ribbon IDE cable on the mother board. One has two DVD drives attached to it. The other has a single ribbon cable going to the original C drive. If I replace that cable and put both hard drives on a new IDE cnale with two connectors (and set the second drive to slave on the jumpers), the PC doesn't recognize either drive. Is that original ribbon cable different than a regular IDE ribbon cable? It looks a bit different, like the wires are smaller and there are more wires. Additionally, if I disconnect one of the DVD drives and put the new hard drive on that cable (with the original configuration for the C drive on the original cable) the PC recognizes the new hard drive in the device manager, but I cannot see the device in the My Computer. What is going on?? How do I make this work where I can have two hard drives?
    Scholar:
  • 155 Answers
Leave the cable connection as it is. That is, one ribbon cable for the 2 dvd drives and the original cable for the old hard drive. You dont need to set the jumper on the second hdd. It has to be set to 'cable select'. Then make sure to connect the second hard drive to the middle port of the ide cable. Don't forget to connect the power connector to the drive. It should work that way.
Two ports on the motherboard
primary ide controller port (for master and slave hard drives. both drives jumpers should be set to cable select. then make sure to connect the right ends of the cable to the drive. middle port is for slave. port on the end is for master. check the power connectors for both drives.)
secondary ide controller port (for 2 dvd drives.)
Posted on Jan 24, 2009
    Brigadier General:
  • 5,158 Answers
Ok... one end of the ide cable goes to the board... make sure that's plugged in correctly and has a blue connector.... second... the last drive on the other end has to be the master... the drive before that is the slave... if that setup is not working ensure that the drivers are set for master and slave... also make the power is pluigged into both drives
Robert
Which power supply connectors plug into which drives in a dell dimension 3000
P1 is about the same as the rest but for a slave drive p7 should be ok
Jun 21, 2013 | Dell Dimension 3000 PC Desktop
I'm trying to increase hard disk space on a Dell
Hi.
The Dell Inspiron 1100 is a laptop whereas the Dell Dimension 2400 is a desktop pc.
The hard drives are incompatible because they are a different size, plus the Inspiron only supports one hard drive so you can't install a slave device. The only way to increase hard disk space is to buy a large capacity internal IDE laptop drive or an external hard drive.
Regards.
Jan 01, 2013 | Computers & Internet
Dell 3000 running out of space do I need an internal hard drive
depends...are there apps you dont use you can uninstall to free up space? Do you do alot of video/gaming? If so then yes add a 500gb or more hard drive. Hard drives are cheap these days.
Jun 11, 2010 | Dell Dimension 3000 PC Desktop
My dell dimension 3000 pc has run out of memory space on the C-drive. How do I add more memory?
You can't directly add additional memory space to the C drive, but you can add additional hard drive and move the files from C drive to the additional drive. If there's enough space on D or E drive, you can move from C drive to the other drive. Note that your C drive includes your Desktop, My Documents files, My videos, My pictures, My Music etc.. So make sure you haven't saved extra files on you Desktop or My Documents. To free up some space, you can run DiskCleanup utility which is built-in with the Operating System. To do this, Right click on the C drive, Properties - Disk Cleanup... and then provide positive input, eg. yes or ok. good luck..
May 14, 2010 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 just stopped working, no sound, no picture. Power supply comes on, hard drive light blinks as if it is trying to load, but, nothing.
just reinsert your RAM.
its not a graeat problem. so just open your cpu and eject ram and insert it again properly. okay
Apr 26, 2010 | Dell Dimension 3000 PC Desktop
I'm trying to reformat the hard drive on my dell dimension 3000 desktop after a virus. I don't seem to have the system restore function anymore. I do have the original cd with windows.
The restore function is available in the system properties... Also if it is not available then
Go to Control Panel -> Add Remove Programs -> Windows Components -> Accessories
Click Details and click System restore option
Apr 25, 2010 | Dell Dimension 3000 PC Desktop
My dell dimension 3000 PC has run out of memory space on the C-drive. How do I add more memory?
Looks like that computer ships with a standard 40GB drive. If you have ran out, you'd need to go to your local computer parts store (ie, frys) or buy an additional hard drive. Your computer uses the IDE interface for hard drives, which is a 40-pin connector. You can but these pretty cheap now. Once you get it, it's just a matter of opening the case, and putting it in there. You can't connect it to the wrong place.
Mar 25, 2010 | Dell Dimension 3000 PC Desktop
How many internal hard drives does a dell dimension 3000 have?
It has 1 fitted internally as there is only 1 3.5" 1" high drive bay.
Oct 07, 2009 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Jan 26, 2007 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop Logo
789 people viewed this question
Alun Cox
