Question about Dell Computers & Internet
Compatible power supply 300 watt for 4700C (OEM L161NF3P)
Is want to mount higher-powered supply externally from slim line case in order to put high powered exhaust fan in case. But would like to increase dc power available to new high capacity m-modules and HD. Running a lot of peripherals too (USB). Case has terrible lack of ventilation.
Is there a compatible std pwr supply avaible w/same pin out?
  • rscottfitzge Jan 29, 2009
    Thanks for the info. I'm still trying to work it out using the same case and removing the slimline 160W and externally hooking in a 4-500watt unit. Now my problem is the +5v FP line vs the spec on the 500Watt +5v FSP. Wondering what the the term "FP v "FSP" mean and are the two interchangeable as long as the voltage (+5) and min Amp rating are in spec?
  • 1,602 Answers
I PURCHASE A CASE AT FRY ELETRONIC STORE WITH LOTS OF VENTALATION FOR MORE FAN MOUNTING CAPACITY, THEY PROBLY MAKE A SPECAIL FAN OR MORE POWERFUL POWER SUPPLY FOR THAT SYSTEM, SOMETIME PEOPLE CANNOT AFFORD THAT POWER SUPPLY AND HAVE TO MONTIFY THERE CASE TO FET THE NEW ONE SO THE FAN **** IN THE AIR TO COOL THE NEW POWER SUPPLY, IT IS ALOT OF WORK MOTIFYING A OLD CASE, THE ONE I GOT FROM FRYS ABOUT 40.00 DOLLARS PLUS TAX, EGGHEAD MAY HAVE A CASE BUT I WOULD LOOK AROUND AT OLD COMPUTER SHOWS, IN SCOUTDALE ARIZONA, AT A COLLEGE, THE BOYSCOUT PUT ON A COMPUTER SWAP MEET EVERY OTHER MONTH AND THE LAST SUNDAY OF EACH MONTH, NO FEES TO SHOP, 200 VENDER FROM THE WEST COAST SHOW UP TO SWAP AND BUY THERE COMPUTER GOODS, SOFTWARE ALSO, CASES 5.00,
ITS HELD AT SCOUTSDALE COMMUNITY COLLEGE
CANDYMANGANDY
Posted on Jan 29, 2009
Where can I find power supply for HP model ATX300-12ZBD
There are lots of ATX power supplies on the market. You do not need to use a HP 300 watt power supply. Just purchase one that suit your requirements - 300 watt or more. These power supplies have standard mounting holes.
Mar 10, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Compaq Presario SR2010NX power supply
if it is your power suply that is bad its very easy. all you have to do is get a replacment oem powersuply i would go with this one http://www.atxpowersupplies.com/300-watt-power-supply-fsp-atx-300-gu.php?psu=ATX-300GU-SR2010NX,. you then will want to make sure the computer is powered down. once you get it powered down i would strongly suggest wearing a anti static strap can buy at any computer repair store. you then want to look at end of connectors and will be labeled. u then want to label the ends as you unplug them. all you have to do is label the new ones. once you get old power supplies cables labeled. you can unhook the four mounting screws on the back that hold power suply to case. then all you have to do is hook up new power surly as you labeled old one and can just match up the plugs. then all you have to do is mount to computer. once you mount it go ahead and power up.
Jan 06, 2011 | HP Compaq Presario SR2010NX PC Desktop
I need a motherboard that will fit in a Raidmax ATX1072BP Mid Tower ATX Computer Case!
Most desktop computer cases have a range of standard mount holes, standard offs.
I suggest you select a motherboard that suits your requirements.
To be sure that the motherboard will fit your case, take the motherboard mount base with you to the computer shop and place the motherboard of your choice on the base to see if the mounting holes line up.
You may need to upgrade the switch mode power supply to a higher power unit if the total power requirements is near the maximum the existing unit can deliver.
Dec 03, 2010 | RaidMax ATX1072BP MID TOWER ATX COMPUTER...
Dell (HP-L161NF3P) (P0813) 160-Watt Power Supply ,how i can repaire it
the news on this one is bad unless your an electrical enginer. you can buy a refurbed PSU for about 35 quid. alternatly you could plug a standard power suply into the PC as all the plugs are standard fittings the trouble with that is you would not be able to put the case back together afterwards
Apr 25, 2010 | Dell (HP-L161NF3P) (P0813) 160-Watt Power...
Sometimes work and sometimes doesnt work
Hi , The SMPS Fan needs to be replaced as due to overheating the SMPS sometimes does not switch ON .
Dec 30, 2009 | Dell (HP-L161NF3P) (HP-L161NF3P) 160-Watt...
I there a replacement for a gx280 SFF powersupply?
Your best bet is to take the power supply out and take it to a good electronics store that has decent computer hardware. That way, you can compare the connections available and also its mounting style to make sure it will work.
Sep 11, 2009 | Dell OptiPlex GX280 PC Desktop
Gateway 3310s desk top computer power supply
You can replace the pc with the same watt power supply or upgrade to around 420W and still be able to run your system within thermal threshold. The power supply should be a 20-pin ATX power supply.
Good Luck
C2Solutions
Aug 29, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Power supply packed i n
Yes, you can safely put in equal or higher. Just make sure it is an ATX and that it is P4 compatible. Most new ones all meet to those specs. Higher is actually better. I would go with a 400w or higher.
Apr 07, 2009 | Intel Allied 450W Dual Fan Pentium 4 ATX...
Power supply fan is loud!
Essentially any Standard ATX power supply with a rating of 250 Watts or higher will work
http://www.discountelectronics.com/index.php?l=product_detail&p=1849
Feb 04, 2009 | Dell Dimension 1100 PC Desktop
Upgrade Video Card
I would recommend picking up a higher watt power supply just to keep up with the changing demands on computers. They are not to do yourself. If still wondering what cards can go with a 300 watt power: Maybe an ATi Radeon 9250 256mb? It seems that a 350 watt power supply should still be minimum nowadays and they are cheap.
Oct 30, 2007 | HP Pavilion m7480n (882780389410) PC...
Computers & Internet Logo
154 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
