Question about Sentry Fireproof Safe
I need factory code for sentery safe sbw3500
I bought a sentery safe sbw 3500. i forget the factory code for this safe
Can't open safe!
If it still doesn't open after you replace the batteries then it is probably do to it being Jamed. I'd suggest tapping it with a bit of force but if it still doesn't open to go and see if someone can fix it.
Aug 12, 2016 | Sentry Safe Fire-Safe Home/Office Safe
Lost combination
You need to call sentry and to give them model number, they will give you an unlock code.
May 22, 2008 | Sentry Fireproof Safe
Bought used sentry fire safe model sw3750 , key works, replaced batteries but do not know electronic code
Brian, You can contact the manufacturer at link below, you will need factory code from them to reset. They will need forms filled out before supplying info.
http://www.sentrysafe.com/Products/57/A3750_FIRE-SAFE_HomeOffice_Safe
Apr 08, 2016 | Home Security
I forget my LG 3500 lock code
dear sir,
Code to reset phone :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select 'Factory Reset'
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
the second option is
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website http://www.unlock-zone.com/ which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
the another alternate option is to flash ur phone software from the nearest l.g serice centre,it also updates your mobile software which increases the mobile speed.
thank you...take care
Oct 04, 2010 | Cell Phones
Sentery 1100 + lost keys
There is a code on the front of the lock, probably just a single letter. There is a company in Delaware that specializes in making keys by code. There number is 302-689-6162. Ask for Stanley
Jul 30, 2009 | Sentry Fireproof Safe
Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Mar 22, 2009 | Sentry Fireproof Safe
Unlock code of LG RD 3500 handset
i want unlock code no. mobil modal no. lg rd3500
Feb 02, 2009 | Welding Tools
Sentry safe msw3517
I have a Sentry Safe MSW3517 and forgot my code.
Mar 16, 2008 | Sentry Fireproof Safe
How to cahnge the battery on a sentry safe
There is a small opening on the front number panel of safe. Use a small hex screwdriver or pin to insert into opening. It will open up the front panel (slide panel to right to take off) showing you 4 AA batteries. Just replace and close panel. Very simple to do. I wish the manual show me how. Instead of trying to figure it out for hours.
Dec 25, 2007 | Optics
Sentry Fireproof Safe Logo
501 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
