Question about Xerox 3030/3040/3050/3060/8830/8825 Developer
Fuser error LL.41
Not a fax machine, this is a plan (A1 size) copier - VERY old
2 Suggested Answers
  • 208 Answers
SOURCE: Fuser Error
You can also look for dealer service which is much more reasonable.
And also access secondary parts sources such as The Parts Drop online. Precision Rollers and several other sources.
Xerox will charge you an arm and a leg. There are many other sources to repair a 580 fax.
That is a very good product.
Posted on Nov 28, 2007
Is like this:i draft my house plan.but when print out my plan.it comes out small.what might be the problem?i used scale of 1;100.paper i used A1 size.and details i used medium.is this correct.i never had...
I believe when you used the scale of 1:100, it formatted it for the A1 paper, but only 1/100th of the size. Try doing a 1:1 (or, if available, auto) scale. AutoCAD should handle the rest.
May 03, 2011 | Computers & Internet
I HAVE A RICOH FW770 PRINTER THAT HAS BACKGROUND IMAGES, STREAKS AND SOME SPOTTING FROM THE DEVELOPER. THIS STARTED SLOWLY AND HAS GOT WORSE DAILY. I THOUGHT THE CARTRIDGE WAS BAD AND REPLACED IT. NO...
First of all the machine requires regular service.
The approx life of certain parts are as follows
Drum : 50000 copies(A1 size )
Developer : 20000 copies(A1 size )
So please check how many copies your machine has done , so that you know what you need to replace beforehand.
About the cartridge, before using it ,shake it well and make sure the gear at the end is turning properly.
Life of the toner is approx 1800 copies(A1 size ).
Jan 27, 2010 | Ricoh FW870 Black and White Copier
Jamming of letter size paper
You will probably have to set the paper size in the settings of the machine and/or on the software driver on the PC (if you are using it as a printer?)
May 26, 2009 | Muratec MFX-1500E Plain Paper Laser Fax
Disabling the fax function
You can set the fax portion of the machine to manual receive like this:
"User tools"
"fax features" ok
"reception settings" ok
"switch reception mode" ok
"Manual reception" ok
"user tools" to exit
Thia will prevent the machine from picking uo any incoming faxes
....However, if the machine is jamming trying to print a 'fax' report, it will jam regardless of the feature you are using -they are unrelated. Depending on the cause of the jam, it could be a specific tray that is causing the problem, so you may want to remove the paper from that tray, and see how it works. The other reason, that is common for jams from one particular tray is that the size is set incorrectly. Check that the paper size dial on the tray is set for the appropriate size in the tray (including orientation).
If none of this helps, please describe the location of the jams, and I may be able to give further advice.
Apr 23, 2009 | Gestetner - DSm618d Digital Imaging System...
Panasonic kx-f1100 fax prints and sends 1 page on 2 pgs- 2big!
I found the solution to my problem: Press Menu, Pound Key (#), 35 to set copy size, 36 to set fax size, press Start/Set, then use up/down arrows on right side of the machine to select 92%, 86%, 72%, or Off. Press Start/Set to select desired setting.
Press Menu to exit!
Dec 08, 2008 | Panasonic KX-FP81 Plain Paper Fax
Need to know abt fax
HP.com has a web page that talks about the different ways you can send a fax from this product:
Faxing Overview
In general, the fax machine in the all-in-one product doesn't need a computer to work. It works just like a stand alone fax machine. You shouldn't have to scan anything in from the scanner in order to fax. Just put the sheet of paper you want to fax into the product's feeder and follow the fax instructions (see the link I posted above).
As long as the product has electric power and is connected to a phone jack, it should work out OK.
As far as legal papers, if you mean legal sized papers, it should work as long as the product supports the paper size you want to use. You can get that on the product specifications web page at HP.
Product Specifications
Once that page opens, go to the Faxing specifications and Paper specifications sections for the relevant details. Good luck.
Oct 09, 2008 | HP Officejet 5610 All-In-One InkJet...
What is the remedy for copier's red alarm button blinking & fax not working?
Do you mean the "Out of paper" alarm? Check that all paper trays have paper. The by-pass tray should be prperly set to receiv "Legal" size paper and have that size paper in that tray.
Mar 30, 2008 | Canon LaserClass LC 8500 Plain Paper Fax
Small Faxes
Dear annicran,
Your fax machine may be getting old. It may only be once in a while now, but in the future, it may occur more and more. You may have to upgrade to a new machine!
Alternative solution is efax.
Zabrina<div style="display: block;width: 540px;background-color: #E4FED4;border: solid 1px #ACE28C;padding: 15px;margin: 5px;font-family: Trebuchet MS, Verdana, Sans-Serif;font-size: 13px;">
<h3 style="margin: 10px 0 5px 0;font-size: 18px;"><a href="http://www.fixya.com/{0}">{1} Problem</a></h3>
<h4 style="margin: 10px 0 5px 0;font-size: 16px;">{2}</h4>
<p style="margin: 10px 0 5px 0;">{3}</p>
<p style="margin: 10px 0 5px 0;text-align: right; font-weight: bold;">Posted by {4} on {5}</p>
{6}
<h5 style="margin: 10px 0 5px 0;font-size: 13px;"><a href="http://www.fixya.com/{0}">View Solutions for this Problem on FixYa.com</a></h5>
</div>
Feb 07, 2008 | Canon imageRUNNER 400S Copier
Brother 3240c Error A1 ,A2 and 82
Not sure what 82 code is but A2 and A1 have to do with size of paper possible original to long for size of paper in cassette
Mar 28, 2017 | Brother MFC-3240C All-In-One InkJet...
Canon Fax L120/L100
press menu and then # goto service mode. Select the clear data function.
Clear all the memory, dRAM and counter.I hope it will work for you.
May 10, 2007 | Canon L120 Fax Laser Printer
Xerox 3030/3040/3050/3060/8830/8825 Developer Logo
43 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
