Question about Vacuums
How to remove a lid from superfish aqua silver fish tank
I have a aqua silver 60 ltr fish tank, The bulb needs replacing but the light unit is housed in the top of the lid and I want to avoid disturbing the fish too much. How can I remove the lid from the tank.
The light unit on my fish tank will not come on ive tried chaging the bulbs but still nothing happens
Hi, First try the light on a different plug. If that doesn't work the switch is the problem. Be careful not to drop light in fish tank. (electic shock)
Jun 17, 2011 | Vacuums
Tip
How To Replace Brush Turbine on Hoover SteamVac When Brushes Don't Spin
When the brushes stop spinning on a Hoover SteamVac, it can be caused by several things. In order to diagnosis why your brushes aren't spinning, please view the diagnosis solution I have done on Fixya:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
If you have diagnosed your machine, and found that the internal receptacle is not spinning, then you'll now need to replace your turbine. This tip will explain in detail how you'll need to complete this repair.
Here's what you'll need to complete this repair:
- Hoover SteamVac Replacement Turbine Brush Gear (several different parts for different models)
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see-thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to un-clip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before you tighten the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
Chris J.
GoVacuum
on Apr 10, 2010 | Hoover F5899-910 SteamVac Vacuum
Tip
How To Replace Brush Turbine in Hoover SteamVac's When Brushes Won't Spin
Chris J.
GoVacuum
on Apr 10, 2010 | Hoover F5886-900 Steam Vacuum
I just purchased a floormate. I can't seem to get it to spray cleaning solution.
Turn the cleaner off and then on again to determine whether the cause of no suction resulted from the activation of the automatic shut-off. There are two reasons a tank will automatically shut off. The first is if the recovery tank is full. Located on the lower front panel of the unit, the recovery tank can be easily emptied and replaced into position. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
Turn the unit on again and check the suctioning action. The second reason automatic shut-off could take place is if the handle was raised to an upright position while the motor was running. Should this occur, simply turn the unit off, wait a moment for the shut-off to reset, and turn it on again to continue cleaning.
  • 2 Make sure the filter and filter lid are properly positioned in the recovery tank lid. The cause of the problem could be that the filter or the filter lid were missing or were not in the proper position.
  • 3 Check that both recovery tank and/or solution tanks are locked in place and are positioned properly. The recovery tank is located on the lower front panel of the Floormate, and the solution tank is located in the front top panel of the unit. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
  • 4 Observe whether filter is dirty. If the filter is dirty, clean the filter by turning the cleaner off and disconnecting it from the electrical unit. Take out the recovery tank and lid. Remove loose debris from the filter by wiping clean with a brush or tapping the filter over a garbage can. After this is completed, the filter may be rinsed clean for additional cleaning and then air dried before returning the filter to the unit.
  • 5 Check that the nozzle is in the proper position and locked. Locate the nozzle underneath the suctioning base of the unit. Make sure the latches are out and line up the middle section of the nozzle with the opening of the cleaner. Hold the nozzle in place while simultaneously sliding the latches inward to lock in
  • Mar 07, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
    The Bissell is not dispensing water or cleaning solution.... The silver & black spinner does not spin
    Check the following with liquid in both tanks.<br /> <br /> - Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.<br /> - <b>Check for debris on spray tips</b>. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access. <br /> - Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE. <br />- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.<br /> - Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.<br /> <br /> If the machine continues to not spray, check the following:<br /> <br /> <b>REMOVE THE COLLECTION TANK</b>:<br />&bull; Make sure the unit is set to water rinse<br />&bull; Remove the smart mix bottle and fill it with water only<br />&bull; Place the smart mix bottle into the collection tank reservoir<br />&bull; Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.<br /> <br /> If your machine continues to not spray, contact BISSELL Consumer Service at <a href="http://www.bissell.com">www.bissell.com</a>
    Aug 25, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Tip
    How To Replace The Brush Turbine in Hoover SteamVac's When Brushes Don't Spin
    Chris J.
    GoVacuum
    on Apr 10, 2010 | Hoover F5842-9RM Steam Vacuum
    Tip
    Chris J.
    GoVacuum
    on Apr 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
    How do I replace the spinning brushes?
    Chris J.
    GoVacuum
    Apr 17, 2010 | Hoover F5906-900 Upright Steam Vacuum
    My hoover steam vac is not releasing the cleaner
    http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
    Godbless
    Problem: Clean solution won’t
    dispense
    Problem: Brushes/brush indicator
    won’t rotate during floor cleaning
    Possible cause
    Possible solution
    • Not firmly plugged in
    • Plug unit in firmly
    • No voltage In wall plug
    • Check fuse or breaker
    • Blown fuse/tripped breaker
    • Replace fuse/reset breaker
    Possible cause
    Possible solution
    • Recovery tank full/automatic
    shut off engaged
    • Remove and empty recovery tank
    • Blockage In tool on end of hose
    • Remove tool and clear blockage
    • Recovery tank lid not on
    correctly
    • Make sure lid is on securely
    • Recovery tank front panel not
    replaced after stair or upholstery
    cleaning
    • Replace recovery tank front panel
    (page 14)
    Possible cause
    Possible solution
    • Solution tank not firmly in place
    • Make sure tank is securely locked in
    position
    • Solution tank empty
    • Refill tank according to instructions for
    surface being cleaned
    correctly
    • Make sure lid is firmly in place
    • Pump needs to be “primed” (when
    using tool)
    • See “Before using tool” section, p. 13
    Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    Tip
    How To Replace Turbine Gear in Hoover SteamVac's When Brushes Stop Spinning
    Chris J.
    GoVacuum
    on Apr 10, 2010 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
    Vacuums Logo
    218 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
