Question about Canon i950 InkJet Photo Printer
Will not print
I have a Canon i950 printer. It was working fine, but after I replaced the black ink cartridge, it quit printing. The light on top of the printer blinks green, then orange 7 times, then back to green. The only thing my computer will tell me is that the printer is not responding. Help me please! I need this printer for school!
  • 3 more comments
  • megenfaulkne Jan 24, 2009
    I don't think they're very old. Definitely less than a year. The ink looked fine & the package was sealed well.
    The green lights never stop blinking & go solid. It just goes right back to blinking orange 7 times, then back to green.
  • megenfaulkne Jan 25, 2009
    I tried turning it off, holding down the resume button when I push the power button, continue holding the power button and let go of the resume button, hit resume button twice, then the green lights never stop blinking & go solid for me to hit the resume button 4 times. It just goes right back to blinking orange 7 times, then back to green.
    I does this when I turn it on. It doesn't matter if I've even asked it to print something for me. Paper is loaded properly, but that doesn't really matter since I can't get past the blinking light for it to even try to print.
  • megenfaulkne Feb 05, 2009
    I've done all of this over & over again. I finally broke down & dug up my old printer out of my basement & got it working. Thanks for trying.
  • Canon Master
  • 6,487 Answers
Try to put the old black in cartridge so we can check if that lights will be gone, so we can check if this just a problem with the enw cartridge that you have so if everything will be fine with the old cartridge better replace the new one...
Posted on Jan 25, 2009
    Sergeant:
    Champion:
  • 435 Answers
Did you load the papers properly?
Sometimes it blinks in orange due to that.
Posted on Jan 24, 2009
  • 565 Answers
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal. (And it woks good yet)
  • Teet Bergmann Jan 25, 2009
    try to clean your prinhead or connect with service
    President:
  • 1,214 Answers
How old were the replacement ink cartridges? That's probably the @1 reason for printer errors during a cartridge changeover.
Anything over 6 months would be suspect, less if the air tite package seal was broken.
  • Mark Egan Jan 24, 2009
    Take the cartridges out of the printer.
    Place the ink end of the cartridge onto a clean paper towel folded over several times.
    Shake downward hard.
    Remove paper towel and see if ink came out, and was the pattern even. Do the same for all cartridges, and the pattern left on the paper towel should be the same for all colors.
    Reset the printer by turning off, then back on.
    Also check that the printer is selected as your primary printer by right clicking and selecting "Make Default Printer".
    Reply back after you do this, and I will help you further.
How do I change the print cartridges?
  • Open the printer cover and prop it up with the support brace located on the right-hand side of the cover.
  • Remove the black FINE ink cartridge from its container and locate the protective tape. Gently remove the protective tape used to cover the print head nozzles and electrical contacts.
  • Insert the black FINE ink cartridge into the printer slot labeled "B." It will rest on a slight angle. Push the cartridge up and back until it clicks into place.
  • Repeat the process for the color FINE ink cartridge, placing it in the slot labeled "C."
  • Raise the printer cover slightly to loosen the support brace. Fold the brace inward and replace the cover to its closed position.
  • A green LED light will flash on top of the printer. In about a minute, the LED stops flashing and displays "1." Once the "1" appears, you're ready to print.
  • Mar 10, 2015 | Canon PIXMA MP210 Photo All-In-One Printer
    Sketchy printing, yellow and black very faint
    Try to change the inkjet cartridges for the black and color because you may only be able to get no more than 105 pages out of a cartridge, assuming it hasn't gone through a cleaning process which uses up a lot of ink.
    Unfortunately, most ink jet printers have very expensive ink for printing small jobs, compared to say a laser printer.
    Dec 19, 2010 | Canon i950 InkJet Photo Printer
    Alarm on: reads wrong cartridge in window
    Problem may be due to your not printing for quite some time. The ink can start to dry and clog the print heads.
    Use a Q-tip slightly moistened with water to clean cartridge ports and print head.
    Jun 13, 2010 | Canon MultiPASS MP700 All-In-One InkJet...
    My printer Canon MP760 does not print black.
    Your black ink must be empty replace with a new one and print.
    Sep 20, 2009 | Office Equipment & Supplies
    Up until today, my i950 was printing perfectly. Today, after it flashes green, I get 7 flashing yellow lights. I noticed one ink cartridge was loose. Putting it back into place did not fix the problem,...
    It indicate that your print head may defective probably cause by electrical connection. OK u may try this, unplug the print head and clean the print head electrical contact part and also the printer itself contact part with dry paper and install it back. Make sure the contact part is fix into the holder completely. Hope this help.
    YBC (/\)
    Jul 10, 2009 | Canon i950 InkJet Photo Printer
    Will not reset, light blinks 8 times
    Hi there you can try this
    Start with the printer OFF
    1. Hold down RESUME and then hold down POWER
    2. Release RESUME
    3. Press RESUME twice, then release POWER
    4. Let green light blink until printer is done futzing
    Select function with RESUME press POWER to execute:
    presses - light color - function
    Number of presses - light color - function
    0 presses - green - Test print (or exit service mode on i960)
    1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
    2 presses - green - EEPROM initialize
    3 presses - orange - Reset waste ink counter
    All The Best Pineworks
    Jun 04, 2009 | Canon I990 InkJet Photo Printer
    Canon i950 won't print
    Starting with printer in off condition holding reume and then power respectively,now press resume twice and and release power button le green light blink until printhead has finished moving
    now is the most crucial information that has to be followed
    0 presses - green light - Test Print
    1 press - orange light - EEPROM info print
    2 presses - green light - EEPROM initialise
    3 presses - orange light - reset waste ink counter.
    Thanks And Regards
    May 12, 2009 | Canon i950 InkJet Photo Printer
    I have a defective print head on my canon i950 printer.
    I believe the print heads are under the ink cartridges. They might have little handles on them.
    Jan 07, 2009 | Canon i950 InkJet Photo Printer
    Colors are not printing properly
    Looks like your printer head is in need of replacement
    Nov 11, 2008 | Canon i950 InkJet Photo Printer
    Printer will not print black ink
    Hi please try these steps:::
    Right-click the printer icon, and then select 'Properties'.
    2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
    3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
    4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
    IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
    Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
    1. Confirm there is no orange tape across the top of the ink tank
    2. If the orange tape is as shown in Figure (1), it is properly removed.
      *BCI-3's shown in this example.
    3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
    4. Make sure each ink tank is snapped into the printer.
      IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
    Jun 09, 2008 | Canon i850 InkJet Photo Printer
    Canon i950 InkJet Photo Printer Logo
    old marine
    old marine
