Msi.dot4wrp fatal error during installation. - Office Equipment & Supplies
  • 1 more comment
  • angela_washi Apr 23, 2009
    Attempting to install HP Photosmart D7560. Recieve fatal error message. MSIdot4 wrp.
  • echevrin May 03, 2009
    when i insert the cd, after about 3 minutes a dialogue box apears with fatal error code 29527 and msi.dot 4wrp. the setup can not continue.
  • Vlastimi1 May 20, 2009
    Hang up the „hp“ personnel :) ...really they aren´t too much of help with hundreds of people complayining about the same fault over & over again !!No fix , no advice people try help each other but with no obvious success...I tried everything except the windows
    reinstallation. But this the last thing i would do because such piece of Going to return my printer soon and buy the Canon Pixma one as the price is the same and they are working like charm with no effort at all with very intuitive interface. HP should learn from Canon to make applications for their stuff really open for people or at least try to not to fucked up people for months with the things no one wants to care with at home or even in work (registry arrangment etc with no result ...what´s that all for ?) ! Sorry for bothering here it´s just 1.000 000 post i read about the Msi.dot4wrp something which ´s still on my screen! Take Care and Good Luck!
Put a bomb under the printer,then go by something that does nor have sorfware problems
Posted on Jul 04, 2009
    Guru:
  • 224 Answers
OK the basic function of the file atl.dll is registering the software,atl.dll will actually combine the software to check your operating system and if there aren't multiple faulty registry entries then it will install perfectly,here's what you need to do.
Insert the installation CD in the computer.
Click Cancel to close the autorun screen.Click Start (msi.dot4wrp fatal error during installation. - c01827528.gif ), and then click Run .Click Browse . Find the drive that contains the software CD, and then double-click the drive. Click the Util folder, and then double-click the CCC folder. Double-click the file Uninstall_L3.bat .
Click OK to run the level 3 uninstall(if it's an HP computer otherwise perform an l4 uninstallation)
Restart the computer.
Click on start and type in cmd (in the black window type) Msiexec /unregister
and then type in Msiexec /reregister .
  1. If necessary, click the arrow (c01185072.jpg ) next to C: (or your hard drive) to expand the list of options.
  2. ) next to Windows .
  3. Click the arrow (c01185072.jpg ) next to system32 .
  1. Under system32 , find the following files: HPZipm12.dll
  2. HPZinw12.dll
  3. Right-click each file, and then click Delete
  4. Click the plus sign (+) next to HKEY_LOCAL_MACHINE .
  5. Click the plus sign (+) next to SOFTWARE .
  6. Select the Hewlett-Packard entry and click on delete on the keyboard this entry shmsi.dot4wrp fatal error during installation. - c01319360.gifed.
Turn off services
  1. Click the Windows icon (c01319360.gif ), type services.msc in the Search programs and files box, and then click Services at the top of the dialog box. The Services window opens.
  2. In the list of services, double-click PML Driver (or some variation of that driver name). The PML Driver Properties window opens.
  3. Change the Start-up Type entry to Disabled , click Apply , and then click OK .
  4. Find the entry for Net Driver HPZ12 , and then double-click it. The Net Driver HPZ12 Properties window opens.
  5. Change the Start-up Type entry to Disabled , click Apply , and then click OK .
Restart the computer then go into C:\Program files (Program files x86 if present in Vista and Windows7)
Look for the Hewlett packard folder and Select the folder and Press Shift and Delete to permanently delete faulty software.
Now Download the software from Hp.com under support and drivers.
And When you install customize the software by only installing the main printer entry the Imaging device functions .
Continue the installation once that complete you will be able to print and you can scan from mspaint or in windows 7 paint by clicking file and From Scanner and Cameras.
However if you want the full software then hit on the start button and then run and type in %temp% and click on enter.
in the new window look for a folder beginning with "7z" or a folder beginning with HP open the folder and your printer folder and at the bottom look for an icon with an Hp logo and called setup and now in the splash window click on install more software and install ALL THE SOFTWARES THAT SHOW UP OVER THERE
Posted on Oct 01, 2010
HP L4 or whatever doesn't always do the job.
If all the other fixes around don't work for you you'll need this one; But it's tough. And scary. A real last resort.
You'll need to delete, manually, any references to HPq HPw HPx and in fact any other to HP. From teh registry (REGEDIT) and folders. ( Windows and System32 especially).
In system32 you may well find some that won't delete. (Including an msidot4wrp.exe or something similar to that)
I used a boot into Linux, a LiveCD version will do. Then I navigated to the folder and took the HP files ourt that way.
But be aware, this is not for the faint hearted. This is war!
The enemy is HP, but Microsoft's OS is the unwilling ally and may become the accidental casualty.
Posted on Jun 22, 2009
SOURCE: when installing deskjet f2180 comes
The same problem occured with my new C7280 All-in one. Tried to install on another PC and this worked. So it seems there is a problem in the Windows software System32 on the first PC (both XP).
Of course the HP software is should be able to solve this...
Posted on Nov 07, 2008
nalin_elliot
  • 224 Answers
SOURCE: Fatal error MSI: DOT4WRP
Very simple.Insert the printer installation software cd
First right click your cd drive and select open then go into the folder called util.
Then go into the folder called "CCC".
In that select uninstallation l3
once this uninstallation completes.
go into Local Disk C:\program files\hp\
and delete the digital imaging folder as much as can be deleted.
restart the computer.
goto hp.com and download the software for officejet 6500
After downloading it run it and when the type of uninstallation comes select advanced.
Next select custom installation and uncheck.
hp updates.
Hp Customer Participation Program
Hp Web Printing.
click on next first select usb installation and click on next(irrespective of whether it is a usb or wireless connection).
click on next and dont plug in the usb cable.
at the bottom there will be a box that says check this box if you want to connect your device later.
click on next.
the installation will finish.
Now insert your printer software installation cd and click on add a device or install and now you can choose your type of printer connection and your issue will be resolved.
Posted on May 30, 2009
  • 169 Answers
SOURCE: I can not install my HP Printers Officejet-- gives fatal error
This issue requires some serious trouble shooting and solutions cannot be posted as they are too long.
If you want further support you can avail free technical support on http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
sunny_magic1
  • 23 Answers
SOURCE: unable to install software on hp c4480
This is a very very tricky issue.
For a long period of time there was no known resolution for this.
but now you can resolve this too.
Follow the mentioned steps very carefully:
>> use the following links depending on your OS:
for Windows XP:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-62152-3&lc=en&dlc=en&cc=us&product=3560280&os=228&lang=en
For Windows Vista:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-62152-3&lc=en&dlc=en&cc=us&product=3560280&os=2093&lang=en
click on download only and download the software for PHOTOSMART C6380
>> run it and install it(keep the USB CABLE DISCONNECTED before installing)
>> during the installation you will be prompted to connect the usb cable.
DO NOT CONNECT THE USB CABLE
>> there will be a small check box that will tell you to check it if you want to connect the cable later.
>> CHECK THAT BOX and continue with the installation.
After the installation completes successfully...
insert the disc for your printer (i.e C4480)
Posted on Sep 25, 2009
Testimonial: "Thanks a million"
Indrani7
  • 11 Answers
SOURCE: Failed Error During Installation.
This is an internal installation error. There can be 2 solutions:---- Solution 1:-- Find all of the hpqwrg files and delete them before installing the software:
  1. Click Start .
  2. Click Search ( Find for Windows 98).
  3. Click Files and Folders .
  4. In the Named entry box, type hpqwrg .
  5. Set the Look In entry box to C: .
  6. Click Search Now ( Find Now for Windows 98).
  7. Click Edit , and scroll to Select All .
  8. Delete all files pertaining to hpqwrg . There will be approximately five to six files.
  9. Be sure to empty the recycle bin of these files also.Solution 2:---- Completely uninstall the higher version of software and reinstall the lower version first, follow the steps below in order:
    1. Uninstall all of the HP Photo and Imaging software (for both of the products). (The uninstall program can be found in theControl Panel in Add/Remove Programs ).
    2. Re-install the lower version of the software.
    3. Re-install the higher version of the software. Thank you Sir.
Posted on Sep 27, 2009
Error message 2753 MSI.dot4wrp message when trying to install HP Photosmart c4480
I had the same problem. I tried to install my new HP Photosmart 8550 printer onto my HP desktop, I am running on Vista 64 bit. Kept getting fatal error MSI.dot4wrp40 over and over again. Upset that my Windows installer was corrupted. I search the internet for this error and realized that this only comes up with NEW HP Printers and scanners. I went to Epson's website and downloaded a driver for one of their photo printers and downloaded the driver for the Epson Stylus Photo1400 Vista 64 bit driver, and guess what it installed I went and bought this printer and I am up and running again. Sorry HP I am jumping ship. The week before I tired to install this HP printer, I installed Print Shop Pro Publisher 23, Blackberry desktop, and Canon digital utilities which in fact all use Window Installer. All installed with no problem, and they are all working. I believe this error message has to be a conflict between HP and Microsoft's 64 bit OS only.... Google THIS ERROR and you will notice only HP comes up.
Dec 29, 2009 | HP Photosmart C4480 All-In-One InkJet...
Unable to install software.
Go to http://www.hp.com/support for troubleshooting information about "Fatal Error" and "MSI.netdevicemanager01
Dec 17, 2017 | HP Officejet 7210 All-In-One InkJet...
hp updates.
Hp Web Printing.
click on next.
Apr 21, 2009 | Xante Accel-a-Writer 4G Laser Printer
MSI.dot4wrp01
Fatal Error during Installation - MSI.dot4wrp01
Try this link. I was able to resolve this with this solution.
Mar 25, 2009 | HP Photosmart C4280 All-in-One InkJet...
Can't install drivers for Vista Home Premium
I would suggest you to go for restoring the system to a good known configuration.
Do a System Restore..
Otherwise more info on such issues can be get on Microsoft Article:
http://support.microsoft.com/kb/908267
Jan 07, 2009 | HP Photosmart C3180 All-In-One InkJet...
Missing msi.dot4wrp
Nov 23, 2008 | HP Office Equipment & Supplies
When installing deskjet f2180 comes up fatal error 2902 and MSI.dot4wrp
May 05, 2008 | Office Equipment & Supplies
1,582 people viewed this question
k24674
jasbo
jasbo
