Question about Kenwood KD-291RC Turntable
Turntable starts playing record middle 1st song
When tonearm moves to start to come down it moves some to the
left then needle touches the record not at begining of the song but
in the middle of the first song i put a new needle n53 it plays ok
this is linear tracking turntable kenwood KD-9XB I BOUGHT USED
no book they didnot have this turntable on the list but i wrote it down here kenwood kd-9xb
  • zjhj Jan 25, 2009
    thanks maybe your right but how do i fix this problem
    yes it make a clicking sound at first as arm moves then it stops
    but coming back it makes it to all the way to stop
    it a linear tracking turntable kenwood KD-9XB i cannot tell if its tilted for sure it looks ok
  • 42 Answers
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Posted on Jan 25, 2009
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
My Denon DP-26F tonearm does not return "all" the way when finished playing a record.
Tonearm can be adjusted to travel back to its support. At the base of the tonearm is a small rubber stopper. Remove the stopper and insert a flat blade screwdriver into the slot beneath. Turn to the left and then test arm for repositioning correct. Adjust until its correct. John
Dec 27, 2012 | Denon DP-26F Turntable
I have a Crosley CR49 turntable and the tonearm seems to be misaligned. I lift the cue lever and place the tonearm where I want it to land on the record, but when I lower the cue lever the tonearm moves...
that situation is possible that it is bent a little. make sure your table is level when using it and check the weight in the back to see if its too far out leaving the tone are to bounce of drift easily. you can manually put the needle down in the meantime.
Sep 22, 2012 | Audio Players & Recorders
Well im not too sure if my needle is broken but when i play a record i cannot hear sound and it sounds like my record is being scratched. Do i need to keep the white cap on the needle or not? or is it just...
It's called a stylus. What red or white caps are we talking about? Some phono cartridges come with stylus guards that flip up out of the way for play or down to protect the stylus from damage while in storage or during tonearm balancing. The stylus needs to touch the record groove directly.
Jul 14, 2010 | Numark ttUSB Turntable
Tonearm goes to record and returns to start position without ever playing the record
Do you have an adjustable piece at the end nearest the pivot point [the bit that goes into the turntable] if you do then adjust the weight so there is more downward pressure on the record [ or just try putting weight on the tonearm ] and see if this helps
May 23, 2009 | RCA Audio Players & Recorders
Turntable stylus not staying on record
Since there are no tonearm adjustments the only solution in the manual that comes close is to make sure the turntable is level. The other possibility is the no-brainer of checking the stylus cover is NOT rotated down, preventing the stylus from contacting the record.
A quick and dirty test of tonearm balance being too light would be to unplug the power and manually move the tonearm over the platter. Gently lower it to see if it floats in the air or lightly but firmly contacts the platter. That won't tell you if it is tracking properly but it might indicate or eliminate tracking force as the culprit.
Apr 26, 2009 | Audio Players & Recorders
Tonearm/ scratchy audio
The transport screw is just for stabilising the suspension for moving the turntable. Just put it in the position that allows the turntable to bound up and down a bit when you poke it.
As for the skating of the tonearm, it's just that the tracking force is set too high. I don't know your turntable, so can't tell you quite where the tracking force adjustment is, but it's likely a dial close to where the tone arm pivots. A test record (with test tones) is a great way to adjust that, but otherwise repeated listening to a record will help you - make sure that the loud parts of a track distort equally on both speakers.
See also http://www.turntablebasics.com/advice.html
Mar 21, 2009 | Excalibur RD50 Turntable
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
When i backspin the arm is forcing itself off the vinyl
IMO the problem can be solved in 2 ways, either move the counterweight on the back of the arm towards the turning point of the arm ( by just adjusting it 10 - 20 % of an whole spin you can adjust a lot), or buy an other needle which is heavier then this one...
Jan 29, 2009 | Technics SL-1210 Turntable
Some sounds are lower in songs
Well, it seems you answered your own question. Replace your stylus. If that doesn't solve your problem, the issue might be your RCA cables or tonearm.
What many people don't understand is that it takes ALOT to wear out a record. I mean, you would have to play a record about a good 1000 times before you'll see any sort of real wear/tear on it. Why do you think they last so long? Besides, record wear doesn't sound like that. With TRUE record wear you'll experience lots of skipping from your stylus, as the grooves have worn down. Also, you'll get alot of pan issues, where the sound goes in/out left/right side. The grooves of a record are a V shape, and the left side of the V carries the left signal, and the right side carries the right signal. With record wear, usually 1 side will wear out quicker than the other, and that's why you'll get inconsistencies with sound.
Unless you play the same record over and over again for the past few years, you wont see this kind of wear.
Replace your stylus first, then have your RCA cables and tonearm checked. Try cleaning out your tonearm with 99.9% PURE ISOPROPYL ALCOHOL and see if that does anything.
Good luck
DJ PRO LAB
Jan 02, 2008 | Technics SL-1200MK2 Turntable
Kenwood KD-291RC Turntable Logo
722 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
