Question about POSX POS-X PC Desktop
I have pos-x monitor with emachines computer. I disconnected it a few days ago to relocate, how can I get the data to display
    New Friend:
    Problem Solver:
  • 7 Answers
You must restart the computer and remove the pen drive / dvd disk from the computer then try to find the data back
Posted on Jan 17, 2013
My computer starts up but the screen sa ys no signal
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
If its a 40 pin flat ribbon type it will be the first to fail.
Even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error.
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free.
Restart your computer then reinstall it this should activate found new hardware wizard
Check the VGA cable connection running from the computer to the monitor.
This cable must be completely inserted into both VGA connection ports, otherwise the video signal is not going to reach the display.
Disconnect the VGA cable from the computer and monitor, then look at the metal connectors on both ends.
If you are missing connection pins, the video signal is not going to transfer between hardware correctly.
To fix this problem, you must obtain a new VGA cable (at any computer or electronics store) to send the video signal.
Examine the power connection on the monitor.
If the monitor is not receiving power, it is not going to turn on.
Turn off the monitor for a few minutes, then power it back on.
Like other computer hardware, the monitor may not initially turn on correctly.
Move the mouse and press the "Enter" key on the computer keyboard.
If the computer is in sleep mode, the monitor is going to appear as if it does not have any display.
Hope this helps.
Nov 22, 2012 | E-Machines eMachines Desktop PC
My emachine ET1831-03 crashed a few months ago. All I can get it to do is display the windows boot manager screen. It says windows failed to start, and gives me status: 0xc000000f NLS data is missing,...
Power off the computer, then restart it. As soon as you see the eMachines logo appear on the monitor screen, press the "left-Alt" and "F10" keys simultaneously. Wait a few seconds for the Windows boot screen to appear, then press the "Enter" key.
Click the "Restore Operating System to Factory Defaults" option after the eRecovery Management window appears. In the Notice window, read the warning that states all information on the drive will be lost, then click the "Next" button.
Click "Next" in the Restore Destination window, then click "OK" in the final confirmation window. The eRecovery Management utility formats your main system drive and reinstalls the original software that shipped with your computer. A progress bar notifies of you of the current progress of the recovery. The recovery utility may prompt you to restart your computer several times during the recovery process. Restart the computer when prompted. The computer reboots automatically after the recovery finishes and launches the Windows First Time Setup. The recovery takes between 10 minutes and one hour depending on which model eMachines computer you own.
Follow the onscreen prompts to customize and personalize the Windows installation on your eMachines computer. Log in to Windows with the username and password you choose during Windows Setup.
Dec 13, 2017 | Computers & Internet
How do I log onto my emachines desktop pc when it keeps saying the user name or password is incorrect
Avoiding data loss! I often use the Windows Password Seeker, which helps to remove the lost or forgotten password with no data loss. Moreover, it is very easy to use. http://www.passwordseeker.com
Sep 25, 2011 | eMachines ET1161-07 Desktop PC
I have an emachines E181H TFT LCD monitor and a few months ago it would turn off at random and would come back on.After a few days it stopped turning off by itself I have had no problems till recently,...
After a while LCD monitors develop problems that are usually caused by faults in the internal circuitry. This could be an issue with the power capacitors failing. If you feel confident enough, you can remove the back cover and check to see if any capacitors are bulging or leaking. (Give it at least 24 hours unplugged to allow the capacitors to discharge before doing so). I found THAT little bit of knowledge out the hard way
Jan 22, 2011 | Acer AL2017 20" LCD Monitor
Monitor displays frequency out of range.....need help . How can I solve this?
The frequency is out of range because the VGA graphics card is not compatible or set right for the monitor's set of frequencies that it can work with.
Try another VGA graphics card.
Or upgrade the card to one with DVI, and upgrade the monitor to one of those 24" DVI Samsung monitors. They're nice. I got one from Best Buy a few years ago, and never regretted the larger desktop.
Good luck on this one.
Jul 10, 2010 | E-Machines eMachines Monitor E15T4
HP rp5700 appears dark and its not the touch
Disconnect the monitor cable from the computer tower, turn on the monitor, if no display available, the monitor gone bad, else if getting message " Check video cable", either the data cable for connecting the monitor to the tower needs to be changed or the motherboard needs to be tested thoroughly.
Jun 29, 2010 | HP rp5700 POS Terminal PC Desktop
My power light is on but the monitor is black. Is
your moniter is not broken your moniter's data cable is not correctly pluged.
Jul 30, 2009 | Dell E173FP 17" LCD Monitor
Says no signal on monitor.
The monitor is telling you that it is functioning properly (it works). It is also saying that it isn't receiving and signal from a computer. This can happen when-
** computer is turned off but monitor is on (this can occur, for example, when the computer's power supply dies while turned on). That happened to me just a couple of days ago.)
** monitor cable to computer has come loose or totally disconnected
Jun 21, 2009 | E-Machines eMachines Desktop PC
Dual Monitor Problem
Go to Control Panel, select Display, select Settings - change the drop-down to select which display is Primary?
Dec 28, 2008 | Computers & Internet
POSX POS-X PC Desktop Logo
23 people viewed this question
Top POSX Computers & Internet Experts
David Payne
David Payne
Are you a POSX Computer and Internet Expert? Answer questions, earn points and help others
