Question about Fujitsu fi-6130z - Document scanner - Duplex - Legal - - PA03630-B055
After scanning several pages, I don't know how to save it as one file.
    President:
  • 2,976 Answers
After you scan the first page, click on add another page or add more, or ahatever your particular program asks for to add another page. When you save as, the pages will all be in one document. If you scan each page, individually as a separate document, they will be just that, separate documents.
Posted on Jan 17, 2013
When i try to save excel files to desktop they aren't saving the latest version,...
I don't think your computer is having an issue with capacity. I don't exactly know what the problem is, because it could be many things. However, if you want your Excel files on your desktop that you keep modifying, you can make a folder on your desktop, and then save them into that. It may be a good idea to delete each earlier one when you save new ones. Hope this helps!
Oct 08, 2012 | Apple MacBook Air
DELL 1135N WILL NOT SCAN MULTIPLE PAGES TO ONE FILE
When you are at the option to "scan to" and you change it to PDF, change the file name and it saves it as that one file. If you don't change the file name it does multiple sheets.
May 16, 2012 | Dell 1135n AllInOne Laser Printer
Can you multi page scan, say 3 pages into one file, want to emaqil that file. Don't want to have to email 3 separate files. Re HP8500A
Yes, you can scan 2 or more pages in one file if you scan as pdf file and you use the top feeder to scanned multiple pages. SET YOU SCANNING FEATURES TO SCAN AS PDF not JPEG FILE.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 14, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Lexxmark x8350 PDF file is to big
I would start by looking at the actual data size of the file.
Next step, I would determine is the flow control between the printer and the PC is working correctly.
If the file is very large or intensive (lots of graphic images), I would break the file into several segments.
For example, pages one to five I would highlight and then do a "Save As" and name the new file as filename1.pdf.
Once the file is saved that way, I would move to page six and do a "Save As" filename6.PDF and so on until I have broken the file into more useful segments.
If you have the file and can send it to me at don.farr@hotmail.com, I'll be happy to see if I can structure the file for you.
Don
Dec 11, 2009 | Lexmark All-in-One Printer with PictBridge
Can't scan multiple pages into single document - reinstalled drivers but still can't - used to be able to. How do I fix this?
http://files.support.epson.com/htmldocs/…
I think this says you need Professional Mode rather than Full Auto Mode.
Under File Save Settings in the Professional Mode, you should see buttons for Add Page / Edit Page / Safe File.
Basically, you keep adding pages then finish.
If you already have multiple .pdf files that you wish to combine, Acrobat Professional (not READER) can do that.
Good luck,
- CarlD
I copied the text but I think you won't be able to see the images here:
4. Select PDF as the file type setting. The current Paper Size, Orientation, Margin, and Compression setting are displayed below it.
5. If you need to change any of the current PDF settings, click the Options button. You see the EPSON PDF Plug-in Settings window:
Select the settings that match your document and click OK. You return to the File Save Settings window.
6. When you are finished selecting file settings, click OK. Epson Scan scans your page and displays this window:
7. If you are scanning only one document page, or you don’t need to edit your pages, click Save File and go to step 10.
If you are scanning multiple pages, click Add page and replace the first page on the document table with the second page and click Scan. Repeat this step for each page in your document. When you are finished, click Edit page and go to step 8.
8. You see the Editing Page window displaying thumbnail images of each scanned page:
If you want to include all the document pages in your PDF file as they currently look, go to step 9.
If you want to delete some of the pages, click the odd pages or even pages icons, or click the individual pages you want to delete. Then click the delete icon to delete them.
If you want to rotate pages, click the pages or use the odd pages, even pages, or all pages icon to select the pages. Then click the left or right rotate icon to rotate them.
Note:
The delete icon is not available when all document pages are selected.
9. When you have finished editing your document pages, click OK. Your document is saved in a PDF file in the location you selected and you return to the EPSON Scan window.
10. Click Close to exit Epson Scan. Source(s): http://files.support.epson.com/htmldocs/…
Aug 22, 2009 | Epson CX8400 All-In-One InkJet Printer
I would like to scan several pages and have it save as one document. Currently each page is a separate document
thanks for using fixya!!!
Just check the setting and instead of using JPEG select PDF file, to save your scanned documents.
Regards! if you need anything more, let me know.
Mar 09, 2009 | Brother MFC-7220 All-In-One Laser Printer
Scanning several pages and saving as one document
Try this....
Scan your multiple pages to an image file, like .jpg, I know it's tedious, name them (optional) by page number, put them into an empty folder.
When you're done with all the scanning, open the folder, select all of them, open with: Preview.
Now, you should see one page, with a side bar containing all of the pages. (If they're not in order, you can drag and drop within the sidebar to reorder.) Select all of those (Or Command A)
Command P (Or Print)
In this window, you should see page one, and below that, make sure it says "Page 1 of XX"...this way you know you got 'em all, and it's your final opportunity to page through them all by clicking on the little arrows to make sure they're in the right order.
Click the PDF button
Save as PDF...
See if that helps
Jan 15, 2009 | Brother MFC 420CN All-In-One InkJet...
Fujitsu fi-6130z - Document scanner - Duplex - Legal - - PA03630-B055 Logo
131 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
