Smc wireless usb setup - Computers & Internet
    Problem Solver:
  • 12 Answers
Ok one If your wireless SUB Adapter came with software install it. Turn off the PC and restart it. Once it is installed place your adapter into an SUB Drive Slot. trun off your computer and your modem. Turn your modem back on then the PC. Once your PC is on you should see your connection in the bottom right hand corner. However, some wireless Adapters will not work with some modems. and you will have to input your IP Address your self before it will work right. But this should do the trick.
Posted on Jan 25, 2009
How do you download the usb to ethernet adapter software?
Here is the SMC driver website. You can search for the model number. Or, they also have a link to old products if yours is old enough.
SMC
Sep 02, 2014 | SMC USB to Ethernet 10/100 Mbps Network...
Vista Drivers ?
Have a look on this site
and download and install
if not workimg reinstall the app in compatibility mode in vista
http://download.cnet.com/SMC-EZ-Connect-Wireless-USB-Adapter-SMC2662W/3000-2112_4-67720.html
Feb 20, 2010 | SMC EZ Connect g SMCWUSBT-G (SMCWUSBTG)...
How do you connect a printer to this?
Basically, if it is a wireless-ready printer, what you need is match the same wireless settings that you have from your router.
On most wireless-ready printer, you need them to connect temporarily to your computer through USB connection then run the Setup CD. You will then have the option to configure the wireless settings (the same that you have on your router), then install the printer driver afterwards. You'll be prompted when to unhook the printer from your computer to make it wireless.
Oct 28, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
USB 2.0 to RJ-45 LAN Ethernet Network Adapter driver required
SMC2206USB/ETH Drivers
SMC2208USB_ETH Driver
SMC2209USB/ETH Drivers
If it's an SMC with a little luck you'll find the drivers for your specific model number, Otherwise, go to SMC Site and search for your model number. If it's not an SMC device, let me know what brand and model number it is.
Alex
Mar 25, 2009 | SMC USB 10/100 m Ethernet Lan Card Adapter...
Unable to get IP address on SMC2804WBRP-G
You need to setup security on the laptop/access point. Apparently it has been setup in the router.
Jan 25, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
SMC Barricade g SMCWBR14-N Wireless Router... router Configure with Westell 327W
it seems that the router capability of both devices are conflicting with each other so below are the steps that you can try to setup the two devices to work with each other.
i assume that you are using pppoe connection from at&t and you are using a connection manager. if so, with the current setup that you have right, you need to disable the connection manager on your computer (network connection, disable at&t connection) and set the connection of your web browser to "never dial a connection". check now if you will be able to connect to the internet instead of being prompted for a password. if your problem is still the same, try the steps below.
configure the westell 327w the way it was before (when it works properly when hard wired to the computers but the wireless sucks) but disable the wireless capability. change now the ip address of the smc router from it's default (192.168.2.1) to an ip address which is on the same segment as the ip address of the westell 327w (ex. 192.168.1.2 if your westell 327w is using the ip address 192.168.1.1). disable the dhcp of the smc router (note:make sure that you have configured all the settings that you want to configure with the smc (i.e. wireless settings, port forwarding, etc). then connect the westell to one of the LAN ports of the smc (note: with this setup, the wan port of the smc should not be used) and power cycle everything and check if this setup will work.
hope this'll help you and just ask me if you have other concern.
ciao!
Oct 08, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
Can't connect to linksys wireless router
It's the particular type of security you've got set up. Some formats of security require the key to be between a minimum and maximum number of characters, some require it to be a set number of characters. If you have problems, reset the router using the reset button on the back, and run the setup again.
May 27, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
