Question about Albatron Monivision 29" Picture Tube Monitor (SK5952SF)
Picture tube model notx2759
    Sergeant:
  • 279 Answers
Okay, that's just a model number. What's the problem with it?
Posted on Aug 28, 2007
SOURCE:
Toshiba television model 36AF62 has audio but no visual
O boy this is a really really old model CRT
if it has no picture is most likely has a failed picture tube. its too old to fix
a new 36 inch will cost you $150
Mar 07, 2018 | Toshiba Televison & Video
Where do I locate the picture tube in the tv and replace it?
there is no tube,it has different components and to fix them is going to cost you more than a flat screen tv
Jun 14, 2015 | RCA Televison & Video
Is there any way to get a new picture tube for this model
What is the model number to your TV? Brand name? Size of the picture tube? 14"; 19"; 20"; 21" etc. Type of the picture tube; full flat; cylindrical; semi-flat? CRT neck type? Broad or narrow?
Provide these details please. Without these, how can one post a solution to your problem?
. http://electronicshelponline.blogspot.com/
Apr 20, 2015 | Televison & Video
What powers the picture tubes in a 55 inch model tn55x81
The tubes in the projection set among other things need: 200 volt screen source, filament voltage and high voltage.
Note that if set for example has a loss of vertical or horizontal sweep this will be detected and the tubes will be shut off to prevent the tubes from getting a burn mark on their screens.
Nov 06, 2012 | Toshiba TN55X81 55" Rear Projection...
I have sound but no picture. Turns on/off with no problem. Checked settings including playing DVD and other video settings- picture just went out
The model indicated has 3 picture tubes (right model?) and will blank or turn the tubes off for several reasons--almost all are protection.
In this kind of set if vertical loss of sweep (in old sets you would see just a white line left to right) it will not permit the tubes to be on as it would burn a line instantly in all three tubes screens.
If this model not likely to be a do it yourself repair.
May 28, 2012 | Toshiba TP55H95 55" Rear Projection...
Hi i need a picture tube (the blue crt) what all models and sizes of Toshiba fit if i was to go used? It is a toshiba 50h81
You can also use picture tube part number 23008517 which is in model 57H81. Please note that these tubes are no longer available frmo Toshiba.
Dan
Nov 02, 2009 | Toshiba 50H81 50" Rear Projection...
Picture tube went out
This set has some age on it. Everywhere I looked the tubes are no longer available. Good luck. Thanks
Nov 01, 2009 | Televison & Video
I bought a jvc tv crt model AV29RT28 last may 14, 2008. my problem was a week after i bought it discoloration on the screen was noted. i report this problem to jvc service center. they said that the...
I presume that the set is second hand?? They`ve got to fit the correct tube for safety reasons and the set is designed to work with that tube only for that size of set, HOWEVER, they may fit a regunned/refurbished or even a second hand tube in the set. Ian
Jul 30, 2009 | JVC Televison & Video
D52w20 rear projection tv
If you go to this link they have any Picture tube you need for your model and they include instructions on how to remove the old Tube and install the new one. Your model has picture tubes instead of lamps. Leave them an email with your model number and which CRT (picture Tube) youre needing they respond quickly. Heres the link.
http://servicemanuals.vstore.ca/
Jun 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model # 20F510TD TV/DVD
What makes you think the picture tube is bad? What exactly are the symptoms you see? The RCA 20 inch picture tube is a good quality long lasting tube and I doubt I have ever seen a bad one.
Jul 03, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
Open Questions:
*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]
Oct 17, 2019 | Computers & Internet
AVG customer service phone +[-\@;-{+1'8OO;8O3^1O69}] NuMbEr USA .Anita This AVG USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 AVG USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the AVG USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, AVG USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVG USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AVG USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AVG USA Calling AVG USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVG USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVG USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVG USA's phone numbers against each other. Contacting AVG USA in General While I8OO8O31O69 is AVG USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach AVG USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVG USA.Anita
Oct 17, 2019 | AVG Computers & Internet
See all Albatron Monivision 29" Picture Tube Monitor Questions
Computers & Internet Logo
53 people viewed this question
Top Albatron Computers & Internet Experts
Ekse
SirEbrum
Are you an Albatron Computer and Internet Expert? Answer questions, earn points and help others
