Question about LitterMaid Waste Receptacles for Self-Cleaning Litter Boxes
Littermaid self-cleaning litter box sensor is not working.
2 Suggested Answers
kelly02155
  • 10 Answers
SOURCE: xNon functioning littermaid LM980 mega
Common problem with Littermaid boxes. Try a better brand of clumping litter. Try using a little less litter. And you can help the rake lift up by slowly pushing on it with something, giving it more strength. I had this problem and found that if I "helped" the rake return to its normal position, it would work most of the time, and then need "help" every once in awhile. I actually gave up on littermaid type boxes...they just don't work very well.
Posted on Nov 27, 2012
When rake cleans makes loud noise
Open the left side of the box and you'll see a white plastic part covering the hole. Get scissors and cut it out. The metal piece moving the rake was dragging on the plastic and so I cut it out of mine and now it's back to normal !
Jan 02, 2016 | LitterMaid Mega Self-Clean Cat Litter Pan
How to register my littermaid litter box
you should be able to through the link provided Warranty Registration
Sep 15, 2014 | Cats
HOW DO I RESET A LITTERMAID LITTER BOX?
I HAVE A LITTER MAID AUTOMATIC LITTER BOX AND THE FRONT CENCER QUIT WORKING I HAD TO BY HAND WITH MACHINE ON PULL IT BACK INTO POSITION IT TOOK A WHILE BUT GOT IT TO GO BACK THEN LEFT IT THERE & NOW SCOOPING OUT LITTER BY HAND UNTIL I CAN FIND ANOTHER CENCER. I HAVE NEVER SEEN ANY TYPE OF RESET BUTTON ON IT. YOUR CENCERS BOTH FRONT & BACK MAY BE DIRTY TRY CLEANING THEM GENTLY WITH A Q TIP & RUBBING ALCOHOL.
Jul 28, 2014 | LitterMaid Elite Mega Multi-Cat Litter Box
Littermaid LM980 Turns itself off
The other appliance, e.g., a motor driven one, may be causing the box to malfunction. You may have to use a dedicated connection to get proper results.
Mar 06, 2014 | LitterMaid LM980 Mega Self-Cleaning Litter...
Litterbox is not working
Usually when this happens it is because there is something obstructing the rake making it impossible for the rake to go back to its original position. If there is nothing in the way, no clumps or bunched up litter, then the rake is not functioning the way it should. Sometimes gently pushing the rake back into its normal position can work. I had a LitterMaid that had this problem and every now and again I would have to "help" the rake with a push. If this doesn't work, then you have a defective litterbox that won't work not matter what... return it for another unit. Good Luck.
Nov 19, 2012 | LitterMaid Elite Basic - Advanced...
XNon functioning littermaid LM980 mega
Oct 29, 2012 | LitterMaid Lm980 Mega Self-cleaning Litter...
If I buy a self-cleaning litter box does that mean that I am off the hook for cleaning?
Sorry to break the news to you but just because you bought a self-cleaning litter box does not mean that you do not need to clean it. While they keep themselves cleaner than other litter boxes, self-cleaning litter boxes still require an amount of sanitary maintenance. They necessitate regular washing and litter replacement. You should also keep an eye out for any waste that the self-cleaning system may have missed.
Aug 14, 2012 | Cats
I would really like my cat to have a clean litter box throughout the day. Do self-cleaning litter boxes really work? If so, this could be a worthwhile investment.
I would recommend you check out the LitterMaid litter box. It has two sensors on either side of the box that detect when a cat uses it. After 10 minutes, a rake automatically comes and scoops clumps of solid and liquid waste into a disposable container at the end of the litter box. Keep in mind that this does not eliminate you cleaning the box.
Aug 14, 2012 | Cats
Where can I buy a self-cleaning litter box for my cat?
Self-cleaning litter boxes are increasing in popularity and are available at most local pet supply stores in your area or online. Here are a few places for you to search and compare.
http://www.littermaid.com/
http://www.petco.com/product/100832/ScoopFree-Automatic-Self-Cleaning-Litter-Box.aspx
http://www.litter-robot.com/
Aug 14, 2012 | Cats
Littermaid plus will not rake
Does it rake halfway and then go back and try again? I have had that same problem and have found it's because of too much litter ni the box. The random time I have noticed. As long as it's raking, I'm happy.
Aug 30, 2009 | Kitchen Appliances - Others
LitterMaid Waste Receptacles for Self-Cleaning Litter Boxes Logo
264 people viewed this question
Top LitterMaid Cats Experts
Tom Chichester
Ruth summersides
RANDY POWERS
Level 1 Expert
Are you a LitterMaid Cat Expert? Answer questions, earn points and help others
