Question about Hardware & Accessories
Securiswitch one gang switch
Cant switch off programme
Wiring diagram 2 gang switch
http://waterheatertimer.org/How-to-wire-switches.html#gang
Is the neutral wire inside the gang box, or is the neutral wire in the ceiling box?
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 16, 2014 | Electrical Supplies
Help - 1 Way 2 gang switch - ie: two sets of lights in same room, 1 light switch with two switches on it, each switching on 1 set of lights. I have 2 brown wires, 3 blue wires, and a short length of free...
I can probably help.
BUT, what voltage are you working with. It sounds like 230V european wire colors?
Now also. Do you have two separate light switches in same box (which is called 2-gang)? Or do you have a double switch, which is two switches on one device?
Add a comment, and include as much detail as possible about the switch, voltage, and number and color of screws on each switch.
Here is a start-point using 120Volt and US wire colors:
http://waterheatertimer.org/How-to-wire-switches.html#double
The difference between US and European, is that European has two hot wires, while US has hot and neutral wires. Otherwise both systems require two wires to complete circuit.
Sep 26, 2012 | Gb Electrical GSW-117 Toggle Switch
2 gang switches
Copy following link for switch wiring illustrations
Dec 12, 2011 | Electrical Supplies
Got three seperate lights want to put in into one thee gang light switch
Copy following link for wiring 3-gang switch:
Nov 19, 2011 | Home
I have a 3 gang box: a is for hall light switch
Timer is not identified. Battery-operate timers wire differently than timers that require neutral wire.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
For 4-wire battery-operated Intermatic EJ500, ST01C, and Ei600, Ei400 wiring:
http://waterheatertimer.org/ST01C-program.html#ST01C
For 4-wire Intermatic Ei200 series, KM-series, Ei500 that require neutral wire
http://waterheatertimer.org/Programmable.html#wire
Add a comment with model number for more specific information
Jun 19, 2011 | RTO Intermatic Digital 7 Day Wall Switch...
How do i wire a 3 gang switch
Open following links for images of 3-gang and 4-gang single-pole switches.
With the 4 gang, just subtract one of the switches.
http://waterheatertimer.org/images/Single-pole-switches-in-4-g.jpg
http://waterheatertimer.org/images/despard-500.jpg
If you have a 3-way switch, or outlet in the box, then add a comment with more exact information about what wires you are trying to connect, what color wires you have, and what you have tried so far. This will narrow down the possible answers and speed help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Cooper Industries Cooper Wiring 2158V 3...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
