Question about 3M OKI Data 62433201
OKIData C610 will not power on
Will not power on.
I bought a new Oki C610 a couple of months ago to start up a custom art business. From the beginning, the DCT 4.5 paper has stuck to the fuser roller. With the first fuser cartridge, it just dog-earred on...
Hi my reply was too long heres the second half..and ill retype the first as a comment
Try printing lighter prints, heavy toner saturation causes paper to stick to fusers and try to keep leading edge of print blank with no big blobs of colour for the same reason, ensure page sizes are set correctly in driver and machine tray settings and dont print outside margins , if you are about to print outside margins your printer driver should warn you, dont click ok if it does
Here is your user manual for your oki. and a link to oki print drivers to suit 610
Here is a link to Magic touch Australia that i thought has some good info re transfer paper use
Ensure your printer works ok with plain paper so we know it aint a printer fault but I'd say it due to how we are feeding the paper and how we have the paper type set and not feeding out the rear as I also think we should be.
Oki does the best colour prints nice and glossy, I dont think many come close to such great colour prints in fact I only like Oki and Kyocera stuff in Colour toner laser machines. Stear clear of cheap non oki toners and supplies because they cause heaps of issues and wreck printers and give many print quality issues, I dont work for OKI directly just telling you how it is in the field ;)
Let me know if you need more help and how you go
Cheers
Steve
Nov 05, 2011 | OKI Office Equipment & Supplies
How do i clear an error alarm on my okidata 320? it wont do anything.
Power on then off, then unplug the unit for a few minutes. Then try it.
If this does not work post back.
Feb 05, 2010 | Matrix Okidata Microline 320 Printer
Power cord socket on dell c610 is broken- can I get it out and replace it ?
This is a inexpensive repair, about $100.00 or less.
If you look on the internet or Bing Dell power socket repair.
Without the proper background, you will be replaceing more than the socket.
Nov 04, 2009 | Dell Latitude C610 Notebook
Dell c610 powers off. then to restart you have to
sound like a short the system is fail safe to prevent more damage so repair or replace
Oct 31, 2009 | Dell Latitude C610 Notebook
External hard drive
Yes, no problems, if the USB hard drive draws too much power you will need to attach an external power supply, usually the small laptop 21/2" drivers don't need external power supplies.
Jan 10, 2009 | Dell Latitude C610 Notebook
Deleting outbox messages
The options tab should always appear on the outbox screen. I would try powering off, taking out battery for a few seconds, put back in and power on. I've noticed that most problems with the c610 are solved by turning off and on.
Jan 05, 2009 | Pantech C610 Cell Phone
Okidata C9500dxn
The power supply probably died. Common in the 9500. Also, make sure you are using the recommend power cord for this printer. This printer uses a ton of power and has a requirement for a beefy power cord. Make sure your using a 20 AMP receptical.
Oct 25, 2008 | OKI C9500dxn Led Printer
How to disable the Okidata from printing double space
Try reseting to factory defaults.
Power unit on while holding down "tear" and "FF Load" buttons.
Hope this helps
Dezzi
Dec 27, 2007 | Office Equipment & Supplies
Cover stripe damaged
sure they are the same on the c510 and c610 laptops.
i see them on ebay all the time for $5-$10.
look for c610 power button on ebay.
Dec 16, 2007 | Dell Latitude D600 Notebook
3M OKI Data 62433201 Logo
246 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
