Question about Dell Dimension 4500 PC Desktop
Wireless How and where do I install a wireless card om my Dell Dimension 4500?
    Novelist:
  • 201 Answers
First, if you are not familiar with installing components I would recommend you have it installed for you. Some major office supply stores will install a card you buy from them for little money or even free. Or you can find a local computer upgrade / repair shop that can do it. Your computer most likely has very large round plastic buttons on the top and bottom edge near the back. The bottom may be partially blocked by a screw on base stand. If so, remove that first. You press both buttons at the same time and open the case like a book. Near the bottom back corner should be some white circuit card slots. You may have to pull out a small metal box to gain access to adding cards. Typically Dell uses green levers, buttons, etc inside the case you use to remove parts. A metal slot cover blank will have to be removed, some just slide off, some have a single screw holding them in place. Installing a PCI card into the white plug should not be difficult but should be seated all the way down and eavenly. If a screw is used to remove the metal slot cover use that screw to hold the card in place. Put everything back the way it was and close the case. You will need to install the drivers that came with the card. Follow the directions for your card. Just in case you were not aware. You do need a receiver (wireless router or access point) that will send the signal to your card. I've had quite a few customers that thought all you needed was the card.
Posted on Jul 12, 2007
SOURCE:
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
I have a Dell Dimension 4500 and want to connect it to the Internet with an Ethernet card. Which card should I use?
I would say any card that gives you the speed you require and importantly is compaitble with your OS.
Jan 31, 2011 | Dell Dimension 4500 PC Desktop
How do I connect my dell 4500 to an ethernet connection? My desktop does not seem to have a connection port. My DSL company (AT&T) sent me a new modem motorola MSTATEA and it does not have a telepohne...
The Dell 4500 uses an add-on PCI card for ethernet.
You may not have ordered this PC with one.
You can purchase a card for this system, if you are comfortable with installing additional cards into the system. The system is
Here is the link from Dell on installing cards. http://support.dell.com/support/edocs/systems/dim4500/replace.htm#1138309
Amazon sells these cards: http://www.amazon.com/s?ie=UTF8&x=0&ref_=nb_sb_noss&y=0&field-keywords=PCI%20network%20card&url=search-alias%3Daps
Jun 15, 2010 | Dell Dimension 4500 PC Desktop
Need graphic card upgrade for Dell Dimension 4500 w/ pixel shader
This is an older machine that has a 4x AGP port for graphics cards. The good news is that cards for this slot are cheap...usually in the 30-50 dollar range. The downside is that you wont get the greatest performance out of them. I would recommend going with a Geforce FX 5200.
Nov 24, 2009 | Dell Dimension 4500 PC Desktop
I have a wireless card in my Dell Dimension
The first thing I would try would be to reset the card, by removing the cover (if you are comfortable), removing the card from the slot and reinserting in the slot or moving the card to another slot (if there is an identical slot). If that doesn't work, replace the wireless card either with another wireless card or a USB wireless network adapter (external adapter that connects to a USB port). Good luck.
Jun 15, 2009 | Dell Dimension 4500 PC Desktop
Add wireless card
You can add one via a USB port like THESE
Or you can add one to an empty PCI slot on your motherboard if you have one available. Like This One
Mar 01, 2009 | Dell Dimension 4500 PC Desktop
Install memory
No. Your Dell Dimension uses PC-2100 type memory. Your Dell Dimension can support up to 1GB of memory. For optimal performance install the maximum amount of memory in each socket. Your Dell Dimension 4500 has 2 banks of 1 socket each for a total of 2 memory sockets.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 25, 2009 | Dell Dimension 4500 PC Desktop
Getting off dial up
You will need a LAN card similar to this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833156117
Very easy to instal and very easy to set up.
Jul 29, 2008 | Dell Dimension 4500 PC Desktop
Formatting my Dell Dimension 4500
sure..boot from an install or recovery cd..and format it from there
Apr 28, 2008 | Dell Dimension 4500 PC Desktop
Dell Dimension 4500 PC Desktop Logo
131 people viewed this question
Clive
Clive
Alun Cox
