Question about Dimplex DS5598 Mid-Size Heater
P10-Q FLAME GENERATOR DRIVE MOTOR is noisy - Dimplex DS5598 Mid-Size Heater
3 Suggested Answers
  • 2598 Answers
SOURCE: the motor driving the flame effect has become
try cleaning the fan and then putting some oil on it might help
Posted on Jan 02, 2010
SOURCE: I need a new flame
what kind of on off switch do i need ,has one black wire and one white wire?
Posted on Dec 24, 2010
The wash machine is reading f-51 and is flasing
Hi
F51 error is a rotor position sensor error. This error appears when rotor position sensor is faulty or due to a faulty control board. Look underneath the tub and check the motor, check for RPS on the right side (follow the brown wires) and under the motors rotor disk. Use allen wrench to remove the rotor and then the four bolts holding the motor stator to the tub can be removed. You would need to check the motor by running Motor test. Please follow the steps ---
1. Unplug washer or disconnect power.
2. Check to see if basket will turn freely.
3. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical
friction or lock up.
4. Remove the console to access the machine/ motor control assembly.
5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6.
If visual checks fail, reconnect P5 and P10 and repeat step 1.
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range.
If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to next step.
7. Tilt machine forward to access the bottom of the machine and the drive motor area. See Figure 1 on page 6-13. Remove the motor bolt, then the motor cover to access the motor connections.
8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9.
If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1.
9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. See Figures 2 and 4, pages 6-13 and 6-16. If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
10. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector. If there is continuity, replace the drive motor. If there is no continuity, replace the lower machine harness.
11. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test in step 1 to verify repair.
12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repair.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Got F 50 code on Whirlpoos Cabrio wash machine. Tub spins, nothing under agitator, replaced control board, nows blows breaker.
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation.
Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction.
If basket turns freely,perform the test below..
This test checks the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. NOTE: Drain water from tub.
  1. See Activation of Manual Diagnostic Test Mode, and check the motor and electrical connections by performing the Agitate and Spin tests under Manual: Motor. The following steps assumes that this stepfailed.
  2. Unplug washer or disconnect power.
  3. Check to see if basket will turn freely. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical friction or lock up.
  4. Remove the console to access the machine/ motor control assembly. See Accessing& Removing the Electronic Assemblies.
  5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6.If visual checks fail, reconnect P5 and P10 and repeat step 1.
  6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7. If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to step 7.
  7. Tilt machine forward to access the bottom of the machine and the drive motor area. Remove the motor bolt, then the motor cover to access the motor connections. S
  8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9. If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1.
  9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
Dec 04, 2010 | Whirlpool WTW6200S Top Load Washer
We are getting a F51 code on our washer. What does that mean?
Hi
Nov 16, 2010 | Maytag Bravos MTW6600T Top Load Washer
What is code F 51
Hi
Thanks for using FixYa and I am sorry to hear whatever happened. Error
F 51 flashes when there is a motor rotor position sensor (RPS) failure. Please follow the step by step instructions to resolve this issue: This test checks the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. NOTE: Drain water from tub.
1. See Activation of Manual Diagnostic Test Mode, and check the motor and electrical connections by performing the Agitate and Spin tests under Manual: Motor. The following steps assumes that this step failed.
5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6. If visual checks fail, reconnect P5 and P10 and repeat step 1.
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range. If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to step 7.
8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9. If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does F51 mean? This comes up on screen. Also leaks from the bottom.
Hi
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F 51 error code what does this mean
Hi
Thanks
Rylee
Aug 23, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Whirlpool error code F50 who do I call ?
F50 means that the Rotation Position Sensor doesn't sense any movement from the motor.
2. Check to see if basket will turn freely.If basket turns freely, go to step 3. If basket does not turn freely, determine what is causing the mechanical friction or lock up.
3. Remove the console to access the machine/motor control assembly.
4. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 5. If visual checks fail, reconnect P5 and P10.
5. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3.Also measure the resistance at the P10 connector between pins P10-1and P10-7 and verify that the resistance is within the range. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range.
6. Tilt machine forward to access the bottom of the machine and the drive motor area. Remove the motor bolt, then the motor cover to access the motor connections.
7. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check fails,reconnect the electrical connections, reassemble stator and motor cover.
8. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector.If there is no continuity,replace the lower machine harness.
9. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector.If there is continuity, replace the drive motor.If there is no continuity, replace the lower machine harness.
10. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test.
11. If the Diagnostics motor failed, then the machine/motor control has failed: Unplug the washer or disconnect power.Replace the machine/motor control assembly.
Thank you !!
Aug 12, 2010 | Washing Machines
Error message F50
Thank you !!
Jun 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code Error F50 Whirlpool Cabrio WTW6600SW
Mar 24, 2010 | Whirlpool Washing Machines
The motor driving the flame effect has become noisy. what can i do
Jan 02, 2010 | Dimplex Compact Electric Flame Stove...
Dimplex DS5598 Mid-Size Heater Logo
124 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
